7200.11 failure
  • stevo1210
    • Oct 2006
    • 4156
    7200.11 failure
    My brothers 500GB 7200.11 Seagate SATA HDD failed today woith that permanently busy and undetectable under the BIOS. There is really important stuff in there, and I know it's a firmware fault.... what do I do?
    Thanks.
  • Harvey
    • Apr 2007
    • 264
    Re: 7200.11 failure
    You replace the drive and restore from the backup.
    • stevo1210
      • Oct 2006
      • 4156
      Re: 7200.11 failure
      Well problem here you see.... my brother backed his data into partition D of the dead drive. He thought his computer had two hard drives, but I only installed one 500GB and split it into two partitions.
      • Wizard
        • Mar 2008
        • 2296
        Re: 7200.11 failure
        Do NOTHING till you do so: Contact Seagate and get firmware if it needs one. Usually that willl take care of this.
        And swear off Seagate/Maxtor for awhile till they get their pants up.
        I haven't felt comfortable with WD due to no full specs disclosed and their previous issues. Hitachi is good so far since they had came clean few years back.
        I'm at this point where I'm on the fence whichever to straddle the fence with SSD and some disc-based HDs but at this moment Hitachi and Seagate have yet to release SSD and Intel asking major premium on their SSD and Samsung SSD currently not in retail (sold only to OEMs at high price). Furthermore, OCZ is of too new to the storage community and reliablity & performance in general not just OCZ is still up in the air. Only OCZ Vertex and upcoming generation 2 Summit series, Intel SSD are my minimum. Rest of other makes of SSD I ignore for many reasons till Hitachi and Seagate do so.
        Seagate was right when CEO threatened other SSD makers with patents as bats primarily for compatibility, reliability and performance issues and did state the reasons for this. And biggest reason Seagate have NOT released any flash based SSD yet is this their is not ready due to no SSD standards regarding this above mentioned issues and partially the price.
        Cheers, Wizard
        • severach
          • Aug 2007
          • 1055
          Re: 7200.11 failure
          Go watch some presentations.
          http://www.myharddrivedied.com/
          sig files are for morons
          • fzabkar
            • Mar 2009
            • 772
            Re: 7200.11 failure
            The Solution for Seagate 7200.11 HDDs:
            http://www.msfn.org/board/index.php?showtopic=128807
            • stevo1210
              • Oct 2006
              • 4156
              Re: 7200.11 failure
              Well my brother found most parts of his data on his laptop so that solved one thing. I returned the 500GB Seagate to the store and they said it should come back in 3 more days.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                Re: 7200.11 failure
                wd blue ide 250gb thailand
                tested fully with wd diagnostics
                install and a few weeks later bad block
                • stevo1210
                  • Oct 2006
                  • 4156
                  Re: 7200.11 failure
                  Been nearly 1 week now and my 500GB drive hasn't come back yet.
                  *sigh* If Seagate's bad and WD's bad, then what else do I have to choose from? They are the main companies which make HDDs here so it's one over the other.... though the Seagate only has bad firmware which I suppose is better than a bad block.
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    Re: 7200.11 failure
                    aw shit its toast. hope backup good
                    • kikkoman
                      • Jul 2007
                      • 691
                      Re: 7200.11 failure
                      IMO there's only Hitachi left at the moment. at least i haven't heard bad things about them in a while (years).
                      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        Re: 7200.11 failure
                        probably cos not well stocked everywhere
                        • KeriJane
                          Mac Enthusiast
                          • Sep 2008
                          • 681
                          Re: 7200.11 failure
                          Hello.
                          I had one of those 7200.11 drives over here.
                          Go to Seagate's website... the firmware page for 7200.11 is here: http://seagate.custkb.com/seagate/cr...p?DocId=207931
                          I'm not sure if the patch will work after the bug bites, but here's an interesting workaround if it doesn't:
                          The data should still be on the drive but the firmware bug sets the drive's size to 0kb. This renders the drive unreadable.
                          You could use SeaTools to reset the drive's size in order to recover data.
                          Here's a thread on the procedure:
                          http://forums.seagate.com/stx/board/...id=17932#M7069
                          I caught one before it went blooey. The firmware update is available as an .iso file that is burned to a bootable CD. You merely boot the affected system from CD to update the firmware. It worked perfectly over here on a non-failed drive.
                          Good Luck,
                          Keri
                          The More You Learn The Less You Know!
                          • stevo1210
                            • Oct 2006
                            • 4156
                            Re: 7200.11 failure
                            The store told me that it should come back in 3 days when I returned the drive and now they tell me it will take 2 to 3 weeks to come back. Fuck.
                            And so they shift the blame to Seagate and thier supplier that my drive hasn't returned. *sigh*
                            • stevo1210
                              • Oct 2006
                              • 4156
                              Re: 7200.11 failure
                              It's been like 2 months now and my damn HDD still hasn't come back. I was frustrated this afternoon so I called the store. Again they said it didn't come back, but before I even had time to open my mouth and whine about their crappy service, the guy on the phone says he put me down for the order of a brand new Seagate 7200.12 SATA 500GB HDD which is ready for pickup tomorrow. Pretty good i suppose.
                              Thanks.
                              • ant3202
                                • Jun 2006
                                • 275
                                • Singapore
                                Re: 7200.11 failure
                                I also had encountered this problem before...
                                it take weeks to do....
                                sighs...
                                • shadow
                                  • Feb 2007
                                  • 732
                                  Re: 7200.11 failure
                                  Looks like you can't win with hard drive manufacturers.
                                  I guess you just have to keep a backup of everything important and expect the hard drive to fail just after the warranty period.
                                  • shadow
                                    • Feb 2007
                                    • 732
                                    Re: 7200.11 failure
                                    I tried to update the firmware on my relatively newish Seagate 7200.11. It would not let me, I think it already has the newest firmware since I bought it. I bought it only a few months ago thou.
                                    The Seagate diskcheck utility said that there is no available firmware for my hard drive (based on the serial number). When I tried to update the firmware anyway, it just said that nothing needs to be done and thats it.
                                    • stevo1210
                                      • Oct 2006
                                      • 4156
                                      Re: 7200.11 failure
                                      Argh! I got my HDD back today and the sticker says "Certified repaired HDD". They said this was a new one when technically it isn't. Still a 7200.11, but with firmware SD1A?
                                      • willawake
                                        Super Modulator
                                        • Nov 2003
                                        • 8457
                                        • Greece
                                        Re: 7200.11 failure
                                        thats annoying and typical for some manufacturers
                                        i am using the same firmware and no probs yet
                                          HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                          09-12-2024, 02:00 PM
                                          HP ProBook 430 G7 + Seagate Expansion 1TB Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G7 + Seagate Expansion 1TB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Seagate Expansion 1TB boardview and 430 G7 + Seagate Expansion 1TB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 08:10 PM
                                          HP ProBook 450 G7 + Seagate Expansion 1TB Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G7 + Seagate Expansion 1TB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + Seagate Expansion 1TB boardview and 450 G7 + Seagate Expansion 1TB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
