Windows 10 Update Breaking Program Install Paths
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    • Electronic Repair
    So I'm probably going to get flamed for asking this because I know a bunch of you are big-time Windows 10 haters, so I'm going to save you some time. I do not plan on downgrading to Windows 7 or XP, and I definitely do not plan on installing Linux.
    Ok, so with that out of the way, I'm having some trouble with the Windows 10 forced updates. Windows 10 is harassing me to install a big update. I think it's a creators update or some crap. If I leave my computer alone it automatically installs it and then I have to use a system restore to get back to the previous version.
    I have a small SSD which has windows installed on it and often used programs like firefox. I also have a raid array where about 90% of my programs are installed. This works great and I have no problems with it. However, when the system updates, it somehow forgets that my programs are installed on drive E and starts looking for them on drive C. This breaks all my file associations, programs, and I can't even uninstall them because Windows thinks that the program was installed on C and is now missing.
    Is there any way I can tell Windows that the programs are installed on E and not C?
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Windows 10 Update Breaking Program Install Paths
    I know that with Windows 95, Windows 98 and the like, (ME)
    it's by design, but not so much with NT-based Windows.
    NT-based Windows-* seems to be more tolerant of having programs on other drives...
    *-NT-based, includes Windows 2000, Windows XP, Windows Vista and later...
    And the large update, is 99 percent the fall creators' update...
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • jondoe
      • Nov 2016
      • 547
      I have multiple drives and I've never seen that problem after an large update, I'm nervous now
      • diif
        • Feb 2014
        • 6978
        • England
        Look at Symbolic links (symlinks). Introduced in Vista and on all subsequent Windows versions.
        https://www.howtogeek.com/howto/1622...dows-or-linux/
          • 31925
          so that's the thread closed then!
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            • high voltage stuff, hardware, unix, BSD, POSIX compliant systems.
            ^ Install Plan9!
            Follow the white rabbit.
              master hoarder
              • May 2008
              • 12185
              • Fixing stuff
              Lol, Windows 10.
              Maybe try a fresh install of Windows 10 again (perhaps on a spare HDD, so you can test this), then let it do it's update, and *then* reinstall all you programs??
              I don't know, but if I had Windows 10 (ha! who am I kidding here), I'd let it do its update thing and not mess with it. MS designed it like that, and there's not much you can mess with IMO.
              Can't wait to see what the next Windows version will bring. Probably no control over your computer whatsoever (not that 10 gives you much).
              I think a possible better alternative would be Windows Server 2012 as a desktop OS with some tweaks. (And also supported for a long time, compared to 7 and 8/8.1).
                • 31925
                next version will probaby replace the keyboard with Alexa!!
                (i'm sorry hal, i cant let you do that!)
                • TechWizard.Support
                  • Aug 2017
                  • 30
                  • Fixing Things, Keeping Fit, Helping People
                  Windows 10 has the option to Change where new apps are saved to, and even filter installed apps by drive letter, so it's unfortunate that the update caused this issue!
                  Are all your apps installed on your F: drive? You could try changing the default program files path, but this could cause all sorts of issues, more info here:
                  http://www.tomshardware.co.uk/answer...-question.html
                  What I'd recommend (despite it being frustrating and time consuming), is a fresh Install of Windows 10 1709 and re-configuring everything. You can download the media creation tool here:
                  https://www.microsoft.com/en-gb/soft...load/windows10
                  • keeper5511
                    Asus strix z490-g gaming wifi bricked after bios update
                    by keeper5511
                    I have a motherboard Asus strix Z490- g Gaming wifi and a 10th gen CPU. I have update BIOS to 2701 version but then I realized that I needed to update the ME firmware first. I didn't read the ASUS notice that said, "Before BIOS update, please download Intel ME update tool from ASUS support site. I updated the BIOS without doing this, and everything seemed fine until the system performed an Intel ME update and shut down permanently. Now the motherboard have "No power issue" and it seems dead!!! My attempts to reflash it were unsuccessful. Searching online, I found several people...
                    03-25-2026, 02:01 AM
                  • FluxCapacitorish
                    Aiwa TV-49UF30H (VM6901 / LC490EGY) stuck in bootloop, need install.img firmware dump
                    by FluxCapacitorish
                    I’m working on an Aiwa TV-49UF30H that is currently stuck in a bootloop. I’ve done a full teardown and diagnostics and wanted to see if anyone has a firmware dump or matching install.img.
                    Symptoms:
                    • Without USB: power LED flashes, TV immediately shuts off (bootloop)
                    • With USB (install.img): green LED + grey screen (appears to enter recovery mode but does not proceed)
                    What I’ve confirmed:
                    • Main chipset: VM6901
                    • Storage: eMMC (Kioxia THGBMNG5, integrated MCP under heatsink)
                    • No SPI flash present on board
                    • USB recovery bootloader is working and detects
                    04-06-2026, 03:04 AM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • Herewegoagain
                    Bios update with Ch341A failed MSi MAG B660M BAAZOOKA
                    by Herewegoagain
                    As the title suggests I broke a motherboard and I'm trying to figure out how or if can fix it. This board has a WSON-8 Bios chip with a 1.8V . In a great moment of learning I fried the chip before I could pull the original bios image from the chip. I bought the same exact Bios chip and programmed it using the most recent bios file from MSI's website. After re-soldering it to my motherboard nothing happens no debug lights or postcodes. I have since tried reloading the most recent bios and an older bios version that matched what was on the motherboard when purchased it but nothing has worked. Currently...
                    08-17-2026, 05:14 PM
                  • skynet2021
                    Lenovo ThinkPad L16 G1 21L4 Unable to update firmware to RTS5453V HELP
                    by skynet2021
                    As I explained, I received a Lenovo ThinkPad L16 G1 21L4. It’s not possible to update the firmware to RTS5453V; the device doesn’t recognize the two USB-C ports, and there’s no way to complete the update because every time it reboots, it checks for the charger and battery. The device works perfectly on battery power, but when I connect the charger, I only get 5V on the input line. I hope I can count on your help. Thank you in advance, and I’m attaching photos of the issue I’m experiencing.Lenovo Vantage: If the battery is connected, it never performs the pre-installation steps to reboot...
                    08-14-2026, 01:42 PM
