Cellular signal bar scales
  • japlytic
    • Oct 2005
    • 2086
    I have noticed on Windows Phone and Apple devices that the cellular signal bar scales have five bars while Android devices only have four, and I am curious why.
    Fortunately, my automotive audio system has a five bar scale.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Cellular signal bar scales
    Really? Mine has 8....
    Follow the white rabbit.
      • 31200
      pointless anyway,
      is it showing strength, or BER??
      because that second reference is the important one.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8327
        On the iPhone you can show the signal strength in dB I stead of bars.
          • 31200
          again, not much use - you need to know the quality rather than strength.
          the tuner can pull a signal from almost nothing, but if it's corrupted by noise then it's not much use.
          a BitErrorRate percentage would be more usefull.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8327
            I know that too, that the BER is more useful for an RF junkie looking at a digital signal, but the signal strength is a simpler useful tool. Not everyone knows about BER what is actually represents and why it is important. However, signal strength understand everyone. At the end of the day, either it works or: “Whaaat? You’rebreaking Up on me!”
              • 31200
              so your saying it's good to have a placebo-guage?
              like the fake pull-out antenna's on early motorola handsets!!!
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8327
                stj, your da hoot! I've had some good laughs with you! I remember the placebo antennas in various items, not only cell phones.
                • mariushm
                  • May 2011
                  • 3799
                  There's no standard for what those bars represent, see : https://www.digitaltrends.com/mobile...ked-an-expert/
                  This may also be very informative (shows bar thresholds for iphone 4 ) : https://www.anandtech.com/show/3794/...one-4-review/2
                  • AstutePauciloquent
                    Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                    by AstutePauciloquent
                    Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                    I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                    11-23-2023, 11:02 PM
                  • CoinCoin88
                    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                    by CoinCoin88
                    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                    09-15-2025, 03:36 AM
                  • howardc64
                    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                    by howardc64
                    Failure Symptom
                    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                    Where is the short?
                    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                    05-27-2025, 02:56 PM
                  • JayPoorJay
                    Converting +/- 5v to a Usable Hz Signal
                    by JayPoorJay
                    Good morning.
                    I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
                    This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
                    The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
                    08-07-2022, 08:35 AM
                  • supravit2000
                    PS4 fat has inconsistent signal after HDMI replacement
                    by supravit2000
                    Hi, guys!
                    I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
                    My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so...
                    12-19-2022, 08:08 PM
