HP lappy at it again
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    I got this laptop for free after the charger port broke about a year ago. A couple minutes of jamming a screwdriver into the back of the charger port, it was working, and has since.
    Anywho, the other problem is windows would sometimes take years to start up. It would not read the hard drive, just sit there, and it was apparent when trying to start in safe mode. It would try to load a certain file, agp440 file. Eventually it starts in safe mode, and sometimes it starts in normal mode. I'm wondering if it's a problem with the install, the hard drive tests in HDtune to have no problems.
    I flashed the bios to the newest, and that fixed it for a couple of days.
    Its a HP Pavillion zd7020us, 2.8ghz p4, 512mb ddr-333, 80GB Hitachi, nvidia goforce 5600.
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: HP lappy at it again
    Just for kicks, check the Windows event viewer. Sometimes disk problems will show up there.
    A man convinced against his will is of the same opinion still.
    • Harvey
      • Apr 2007
      • 264
      Try and get the manufacturers HD diagnostic application and run that on a surface test, or failing that, try Speedfan and see what the SMART settings say, as your probably getting sectors reallocating due to a fault on the drive.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        agp440 is a red herring.
        It's the last file that DOES load properly. (That's why you see it displayed.)
        It's the file after it that's causing your problems.
        The next one after varies but is most always networking related.
        Mann-Made Global Warming.
        - Dr Seuss
        • motormayhem
          Lenovo T460 Only Charges on One Charger
          by motormayhem
          Laptop Question
          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
          05-12-2023, 01:46 PM
          NVDC charger configuration...
          11-05-2024, 03:28 PM
        • flat-earther
          how to prevent a connected charger from draining battery when not charging?
          by flat-earther
          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
          So the battery is backfeeding the charger and being drained.
          How can I prevent...
          08-07-2025, 01:04 PM
        • flat-earther
          ASUS X54H laptop thinks it's always charging even with charger unplugged
          by flat-earther
          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
          Windows also shows ''Plugged in'' when charger is not connected.
          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
          If I let battery run out and say it has 3% Windows will...
          06-24-2025, 09:32 AM
        • Johndill
          Dell Inspiron 7567 LA-D993P odd charger issue
          by Johndill
          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
          Here are the tested scenarios:
          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
          2. With the laptop off, plug in charger (LED says on) & the front charging...
          11-16-2022, 10:55 PM
