m-sata to sata pinout diagram
  • angel-boy
    • 550
    hy , i cannot manage to connect a m-sata 128gb to sata connector,
    i power with 3.3 , and tx , rx , but noting
    any help ?
    • 31300
    Re: m-sata to sata pinout diagram
    try pinouts.ru website
    • angel-boy
      • 550
      i want to know how to connect pin to pin . i see that have , Presence detection , Device sleep , this i dont know where to put
      • DynaxSC
        GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
        by DynaxSC
        I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
        There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
        The board is generally working now, all PCIe ports are working, Windows installs normally.
        However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
        The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
        03-10-2025, 12:27 PM
      • AquaMan Ua
        Panasonic toughbook CF-19 help connect the HDD directly. Need a SATA pinout.
        by AquaMan Ua
        Hello, dear community. NEED A DIAGRAM of the HDD/SSD connector contacts as an example (a screenshot from the diagram of another laptop on which I have already done this and a photo of the patient's board) Maybe someone can make a screenshot of the diagram with the pinout? Or does someone have a diagram of the motherboard schematic?
        I am asking, because not find the information myself anywhere. I have a PANASONIC CF19 MK2 laptop (Any revision will do, I do not think that the contacts in the connector are located differently) but finding a basket for it at reasonable prices is a problem....
        08-26-2025, 09:07 AM
        HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
        This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
        09-12-2024, 03:28 PM
      • Kambi13
        Socket G3 / rPGA946B Pinout diagram
        by Kambi13
        Does anyone have the pinout diagram for intel's Socket G3 / rPGA946B
        Best Regards
        09-14-2022, 05:34 AM
      • hs5424
        Dynacord powermate 1600 block diagram.
        by hs5424
        Hi All,
        I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
        The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
        07-31-2025, 01:35 PM
