Sound issues
  • stevo1210
    • Oct 2006
    • 4156
    Sound issues
    My brother is going to kick my ass soon because his PC decided to be a bitch today. Worst of all, I'm getting the blame because I added RAM to it this morning.
    So the problem is with the sound. It has been fine for months until this morning. The sound card works fine for only a few applications and ironically only Windows applications. Windows media player plays music fine and the windows start-up and shutdown noise etc. are fine.
    But when my brother starts up a game, any game whether it is World of Warcraft or Call of duty 4, it will make this very loud and continuous droning noise until he exits the game. This also happenes when he plays a movie using Nero showtime or whatever else.
    In my opinion I think it's a software issue. I don't think upgrading the RAM from 2GB to 4GB is the issue here.
    The sound card is a Creative Soundblaster 5.1ch PCI, and the internal Intel audio has been disabled.
    Here are the specs of his PC for reference.
    * Intel Pentium Dual Core E2180 CPU
    * Intel DP965LT motherboard (P965 chipset)
    * 4GB RAM (2x Kingston DDRII 800, 1x Kingston DDRII 667 and 1x Corsair DDRII 667) All RAM is in a dual channel config, except running at only 667MHz due to the slower RAM speeds in there.
    * Asus/Nvidia 8400GS 512MB PCIe graphics card
    * Pioneer DVR-109D IDE DVDRW
    * Seagate SATAII 7200.11 500GB HDD
    * Windows Media Center edition 2005
    * Thermaltake Mambo ATX case w/ 12cm exhaust fan
    * Asus/ Delta electronics 350W 24 pin PSU
    * Logitech X530 5.1ch speakers
    * Creative Soundblaster 5.1ch PCI sound card
    * Dlink DWL-G510 WLAN PCI card
    * Logitech Media 600 USB keyboard and Logitech RX300 USB mouse.
    I don't know what's wrong and I need a quick fix before my brother goes insane. I think he looked for drivers for the sound card today for an update and the newest drivers are from 2007.
    Thanks.
  • Scenic
    o.O
    • Sep 2007
    • 2640
    Re: Sound issues
    um... are you using the drivers from Creative or the windows ones?
    i've got a SB Live! Player 1024 and a SB Live! 5.1 ...
    both of them bitch around with the creative drivers, but the windows ones work fine...
    • kikkoman
      • Jul 2007
      • 691
      Re: Sound issues
      increasing the PCI latency to 128 or higher might help.
      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      • stevo1210
        • Oct 2006
        • 4156
        Re: Sound issues
        I use the creative drivers as Windows XP has no drivers for the sound card itself.
        How do i do that? Theres no PCI latency menu in the BIOS, or is it a Windows thing?
        • kikkoman
          • Jul 2007
          • 691
          Re: Sound issues
          it's a bios thing. looks like they abandoned that setting.
          at a quick glance google tells me that the audigy series had problems under EAX with 4gb RAM or more with older drivers, but no word about the older SB series.
          not quite sure if this happens only on 64bit systems or with 32bit too.
          what you can do:
          1) use a different PCI slot and see what happens
          2) remove some RAM (MCE can't use the full 4gb anyway) and see what happens.
          • zandrax
            Hit and miss
            • Dec 2007
            • 1157
            • Italy
            Re: Sound issues
            Creative cards have an long history of troublesome drivers (usually good on Intel chipsets, but prone to crash on anything else) and sensitivity to PCI timings: increasing PCI Latency to at least 64 cycles helped in past to solve skipping audio in both playback and recordings, sometimes even cured BSODs due to driver crashes; however this doesn't seem to be your case.
            Since it works with Windows apps and it's noisy only on DirectX ones (games, Nero, ecc), I suspect the DX config is corrupted or the driver is flawed.
            Some Creative cards don't have an hardware mixer and DX default config is to enable the hardware mixer: games usually crash at first, but you can even get the annoying continuous hum. To solve it, run the Sound card test in dxdiag, reply to all "That's a fake bird chirping sampled at xxx Hz yy bits: did it shatter your eardrums? Yes/No" questions and lastly agree with dxdiag's proposal of switchting to a software mixer.
            If doesn't resolve the issue, look for an updated driver: the 4 GB issue Kikkoman points out is plausible since the card looks an old one and in past drivers were programmed with fixed memory path in mind, usually between 3 and 4 GB (who could run such a sound card and have more than 512 MB of ram on its system?). Additional memory conflicts with these hardwired memory locations and you get troubles.
            If the new driver from 2007 isn't effective, then remove the new 2 GB and check if the problem is present: if not, then you know the reason.
            Zandrax
            Have an happy life.
            • stevo1210
              • Oct 2006
              • 4156
              Re: Sound issues
              I found the latency menu eventually in the BIOS and I increased the PCI Latency timer to 128 from the previous 32. Still no change at all.
              This problem is very strange, after a restart of the PC, I can start a game for a few minutes and then it makes that very loud droning noise. But I can still play music using Windows media player etc. without a problem, so I think Zandrax is right, it's a DirectX issue. Except I don't know how to change it to software mixer to prevent this issue.
              Problem is that I can't really get rid of the extra 2GB RAM my brother bought because it was quite expensive, but I can however remove it for a short while for a test, but it must go back in (Which I will do later). But the computer must have the 4GB he purchased otherwise he ain't going to be happy about it. He is a very heavy duty gamer and that 4GB of RAM is very vital I guess, and the graphics card is going to get the boot very soon as he ordered a 1GB Nvidia 9500GT which shall be coming soon.
              I also tried to install a driver update for the card except it wouldn't accept it and said I didn't have the correct product yet I have downloaded the correct driver.... I even double checked the model of the Creative card as being a (SB0060 model number) Sound blaster Live! 5.1 PCI, exactly like this one .
              Thanks.
              • stevo1210
                • Oct 2006
                • 4156
                Re: Sound issues
                Oh, and I can't find a way to remove the Creative driver/software in the add/remove programs menu which is a worry as I need to get rid of them for troubleshooting.
                • stevo1210
                  • Oct 2006
                  • 4156
                  Re: Sound issues
                  I finally found the application in add/remove programs. For a short and temporary time my brother will use the onboard Intel audio until I can find a fix for the sound card somehow.
                  • Wizard
                    • Mar 2008
                    • 2296
                    Re: Sound issues
                    Stevo, DUMP the creative! And find alterative audio card.
                    And, cut your brother's pc back to 3GB if you can find pair of *matched* pair of 512MB sticks at DDR 800, NOT DDR 667. This is doing really stupid mixing the 2 different sticks in a bank, really asking for trouble.
                    I do not recommend keeping using older creative audio cards too long, they seems to be FIXED to specific eras and trouble some. I dumped them when I could not use 98 with a live! 512. crashed the 98 when intializing the audio card.
                    Cheers, Wizard
                    • bgavin
                      • Jan 2007
                      • 1355
                      Re: Sound issues
                      DPC Latency Checker
                      Check your DPC latency with the above tool. It is a standalone .EXE and does not install anything on your machine. It is part of my standard audit package.
                      This tool will tell you if you have DPC problems that will causing skipping and stuttering. Use it as you disable services to find the offending driver.
                      As noted above, the mismatched memory is a bad thing. Dual-channel memory timings are blisteringly fast, so you are well advised to match your ram. I will not mix different stick models in the same machine, nor will I ever mix different manufacturers.
                      I run 2x2gb in my primary workstation, and simply throw away the 0.6gb that XP cannot access. I have four slots, but choose to run two sticks. I've seen too much chatter about 4 sticks causing subtle problems.
                      24 hours of MemtestPlus should pass error free.
                      It's always a good idea to check your temps, too.
                      HW Monitor is from the author of CPUID, and it works well.
                      Creative Drivers have always been junk. Numerous tests with bus sniffers reveal they are bus hogs and do not play nice on a shared PCI bus.
                      • stevo1210
                        • Oct 2006
                        • 4156
                        Re: Sound issues
                        I managed to get the thing to run "OK" but now I only get sound through two front speakers because I haven't installed that 'special' Creative software. I only installed the driver through device manager and now it seems to be fine in games. But um, I now know it's a software glitch somewhere down the line. Now I just have to figure a way to make the 5.1ch sound option work.
                        • sofTest
                          • Aug 2008
                          • 361
                          Re: Sound issues
                          If I remember correctly, the MCE your brother got are 32-bit, and the memory of all the devices will be located below the 4 GB limit. When your brother get his 1 GB video card, that will reduce the usable memory to 3 GB. All the other devices might use another 512 MB. As you can see, your brother might end up with 2.5 GB usable memory for programs anyway. If you got to pull 2 GB from the system to solve your sound problem, there might not be much of a loss.
                          Be a mensch
                          • stevo1210
                            • Oct 2006
                            • 4156
                            Re: Sound issues
                            Yeah the Windows MCE is 32 bit and can only see 3.25GB of RAM. If I pull out 2GB can have remaining 2GB, isn't that less than the 2.5GB you specified?
                            • jpdoe
                              • May 2007
                              • 237
                              Re: Sound issues
                              I would think the video card memory would be addressed through PCI registers, not trough the regular memory address bus.
                              In the interest of full disclosure, I don't fully understand the 3GB limit of 32bit CPUs. IIRC, it would seem the actual limit can be between 2.75GB and 3.5GB, depending on the motherboard/chipset/cpu combination.
                              • sofTest
                                • Aug 2008
                                • 361
                                Re: Sound issues
                                Yes less, but probably not noticeable. Please note the exact memory available depends on which and how many devices there are in the system.
                                Be a mensch
                                • sofTest
                                  • Aug 2008
                                  • 361
                                  Re: Sound issues
                                  Actually, maximum memory available for programs can even be below 2 GB in a dual video card system. The memory "loss" on 32-bit Windows systems, is very well described in this link.
                                  Be a mensch
                                  • sofTest
                                    • Aug 2008
                                    • 361
                                    Re: Sound issues
                                    I just remembered the KX Project. They develop an independent driver for many Creative-cards. I tried their driver a few years ago on my SoundBlaster Live! Platinum card, but I uninstalled it as it didn't support all my needed outputs on the card. It seem to still being developed. My be the driver fits your needs?
                                    Be a mensch
                                    • kikkoman
                                      • Jul 2007
                                      • 691
                                      Re: Sound issues
                                      the kXproject drivers are great and i've been using them for years. awesome if you do audio stuff.
                                      since stevo's brother seems to be into gaming, they may not be the best choice though. --and overkill as well.
                                      the biggest issue is that EAX is only partially supported.... most games work fine but i've seen a few that required the original driver. swapping drivers is not a big deal, but could be annoying to stevo's bro.
                                      • jpdoe
                                        • May 2007
                                        • 237
                                        Re: Sound issues
                                        Thanks for the link, sofTest.
                                        • jjne
                                          Yamaha RX V675 sound issues
                                          by jjne
                                          I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
                                          From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
                                          At first I thought it was either a speaker relay or the DSP, but I don't think...
                                          06-24-2025, 07:01 AM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • acedogblast
                                          Marantz SR5012 popping and other sound issues
                                          by acedogblast
                                          Hello I have a Marantz SR5012 7.1 AV receiver that is producing speaker pop and other sound issues. These sounds are coming out of all connected speakers regardless if they are configured to be used. The rca preouts are clean from these defects so I am assuming the problem has to be with the amplifier.
                                          These sound issues are random and unpredictable. There are times where the unit can go 10 minutes without any problems then suddenly the problems come back. It doesn't seem to matter if there is sound being played or not.
                                          I have disassembled the unit and was able to take out the...
                                          02-15-2023, 01:40 PM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • i19
                                          Asus UX3402 / Q409Z - No sound, no TPM, Boot issues: Bios flash?
                                          by i19
                                          Hi
                                          I got an Asus UX3402 / Q409Z and after a BSOD I lost sound, tpm 2.0, and if it turns off it can take HOURS before I can boot again.
                                          Reading here and on reddit I figured its a BIOS issue, and that reflashing it may fix the problem.
                                          I want to use an CH341A (new model with 3.3v) to flash it.
                                          My problem is that I'm not sure if the SOIC8/SOP8 clips will attach to the chip and hold properly? (haven't opened my laptop yet, I'm basing this assumption on a picture from the same thread I attached).
                                          Any tips on how to connect to it? Maybe something...
                                          08-20-2024, 06:50 AM
