car, motorcycle programming or decoding
    • 20551
    Re: car, motorcycle programming or decoding
    It could be the airflow meter at fault, try cleaning it .
    https://www.justanswer.com/uk-car/8y...ght-keeps.html
    EDIT: https://www.youtube.com/watch?v=NBs6Zxg4Q0A
    https://talkford.com/community/topic...m-fiesta-tdci/
    • Esse
      • Apr 2014
      • 317
      • TOGO
      #42
      I've cleaned the MAF sensor too.please if you think it can be this MAF why the scan is not giving any code related to that?
      • Esse
        • Apr 2014
        • 317
        • TOGO
        #43
        Any help?
        • petehall347
          • Jan 2015
          • 4426
          #44
          you could do with a scanner with live data then you check things better .
          • Esse
            • Apr 2014
            • 317
            • TOGO
            #45
            Please can you give me the Manuel of this particular car Ford Fiesta 2002 1.4dtci diesel
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3573
              • slovakia
              #46
              check error code, then check live data to see what is wrong, than check on problematic area with multimeter/osciloscope
              opel ecu not recieve data from sensor but sensors voltage and wiring is ok?
              in ecu is broken wire between ecu board and ecu connector
              • Pascal Komlassan
                by Pascal Komlassan
                Hello friends. I would like to know if someone is programming or decoding autommobiles (car, motorcycle)
                11-23-2018, 04:18 AM
              • araxnido
                Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
                by araxnido
                Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
                When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
                06-10-2025, 09:26 PM
                Common SPI bios chip programming Questions and Answers
                by SMDFlea
                Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                A: If you can`t read from it how do you expect to write to it ?.
                Q: Why is my bios chip unreadable ?.
                A: The programmer is faulty or has a worn or broken zif socket.
                The USB cable is frayed,connector pins worn or some other physical damage.
                Not enough amperage or voltage to power the programmer properly.
                Bad...
                09-02-2021, 04:40 PM
              • hikesync
                XMCQH128A​ Programming issue
                by hikesync
                Sup guys i've been having a trouble with XMCQH128A chips, this is the only model that always fails to programming. All the others models and brands like Winbond, cFeon, etc. All works fine. But i just cant do it with XMC chips, is there some specific program that i must use? (i am using NeoProgrammer)
                06-26-2025, 11:22 AM
              • bk304
                Dell Precision 3560 BIOS programming
                by bk304
                I am working on a Dell precision 3560 with a locked BIOS. I used AsProgrammer software with the CH341A v1.7 set at 3.3V. AsProgrammer is the only software that works with the CH341A that lists the W25R256JV. Reading the 25R256JV with this setup returned garbage results. I switched to my T48 programmer and it identified the chip as a 25Q256JV and appeared to read the chip perfectly.
                I need to reprogram the chip but I am not sure if the programming the 25R256JV with the 25Q256JV setting will work. I don't want to risk bricking the computer.
                Anybody have any experience or...
                02-16-2025, 09:21 AM
