upgrading memory dimension 3000
  • klein
    • Nov 2008
    • 37
    hi
    i have a dell dimension 3000 and would like to upgrade it with:
    Intel Pentium 4 3.2 GHz 1MB 800 MHz SL7E5 Processor Socket 478
    memory wise i'm a little confused
    i understand it will take two one gig sticks of memory
    pc3200 ddr-333 184-pin 2.50v nonECC
    pc3200 ddr-400 184-pin 2.50v nonECC
    witch will give me 800fsb ?
  • R_J
    • Jun 2012
    • 9552
    Re: upgrading memory dimension 3000
    You want PC3200 (ddr-400) I don't believe there is "PC3200 ddr-333", that would be PC2700 (ddr333)
      master hoarder
      • May 2008
      • 12175
      It doesn't matter which one you use, as the RAM frequency will be set independently of the CPU. CPU will still run at 800 MHz FSB. However, for the sake of running the RAM at the same clock as the system main clock (200 MHz), then use the DDR400 RAM.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        2700 is 333, 3200 is 400
        also, make sure your bios is flashed to A03 before upgrading the CPU
        1GB DDR is not cheap, we're talking $45 a stick, relative to DDR2 2GB sticks new that can be $15, or DDR3 1600 4GB sticks that run $30
        you're money is best put to something like a core 2 board/cpu combo used off ebay with some ddr2, a new case. You can probably keep your HDD because a lot of c2d boards still have ATA ports, but you would have to get one with two, because you don't want to put your ATA drive on the same cable as your cd/dvd drive. Or get a sata hdd. They're pretty cheap now a days new like a 500g, or sometimes even 1gb are cheaper because they're in high supply.
        i'm assuming you know how to install the OS, in the case of a c2D I would recommend Windows 7 and 4GB of ram. If you want to go all out, you can get a board with 4 slots and go for 8, but thats somewhat overkill. the performance difference between what you're trying to upgrade to with the D3000 is night and day
        edit: Yay! 3000 posts!
          master hoarder
          • May 2008
          • 12175
          Whaaaaaaa???????????
          You can get used DDR and DDR2 memory on eBay for around $1 to $2 per GB if you looked a bit more. I typically look for scrap memory / memory for scrap. All sticks I have gotten so far (over 30) from various sellers have always worked. And most of the RAM is usually from quality OEM brands too.
          If that sounds too sketchy for you, there's always the refurb/tested-recycled RAM on eBay, which also goes for much cheaper. But $45 for a stick of 1 GB of DDR? That's a straight rip off!
          As for upgrading that Dimension 3000... yeah, maybe not very worthwhile, although that can also depend on what you need it for. If it's just for typing or some specific task that does not require internet use - yes, you can still probably get more use out of it. But for internet browsing, I suggest going with something Core 2 Duo or newer too. My parents had a Dimension 3000 and I kept it going pretty much until 1 year ago, as they rarely used it for browing and mostly for typing. But eventually, it just got too slow even to check mail for them, so I had to replace it. I still have it and will eventually re-purpose it.
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            I was talking about new prices, sorry
            • Fast Alpha
              • Feb 2013
              • 245
              I have got a Dell Dimension 3100 that takes 2x1GB DDR2 SDRAM.
              Yep just get a new computer or build it yourself.
              http://www.hse.gov.uk/pubns/indg305.pdf
                master hoarder
                • May 2008
                • 12175
                Buying new stuff for an old computer is always an unnecessary waste of money. (Not that upgrading a very old one isn't... but again, that all depends on the application - if the PC has a specific use or is fine for what is needed, then it's not a waste).
                • brethin
                  • Dec 2008
                  • 1907
                  depending on the OS your running and how much ram you have now it may not be worth the effort, then again you can get the ram you need on eBay for like $5.
                    LENOVO 3000 J110 3000 J E6300 Specification for Upgrade or Repair
                    This specification for the LENOVO 3000 J110 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 3000 J110 boardview and 3000 J110 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO 3000 J110...
                    09-12-2024, 03:36 PM
                    ACER Predator Orion 3000 PO3-600 Predator Orion 3000 i5-8400 Specification for Upgrade or Repair
                    This specification for the ACER Predator Orion 3000 PO3-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 PO3-600 boardview and Predator Orion 3000 PO3-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-12-2024, 03:28 PM
                    ACER Predator Orion 3000 PO3-620 Predator Orion 3000 i7-10700 Specification for Upgrade or Repair
                    This specification for the ACER Predator Orion 3000 PO3-620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 PO3-620 boardview and Predator Orion 3000 PO3-620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    ACER Predator Orion 3000 600 I9200 Predator Orion 3000 i5-8400 Specification for Upgrade or Repair
                    This specification for the ACER Predator Orion 3000 600 I9200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 600 I9200 boardview and Predator Orion 3000 600 I9200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                    Lenovo 3000 Series Schematic
                    Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                    3000 C100 laptop with Braille keyboard
                    Lenovo 3000 C
                    C100, C200 - 15-inch XGA screen
                    Lenovo 3000 N
                    N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                    N500 - 15.4 inch screen.
                    Lenovo 3000 V
                    V100, V200 - 12.1-inch WXGA models
                    Lenovo 3000 G
                    G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                    10-04-2024, 06:05 AM
