Freezing when something plugged in, and wiping MBR's
    Re: Freezing when something plugged in, and wiping MBR's
    Get prime95 and run torture mode. It is a excutable files only so it does not install into windows itself. So it is safe test to perform. I use this to confirm the hardware are stable.
    Cheers, Wizard
      >Service Pack 3 and MS dual core patch.
      what the hell is "dual core patch"?
      2nd core not working without patches from ms?
      oh no you don't!
        Theres plenty to unhappy stories if you type it in google.
        Nearly all updates make things worse in my findings.
        First Geforce 6 driver was the most compatible and fastest.
        Early Geforce 2 driver was most compatible and fastest.
        It may not even be a conincidence that patches make things worse. But if you want a job in IT you probably will already know you're not meant to admit that truth. That and nobody needs a CPU faster than 8Mhz.
        Rubycon Rubycon Rubycon
          Sounds like a bad power connection or HDD data cable connection.
          My MSI 845 E Max did that sometimes, but not partition corruption like you're describing, it just locks and and thus required to hard shut down.
          Has done that before when I just tapped the left side of the case.
          Seems to do alot better when I unplug the all the power connectors and IDE connectors and replug them back in.
          It may be the modular power connectors on my Antec SmartPower 2.0 500 W PSU.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
            Thats a good point that hasn't been brought up.
            I replaced the standard SATA2 ones with with branded ones. Still I've told him to stop trying to hot plug eSATA devices. His docking station has these warnings all over the box.
