car, motorcycle programming or decoding
+ More Options
Posts
    • 21497
    Re: car, motorcycle programming or decoding
    It could be the airflow meter at fault, try cleaning it .
    https://www.justanswer.com/uk-car/8y...ght-keeps.html
    EDIT: https://www.youtube.com/watch?v=NBs6Zxg4Q0A
    https://talkford.com/community/topic...m-fiesta-tdci/
    • Esse
      • Apr 2014
      • 317
      • TOGO
      #42
      I've cleaned the MAF sensor too.please if you think it can be this MAF why the scan is not giving any code related to that?
      • Esse
        • Apr 2014
        • 317
        • TOGO
        #43
        Any help?
        • petehall347
          • Jan 2015
          • 4435
          • United Kingdom
          #44
          you could do with a scanner with live data then you check things better .
          • Esse
            • Apr 2014
            • 317
            • TOGO
            #45
            Please can you give me the Manuel of this particular car Ford Fiesta 2002 1.4dtci diesel
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3616
              • slovakia
              #46
              check error code, then check live data to see what is wrong, than check on problematic area with multimeter/osciloscope
              opel ecu not recieve data from sensor but sensors voltage and wiring is ok?
              in ecu is broken wire between ecu board and ecu connector
              • Pascal Komlassan
                by Pascal Komlassan
                Hello friends. I would like to know if someone is programming or decoding autommobiles (car, motorcycle)
                11-23-2018, 04:18 AM
              • araxnido
                Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
                by araxnido
                Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
                When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
                06-10-2025, 09:26 PM
              • zlr8r
                Advice on newer EC chip programming eg. MEC5107-LJ BGA
                by zlr8r
                Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
                i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
                09-16-2025, 09:54 AM
              • zesko
                MP2886A programming
                by zesko
                I have a board with a dead pwm on mp2886a. I order the chip without thinking about programming, and now I just realize my mistake.
                Someone know if it's 100% needed to program the chip ? And if so, how to program it ? I see some dedicated board and software but, software is a bit tricky to me, the bad part of the job...
                p.s : with the dead pwm chip, the GPU work fine when I disconnect the shorted pwm (6), with the new chip Pgood is 0 and the gpu doesn't start, so I guess it need to be programmed, or it's fake chip..
                p.s 2 : Sorry for my...
                07-28-2025, 02:07 PM
              • hikesync
                XMCQH128A​ Programming issue
                by hikesync
                Sup guys i've been having a trouble with XMCQH128A chips, this is the only model that always fails to programming. All the others models and brands like Winbond, cFeon, etc. All works fine. But i just cant do it with XMC chips, is there some specific program that i must use? (i am using NeoProgrammer)
                06-26-2025, 11:22 AM
