Freezing when something plugged in, and wiping MBR's
  • Wizard
    • Mar 2008
    • 2296
    Re: Freezing when something plugged in, and wiping MBR's
    Get prime95 and run torture mode. It is a excutable files only so it does not install into windows itself. So it is safe test to perform. I use this to confirm the hardware are stable.
    Cheers, Wizard
    • i4004
      • Oct 2006
      • 2029
      >Service Pack 3 and MS dual core patch.
      what the hell is "dual core patch"?
      2nd core not working without patches from ms?
      oh no you don't!
      • Fizzycapola
        • Oct 2006
        • 423
        Theres plenty to unhappy stories if you type it in google.
        Nearly all updates make things worse in my findings.
        First Geforce 6 driver was the most compatible and fastest.
        Early Geforce 2 driver was most compatible and fastest.
        It may not even be a conincidence that patches make things worse. But if you want a job in IT you probably will already know you're not meant to admit that truth. That and nobody needs a CPU faster than 8Mhz.
        Rubycon Rubycon Rubycon
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Sounds like a bad power connection or HDD data cable connection.
          My MSI 845 E Max did that sometimes, but not partition corruption like you're describing, it just locks and and thus required to hard shut down.
          Has done that before when I just tapped the left side of the case.
          Seems to do alot better when I unplug the all the power connectors and IDE connectors and replug them back in.
          It may be the modular power connectors on my Antec SmartPower 2.0 500 W PSU.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • Fizzycapola
            • Oct 2006
            • 423
            Thats a good point that hasn't been brought up.
            I replaced the standard SATA2 ones with with branded ones. Still I've told him to stop trying to hot plug eSATA devices. His docking station has these warnings all over the box.
            • CornholioGSM
              Macbook Pro 15" 2018(820-01041-A) Freezing, Rebooting, Kernel Panics but only with connected Battery
              by CornholioGSM
              I have here one interesting problem.
              Laptop comes to me with freezing and rebooting problem. All inside was relatively clean and no water damage. Only visible problem was one swolled cell on battery...all was looking like batt problem.
              I have put inside new - not original batt, but problem with freezing still. I am able to boot into os, then pc can run few seconds, then freezes and reboot and reboot until force power off.
              Quickly i am able to see battery information...batt is detected normally in os with power cycles hours...
              06-25-2024, 12:27 PM
            • FShahid
              Dell Inspiron 7520 (Intel/AMD) LA-8241P Freezing Issue
              by FShahid
              Hi I have Dell 7520 which has i7-3632QM as well as AMD 7730M Discrete Switchable GPU.
              This is BACO Switchable meaning the AMD GPU can only "render" and cannot work as alone as it depends on iGPU for output.
              Attached is the datasheet for LA-8241P which shares common with Inspiron 5520 and Vostro 3560. Link to Schematics: https://cdn.badcaps-static.com/pdfs/...a856347d78.pdf
              The laptop has worked flawlessly for last 9 years, with CPU temps never exceeding 90*C and GPU barely reaching 80*C on gaming/full load.
              Since...
              04-26-2022, 04:41 PM
            • martin83
              Asus Rog G513qr Freezing
              by martin83
              Hello everyone.
              I am here to ask for help identifying a problem with an Asus Rog G513qr, Ryzen 9 5900x and RTX 3070.
              The laptop turns on but turns off or freezes when connecting a USB flash drive (even during the ROG logo). Even without using the USB ports, the laptop is unstable and when the charger is disconnected, it freezes.
              A few months ago, the laptop started freezing when powered only by the battery and in power saving mode.
              After replacing the NVME disk and replacing the liquid metal, thermal grease and thermal putty, it got worse and...
              06-11-2025, 12:35 PM
            • DarkAngelz195
              ASUS ROG SCAR 16 (G634J) - intermittent freezing
              by DarkAngelz195
              Hi guys, this is my first post on here so please be gentle.
              I have this ASUS ROG SCAR 16 - G634J laptop that keeps on freezing intermittently, showing a red blinking battery light, resulting in a frozen screen, unresponsive keyboard, only a hard reset will bring it back on. I will say that due to the frequency of it happening now it is really hard to try to load up any monitoring software etc.
              Now here is the thing, I have seen at least 5-6 posts around on reddit and ASUS's official forums with individuals all having this exact issue. My bet is that its something to do with...
              10-15-2024, 04:43 PM
            • Marian.Bella
              Pioneer sph-da160dab Freezing, reboot and white screen
              by Marian.Bella
              I have car radio Pioneer sph-da160dab. Currently freezing, restarting and as the last stage of dead is white sceer with colored vertical lines. LCD is ok. Latest firmware applied.
              Any ideas ? Warranty is not possible due to second hand buy.
              Thanks.
              09-17-2023, 03:47 AM
