reset password windows 10
  • Rouer
    • Jan 2019
    • Osaka
    Re: reset password windows 10
    Originally posted by desert-rat
    Mint is Ubuntu , it works for me . Its running on the lap top I am making this post from now. There are other distros. Most of them are free and will run from a usb drive . If you dont like the distro you have only wasted a bit of time down loading them . You down load it as an iso file , copy it to usb drive as a live boot. It runs from the drive with out being on the hard drive . Only installing if you like it .
    https://www.mobiledic.com/windows-to...-password.html
    p.s. Mint/ubunty are general porpuse , distros like Kali are more for hackers
    http://trinityhome.org/Home/index.ph...g=en&locale=en
    Good luck to you,generally speaking, you will succeed with them.
    • showmelee
      • Sep 2018
      • 5
      PCLinuxOS is nonsystemd!!!
      • llonen
        • Sep 2014
        • 495
        • hampshire
        I don't run the abortion that is win 10 so I would not necessarily know but tell me the age old hack,
        Find osk.exe and rename it to osk.bak
        Find cmd.exe and make a copy naming it to be osk.exe.
        no longer works its not like they have had years to fix this
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          Originally posted by Uranium-235
          new members answered a question of a new member and the vets just complained about windows 10
          we're better than this people
          If this was an automotive forum, would you entertain questions like:
          • "The back left tire on my vehicle is flat. How do I fix it?"
          • "How come the radio isn't playing my favorite station?"
          • "Why does the gas pump turn off before the tank is completely filled?"
          The forum isn't "Computers R Us" or "Computers for Dummies". And, we've had google for 20 years, now -- if someone hasn't figured out how to ask a question THAT HAS UNDOUBTEDLY BEEN ASKED BY TENS OF THOUSANDS OF PEOPLE and get an established answer by that means...
          A querent (not to be confused with a queer ANT!) has some basic responsibility to think about the question they're posing before posting it!
          OTOH, if you want the forum to devolve into one of the above (CRU, CfD), then please don't be annoyed when you then have to spend considerable time digging through mindless posts trying to find anything of substance!
          Had the OP asked an equally "stupid" question about "Why did my REPLACEMENT caps short out?", I would imagine a more tolerant response (e.g., have you checked to make sure you didn't install them BACKWARDS? have you checked their WVDC ratings?)
            Great Sage é½Šå¤©å¤§č–
            • 30965
            you see how much trouble win10 is!!
            it even gets people who dont use it to attack each other!
            • Curious.George
              • Nov 2011
              • 2305
              • Unknown
              #26
              I don't see anyone "attacking" anyone else.
              Uranium expressed a valid observation -- no one is disputing that.
              I simply stressed that we have a reasonable expectation to have querents think twice about whether this is the right place to ask particular questions. The OP could just as easily have typed his/her query ("windows 10" "reset password") into google and found "About 6,400,000 results (0.75 seconds)".
              But, that would assume the querent could read an answer without then having to ask for clarification ("hand-holding") -- which is what a forum would provide!
              • captainKKK
                • Sep 2018
                • 287
                Tell me exactly how to permanently turn off W10 updates
                  • 30965
                  pull the ethernet out or turn off your router.
                  • Curious.George
                    • Nov 2011
                    • 2305
                    • Unknown
                    #29
                    pull the disk out or turn off your PC?
                    • captainKKK
                      • Sep 2018
                      • 287
                      ........And still be able to actually use W10
                      • Curious.George
                        • Nov 2011
                        • 2305
                        • Unknown
                        #31
                        I think it gets irritated if it can't suck on mama's t*tties often enough. Then, gets irritating!
                        • captainKKK
                          • Sep 2018
                          • 287
                          I have tried everything from shutting off services and modifying the registry to make the thing stop doing the update and nothing stays changed even if I changed the permissions. Best I can do temporarily is to stop and disable the Windows Update service.
                          • Soumana Sanou
                            ā€œHP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                            by Soumana Sanou
                            Hello,šŸ˜‡šŸ˜‡šŸ˜‡
                            I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                            šŸ”§ Model: HP ProBook 11 G2
                            šŸ“¦ Serial Number: 8CG72478MY
                            šŸ†” UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                            šŸ”’ BIOS Status: Locked with password
                            The laptop is no longer under warranty and HP refused to help me.
                            I’m looking for a custom SMC.bin file.
                            I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                            Thanks a lot for your help!šŸ™šŸ™šŸ™...
                            06-17-2025, 04:04 PM
                          • lefou486
                            Reset BIOS password on Lenovo Thinkbook 15 G2 ARE
                            by lefou486
                            I made a big mistake
                            I put a password for BIOS & i don't find it
                            I use a random password generator & I neted the password before put into the bios
                            Everything works OK until i want to change an option in my BIOS
                            password is wrong
                            I don't understand
                            How reset this password ?
                            Thanks for your help
                            07-29-2022, 09:18 AM
                          • Nopslide
                            HP Omen 15-dh0052nf power-on & bios password
                            by Nopslide
                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                            04-01-2024, 04:27 PM
                          • outsider
                            Panasonic FZ-G1 MK5 - BIOS password returning
                            by outsider
                            Hello
                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                            https://www.badcaps.net/forum/troubl...61#post3637661
                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                            06-17-2025, 12:51 AM
                          • FaissalDZ
                            Probook 5330m bios password reset
                            by FaissalDZ
                            Hi everyone.
                            I have an HP ProBook 5330m with bios password.
                            and I need help to unlock this password.
                            I already try RCUnlocker tool
                            Please help me.
                            Serial: CNF1400VLB
                            Product: LG723EA#ABF...
                            01-20-2025, 09:57 AM
