PSU choice - is this GOOD?!
    http://www.aria.co.uk/Products/Compo...roductId=27381
    been doing some thinking on new PSU
    is this going to be stable voltage? is this a good PSU?
    the one i have now fluctuates too much
    DFI Lanparty NF2 Ultra B
    TICTAC 619XT Bios
    AMD Athlon XP-M 2600+ FQQ4C IDYHA I-Stepping
    Speeze Vulture spin 3 Heatsink and Fan
    2x Mushkin XP4000 1024m DDR500 (1:1) @ 2.5-3-2-8 1T
    GeForce FX 5700 256m
    Zalman VF900 CU GPU cooler
    Skyhawk 400W Aluminium psu
    Sharkoon Silent Eagle 1000 case fans
    Re: PSU choice - is this GOOD?!
    PC power and cooling is always a good choice. They have industry leading voltage stability.
      i still don't trust PCP&C... dunno why...
      i'd go for the Corsair HX520 V2 instead (Seasonic OEM)
      allthough it's "a little bit" overkill for that sys in your sig..
      i'm running a XP3000+ on a nForce2 board (Asus A7N8X) with 1,5GB RAM & a FX5900 Ultra on a 300W Fortron Source lol
        Is that a good PSU? - yes it is. But I wouldn't recommend buying it for the system that's in your sig. Socket 462/A are +5v based which means the CPU gets its voltage from the 5v line. New computers, as in P4 class and newer pull juice from the 12v line.
        A Sparkle PSU (Power Q series) will be much more proper for your system. 250-300 watts should suffice.
          I've seen several socket A motherboards with the 4 pin Pentium4 PSU connector. That would make them 12v based.
            i just checked that.. this board does have a P4 connector...
            http://www.firingsquad.com/hardware/.../images/01.JPG
            but still... 520W for the Corsair or 610W for the PCP&C is just overkill for the sys in his sig... o.O
              Jpdoe is right: the Lanparty NF2 Ultra B has a P4 connector, so it's 12 V based and any recent, good psu will work.
              I'm with Scenic: PC P&C is good but uses crap caps (you pay an above average price for the brand, not for premium components) while the Corsair HX520 is a Seasonic design with premium caps for the same amount of money. I'd have suggested a less powerful (and cheaper) psu too since anything above 300-350 W is an overkill, but the shop offers only a narrow choice: the Corsair CX400 is nice but secondaries are Teapos , IIRC OCZ psus are manifactured by FSP (again Teapos, OSTs and C[r]apXons), I don't trust Thermaltake because every product is different from others (the number of OEMs involved and wide range of quality in TT's products amaze me) and I can't spot the VX450 or another known product usually available at about £45-50. Pity.
              Zandrax
              Edit: Scenic caught me
              Have an happy life.
                The Asus A7N8X family is +5V-based.
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                  thanks
                  i used a PSU calculator to weigh up my next build...
                  so the 600W will be not wasted as i would transfer it into a new system eventually
                  ijust want a good solid PSU that could be "futureproof" ( i hate that term lol)
                  TICTAC 619XT Bios
                    The Intel Platform Design Guide for the i810 chipset 'recommended' that CPU power come from +12v but the 4-pin "P4" plug wasn't required yet.
                    Most manufacturers left CPU power on +5v because they wanted their boards to be compatible with older power supplies.
                    They didn't want to have to say say "If you upgrade to *OUR* P3 board then you *HAVE* to buy a new power supply too." ,,, when motherboards from other manufacturers didn't have that requirement.
                    Though I don't personally know of any, it's quite possible P3 boards exist that power CPU from +12v. If there are they still wouldn't likely have the "P4 plug".
                    I imagine the point of that transition on the AMD side was just as foggy with manufacturers holding off on switching to +12v until PSU's with the plug were more common.
                    My reference: See figure 4-1 in this.
                    [File is too big to attach.]
                    Mann-Made Global Warming.
                    - Dr Seuss
                      In the drawing what I was talking about look at where VRM power comes from.~~~
                      There is another interesting fact hidden in that drawing.
                      Look at RAM power.
                      It comes from both +5v and +5vsb via the "5v Dual Switch" and "3.3vsb Regulator."
                      That's how bad caps in +5v or +5vsb can cause RAM problems.
                      - Dr Seuss
                        Look at RAM power.
                        another good one is the abit vp6.
                        rather than get +3.3 from the psu for nb and vdimm they buck down from +12.
                        maybe they wanted better regulation than the psu's of the day offered?
