3G Ram and software
  • Gianni
    • Jul 2008
    • 681
    • Italy
    3G Ram and software
    my brother is working on a new Toshiba laptop and phoned me to have some explanations because he is facing some problem:
    1) Hiren's Boot CD (8.3) works on system with 3GB Ram?
    2) Acronis True Image 11 works without installing it on the system?
    Till now I have never worked on system with more than 2GB Ram so I don't know if with 3GB Ram some software could have problem but seems that my brother is not able to use them on this Laptop due to large memory.
    I use Acronis and Hiren's 9.5 without problem just booting the PC from CD drive.
    Anyone here knows if this memory larger than 2GB can create problems with these tools?
    I'm going to visit my brother and within 3 hours I will be able to give more details.
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: 3G Ram and software
    acronis you install on one pc and then run the "bootable rescue media builder" to make a boot cd to use on any pc
    i doubt 3gb is making any issue with software.
    • Gianni
      • Jul 2008
      • 681
      • Italy
      Hi willawake
      you are right the 3GB is not a problem.
      My brother was trying to make a system image for recovery and Acronis was unable to find any partition.
      I entered the BIOS set up and I switched the SATA support from SATA AHCI to SATA compatibility.
      In this way Acronis had no problem at all to see the HD partitions.
      I was not able to run any application from Hiren's Boot CD because after choosing the application from menu, Hiren's was unable to install a working CD driver.
      The Laptop is Toshiba Satellite A300.
      I found the problem with SATA bios setting last month when I reinstalled an XP on a Compaq Presario C500, with SATA native support enable WindowsXP installation CD was unable to see the HD.
      By the way, the first partiton in Toshiba HD was an unknown EISA partition, about 1.46GB, what is it?
      I think it is something for system recovery but it is too small to contain a complete restore image for Vista.
      Ciao
      Gianni
      H. J. Brown
      • zandrax
        Hit and miss
        • Dec 2007
        • 1157
        • Italy
        @ Gianni: the 1.46 GB isn't a Vista restore partition since the notebook is supplied with a recovery cd. It's full of programs copied by Toshiba Applications Installer after the restoration. Unless you want to get rid of it, do no touch that partition.
        Zandrax
        Have an happy life.
        • Gianni
          • Jul 2008
          • 681
          • Italy
          Thanks zandrax
          my brother left the partition like it was, he needed only to make a restore image. There's no sense to free 1.46GB on a 250GB HD, there's plenty of free space without risking to delete something that could be useful.
          Ciao
          Gianni
          H. J. Brown
          • i4004
            • Oct 2006
            • 2029
            why use that crappy dossy crap hiren if you can make ubcd4win?
            that way you boot to win, although yeah, it's slow....
            i also had the same problem with hiren: it' can't even fuckin' have the cd driver recent systems need....
            i should make a post on integrating acronis 11 to ubdc4win in VIP section of the forum...
            if i do, zandrax can inform you about it...
            • i4004
              • Oct 2006
              • 2029
              oh...you can see that section too, so...
              • Gianni
                • Jul 2008
                • 681
                • Italy
                Thanks i4004
                I have see UBCD4WIN some days ago and I had no time to give it a try.
                It should be a good replacement for Hiren's since lately I had some problem to use it.
                I don't know the right reason but I had problems with Hiren's and the CD Driver with 2 PC, I had to remove the HD and connect it to my PC to do some operation.
                Yesterday the problem with Toshiba... it's getting annoying especially when you have not much time.
                Now I download all stuff and I will try to create a working CD.
                Ciao
                Gianni
                H. J. Brown
                  Copy DMI info easily with Hex editing software and Macro script
                  by SMDFlea
                  Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                  Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                  02-28-2023, 02:14 PM
                • NeedsPractice
                  Backup To OneDrive Software? Everything! Best Software?
                  by NeedsPractice
                  I contacted Microsoft and they said they do not have software to where you could backup all your files to one drive. I mean you can copy some of your files to your one drive folder and back stuff up. However, it does not do this automatically.
                  I have around (10) hard drives I want to backup to the cloud with One Drive. What is the best software to do this with?
                  AOMEI Backupper
                  I Drive
                  Easeus
                  I do not want a Cloud Plan. I just need the software to take my DATA and Transfer it to the cloud in a nice, readable, viewable fashion. I wish...
                  02-04-2022, 06:04 PM
                • bseinfo
                  Brother MFC-J480DW printer stuck in maintenance mode
                  by bseinfo
                  I have a Brother MFC-J480DW printer stuck in maintenance mode (BHL2 USB Maintenance). The screen only shows white bars, and it’s completely unresponsive. The official Firmware Update Tool doesn’t detect it, and I’ve tried multiple versions.
                  I’m looking for the raw firmware file LZ5313_L.blf (or .djf), compatible with FILEDG32.exe, so I can attempt a manual recovery.
                  If anyone has a full dump of this model (or a compatible one like MFC-J485DW or J885DW), or knows a private Discord or Telegram group where this kind of firmware is shared,...
                  07-05-2025, 10:53 AM
                • BMCappelletti
                  iMac fan ramps up after shutting down. Software? SMC? FET?
                  by BMCappelletti
                  Hi everyone.
                  There are some topics here (also on a lot of other places) regarding this issue, but I believe none has a definitive answer. At least I didn't see anyone saying it really worked for them.
                  In my case I have an iMac A1418 (late 2012) that the fan goes full blast (or at least ramps up the speed) after going to sleep or turning the computer off.
                  It's not a software issue, cause it was formatted and it happens with any MacOS version I test.
                  At some places people say it would be an issue with the S5 rail. Others say it's the S0 rail. And some others say it's an SMC...
                  01-17-2025, 08:11 AM
                • Russ17
                  JVC LT-55C870(B) Corrupt Software??
                  by Russ17
                  I have a JVC LT-55C870(C). All that happens upon applying power is the red led flashes slowly (1Hz).
                  If I hold the OK on the remote while powering on, the led flashes at 2Hz, but without a USB Device attached, it obviously does nothing, no screen or backlight.
                  Any thoughts on this being corrupted software?
                  Owner says the TV experienced a power surge.
                  If software is a possibility, can someone point me in the right direction to download the correct software. Is there a procedure to force software to load from USB?
                  10-10-2023, 12:34 PM
