New DVD drives
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    #41
    Re: New DVD drives
    well lately i got
    LG GH22NS30 sata and Sony NEC Optiarc (umm who made it) AD-7203A ide
    seem ok so far
    the nec is just over 2mm less width than normal which is a bit wierd
    • guy_fixit
      sony VGN-G2 no USB drives
      by guy_fixit
      I have here a Japanese market Sony VGN-G2ABNS. By the specs this ultaportable laptop is very similar to a Sony VGN-TZ series but with a 12 inch XGA display. U7700 cpu, 945GMS chipset, 1 to 2 GB DDR2 RAM, 1.8" pata-ZIF hdd, etc. As received it came with windows 10 - Japanese language. After I noticed my problem I swapped in a TZ hdd with winows 7 pro 32 bit.
      The problem I have with it is most USB devices do not work on it. Plug in a mouse or keyboard to either external port and that works fine. Any other device, either internal or plugged in will not work. Windows says "there...
      01-01-2024, 01:17 AM
    • Carlos#2003%
      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
      by Carlos#2003%
      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
      02-15-2024, 07:52 PM
    • dkneyle
      Sony KDL-46HX850 Can't upgrade/update firmware
      by dkneyle
      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
      09-25-2024, 10:44 PM
      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-06-2024, 05:27 AM
    • eccerr0r
      It's 2025: do you know where your 5¼" floppy drives are?
      by eccerr0r
      Oh wow.
      As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
      Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
      Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
      Weird. Seems the PC drive is having trouble clamping...
      07-07-2025, 12:49 AM
