DisplayPort woes
  • stevo1210
    • Oct 2006
    • 4156
    DisplayPort woes
    Hi Everyone.
    Just bought a new LG Ultra wide monitor today. Love it to bits, however I am having an issue with displayport.
    Displayport works and displays an image without issue, however if I were to turn off the monitor or simply change source... if I flick back or turn on the monitor again while the PC is still on... it displays "no signal". I would have to turn the computer off completely or reset it for the monitor to get a signal again. This behaviour does not happen on HDMI - I can turn off the monitor while my PC is still on, and switch it back on without issues.
    However. I decided to grab my brothers computer which he uses DP on, and also use his expensive Amphenol DP cable (full size DP), there are absolutely no issues and it behaves as normal - ie. if I switch off the monitor and switch it on again while PC is running - it receives signal and comes out of sleep mode or whatever.
    I have never used DP before so I don't know what I'm doing wrong here. The cable I am using is the one that came with my Viewsonic 4K monitor which was donated to mum. It's a DP to Mini DP because my HD6870 card only has mini DP, and not full size DP like my brothers PC.
    Could it be a cheap cable issue?
    Thanks.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: DisplayPort woes
    cable or the connector would be my guess.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • stevo1210
      • Oct 2006
      • 4156
      Just got a different Mini DP to DP cable for it. Works fine now!
        by momaka
        03-15-2023, 10:17 PM
      • papillon
        Monitor Interlook switch on a microwave
        by papillon
        I *was* trying to determine the cause of a failure in a microwave oven.
        The unit is a Frigidaire Gallery model CGMV175QFA.
        For future reference, the exploded view for this specific model is available here.
        The last page of that document also has the electrical diagram which I am attaching to this message as well.
        The unit had a blown fuse when I opened it. I tested each component individually (magnetron, relays, tracsformers, etc) and all appeared to be working fine (no shorts) but the fuse kept blowing.
        Eventually, I looked at the electrical diagram...
        04-17-2023, 09:32 PM
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
      • ArchangelGabriel
        Aorus 17G YD laptop, broken display, could not switch to external monitor
        by ArchangelGabriel
        Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
        11-23-2023, 03:55 AM
      • Natob82
        Micro Momentary Push Switch?
        by Natob82
        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
        12-21-2022, 05:22 AM
