Changing HDMI displays can change your default audio device
  • japlytic
    • Oct 2005
    • 2086
    Unlike DVI, HDMI can also carry digital audio, and when I changed a display using the HDMI input on a connected PC, the default audio playback device changed to the display under Windows 10 - this happened on changing a display to one without any audio output including headphone, and certainly on one with a headphone output and/or inbuilt speakers.
    So no audio on changing your display? Check the default audio playback device selection.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8223
    Re: Changing HDMI displays can change your default audio device
    ...IF audio via HDMI is enabled and the HDMI cable is the right one. Not all HDMI cables carry audio.
    • japlytic
      • Oct 2005
      • 2086
      Audio and video is carried on the TMDS lines on the HDMI interface and the data stream has ID filters; the other lines (CEC, DDC, Ethernet, Hot Plug Detect) are not used for audio.
      • samson7point1@yahoo.com
        Help troubleshooting an audio problem with an RCA SGT-250 CED Player
        by samson7point1@yahoo.com
        The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
        The player processes the audio signal using two different reference frequencies. The "R"...
        04-30-2024, 11:22 AM
      • aliougm
        Marantz SR4003 AVR HDMI board issue, seeking for help
        by aliougm
        I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
        Connection as below:
        Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
        If I bypassed AVR then HDTV screen color be good.
        I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
        3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
        I replaced all...
        04-30-2022, 12:21 PM
      • i_am_patch
        Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
        by i_am_patch
        Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
        04-30-2024, 08:20 PM
      • spleenharvester
        Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
        by spleenharvester
        I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
        I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
        03-12-2025, 03:42 PM
        DELL Inspiron 3668 Inspiron 3000 i7-7700 Specification for Upgrade or Repair
        This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
        09-12-2024, 03:36 PM
