voltages... good or bad?
  • gustie
    • Dec 2008
    • 76
    i still need to remove the PSU in THIS pc to check for bad caps..
    but this is what OCCT says about it...
    seems to ripple a bit and seems LOW?
    this PSU scrap or ok?
    DFI Lanparty NF2 Ultra B
    TICTAC 619XT Bios
    AMD Athlon XP-M 2600+ FQQ4C IDYHA I-Stepping
    Speeze Vulture spin 3 Heatsink and Fan
    2x Mushkin XP4000 1024m DDR500 (1:1) @ 2.5-3-2-8 1T
    GeForce FX 5700 256m
    Zalman VF900 CU GPU cooler
    Skyhawk 400W Aluminium psu
    Sharkoon Silent Eagle 1000 case fans
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: voltages... good or bad?
    OOCT relies on motherboard's hardware monitor to read voltages and HM isn't sensitive enough to detect real ripple (voltage transients, they last a fraction of second): what you see is some fluctuation (especially on the vcore graph), maybe some noise (the 10 min spikes on the 12 V graph), but not ripple.
    2nd: this psu seems quite low on the 12 V rail because it has a big jump when OCCT stresses the cpu and on your motherboard the 12 V is feeding the processor; it may be a group regulated one (old design) since all voltages are lower, though within ATX tolerances, when the cpu is at full load.
    My suggestion is trying another psu, a recent and good one, and checking voltages with a oscilloscope (if you own it): don't trust an uncalibrated hardware monitor at all, its readings may be off (a digital multimeter is useful to compare values, but won't give you ripple anyway).
    Zandrax
    Have an happy life.
    • gustie
      • Dec 2008
      • 76
      my CPU has a small feed like the P4 type lead with just 4 pins too - but i dint know what voltage that is...
      TICTAC 619XT Bios
      • zandrax
        Hit and miss
        • Dec 2007
        • 1157
        • Italy
        It's the ATX 12V connector: yellow cables are 12 V, black ones are ground
        Your psu is weak on the 12 V side, vcore is based on the 12 V and its fluctuations are up to 0.2 V on 1.6 V: if I were you, I'd try another psu.
        Zandrax
        Have an happy life.
        • gustie
          • Dec 2008
          • 76
          thasnks
          i will open it up over the weekend to check caps too....
          this week ive found a PSU and a mobo with bad caps...
          now i have a spare mobo and PSU to recap - it wont hurt if i kill these
          just need an iron now!! and the caps lol
          TICTAC 619XT Bios
          • KeriJane
            Mac Enthusiast
            • Sep 2008
            • 681
            Hi gustie!
            For the caps, you can probably obtain them right here from Badcaps.net.
            DigiKey.com is my favorite.
            There are a lot of caps on eBay, but don't order from the Asian vendors as it will usually take at least 2 weeks to arrive. Also, they sell a lot of no-name and counterfeit caps.
            The soldering iron is much simpler.
            For Power Supplies, nothing too fancy is needed for soldering. Most standard pencil type irons are fine. A pointed tip is better than a chisel tip for tight areas.
            Now for De-Soldering, you have a few options:
            1- they make a desolder wick that will wick away the solder. I don't like these, but they are cheap.
            2- A spring-loaded desolder tool. These work, but have to be cocked before every use and the inertia from the sudden release can cause you to bump and possibly damage things. These things are about the size of a large marker and are fairly cheap.
            3- a soldering iron with a rubber bulb attached to a hollow tip. These things work great and they're cheap. Radio Shack sells one for like $15. They even carry spare rubber bulbs! Just be careful where you point it when squeezing the bulb IN .
            4- a vacuum-type professional desoldering station. That's as expensive as it sounds and is probably a good idea for desoldering delicate multi-layer motherboards.
            Have Fun!
            Keri
            The More You Learn The Less You Know!
            • gustie
              • Dec 2008
              • 76
              will these ship to the UK?
              TICTAC 619XT Bios
              • tazwegion
                • Jun 2006
                • 444
                Internationally I source my low ESR SamXon capacitors directly from their sales rep "Bigpope" he used to frequent these forums (don't know about recently)
                Get a DMM and strip that questionable PSU down... be a great start
                Viva LA Retro!
                • gustie
                  • Dec 2008
                  • 76
                  whats a dmm?
                  TICTAC 619XT Bios
                  • stevo1210
                    • Oct 2006
                    • 4156
                    dmm is a digital multi meter.
                    • gustie
                      • Dec 2008
                      • 76
                      taz
                      i opened that PSU - 3 bulgers - one vented!
                      TICTAC 619XT Bios
                      • Antonynl
                        What are typical ripple voltages on a laptop motherboard?
                        by Antonynl
                        I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                        So I have two questions:
                        1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                        2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                        Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                        12-09-2022, 06:51 AM
                      • debidoobs
                        RX580 all voltages good but won't boot and fan won't spin
                        by debidoobs
                        Im actually trying to find what is going wrong with my sapphire Pulse RX580 8gb... I purchased it used and supposely dead a year ago and found out (thanks internet) that U1000 (And gate sot23-5) was not giving me the high state to the power management IC NCP8122...
                        At this time, with no spare parts, i decided to put a 1kohm resistor to create the voltage as commented by a guy named Lorkur on this forum (https://*******/viewtopic.php?f=48&t=122873), you ll need to translate it in english.
                        and voila ! the gpu worked again and i didn't care much since....
                        02-11-2024, 02:04 PM
                      • Capacitorial
                        Powersupply has all the voltages - Monitor still no power
                        by Capacitorial
                        Hello guys,
                        I have a Philips 240B7QPJEB. The monitor seems completely dead.
                        I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                        On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                        The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                        The weird thing is, that the Power LED is powered over the TCON board.
                        On The TCON...
                        12-28-2024, 02:12 PM
                      • Zender
                        Power good problem in PSU all voltages seems to be OK
                        by Zender
                        Hi there I just got some Cooler Master mpx-7001-acabw-eu PSU. There is sticker on it so it is not been open ever.
                        It have some power good problem, all voltages seems to be ok, but that PG is 0 and blinking on this simple PSU tester, also when on this tester a PSU let out some strange sound inside it ( I can't record it since PSU tester is whistle and covering that sound from PSU ).
                        When I try to connect a green and black wire on 24 pin connector a fan on PSU just little move and nothing.
                        Here is a video of problem : https://www.youtube.com/watch?v=3cmO8x05...
                        08-08-2020, 11:02 AM
                      • CapLeaker
                        Astron RS-7A/10A not regulating output voltage low
                        by CapLeaker
                        Either I am getting old or dumb, probably both.
                        This “simple” linear power supply is driving me insane. Should be easy, right?
                        Here is the story. Got that Astron RS-7A or 10A as stone dead. I mean turned on and got 0.00V not even an mV on the output. Why dat? Darn electrolytic output capacitor shorted at the binding posts. No, problem… new one in stock and mounted.
                        Turned the PSU on again and now I got 0.1V on the binding posts. Everything clear like sunny day and replaced the LM723 regulator IC in the socket. Had it made, I thought....
                        09-17-2023, 08:33 PM
