USB woes: crashing, noise, bsod, wiping devices, destabilising, causing random input.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: USB woes: crashing, noise, bsod, wiping devices, destabilising, causing random input.
    You are knit picking at nothing.
    If you take things in context in the first place you wouldn't get so lost.
    Mann-Made Global Warming.
    - Dr Seuss
    • jpdoe
      • May 2007
      • 237
      Sorry for my lack of clarity.
      I don't really remember the actual instructions I read some years ago.
      In a few days, when I'm not half sleep as I am now, I'll make an independent thread with a more detailed post.
      Thanks for your answers.
      • Fizzycapola
        • Oct 2006
        • 423
        Originally posted by zandrax
        @ jpdoe: like arneson wrote, screening means shielding. Cheap cases use unshielded cables or "selfpromoted tecnicians" [euphemism for those barely capable of putting a motherboard into a case] don't connect the shield to the ground pin.
        @ fizzy: I read only now you've troubles with a laptop: forget the unshielded cable thing.
        Did you try connecting the devices to a powered hub?
        Zandrax
        That sounds like a good idea for testing purposes Zandrax. Though I'd rather not have to buy one of those if it can be helped. ( I think I'd rather buy some low latency ram instead for the same money hehe)
        I wonder would it not be possible to make a passive filter instead using the smoothing power of Oscons. Something simple like penetrating the rear cable of the port inside the laptop and sneaking a few Oscons in, then seal up with liquid electronic sealant and shrink rap it to seal all oxidisation opportunity.
        In the case of devices acting as antennae, by their leads, perhaps I will be more generous with my ferrirtes here. Alternatively, cannabalising unused screened cable. I could rehouse most of my device usb leads in a double layer screening and solder it at the socket entering end to the metal shroud. ( or not?)
        Let me know if any of those ideas sound feasible.
        Rubycon Rubycon Rubycon
        • i4004
          • Oct 2006
          • 2029
          you can be so fuckin' dense at times.
          it's just not possible for you to be wrong, is it?
          first of all you've read it in a wrong way, and then you've said only floating ground can cause g.loop, and now i'm lost?
          i'm not nitpicking, it's what he said. it IS the context.
          also, the complete answer is weird:
          "What you are talking about is called 'floating grounds' [ground is not at earth ground].
          That should not happen in a PC unless there is already a fault."
          what should not happen?
          floating ground will happen anytime electric installation of the place is not grounded.
          so again, floating ground and ground loop are not the same thing.
          and mistaking one for another doesn't make things any clearer.
          and i want them clear because it's interesting subject and as i had a particular weird case recently, one that i'll probably document here.
          perhaps in the jpdoe's new thread.
          so i allow only good data on ground loops on this forum.
          <wink>
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Of course I can be wrong. - But not this time...
            A floating ground describes a circuit where the the ground's voltage is above earth ground.
            [Greater than zero volts to earth.]
            If you connect the ground on a circuit with a floating to the ground to a circuit with an earth ground (or to a floating ground at a different potential) then you create a current path. - That current path is called a ground loop.
            And like I said.
            If you could keep things in context you wouldn't get so lost.
            - Dr Seuss
            • zandrax
              Hit and miss
              • Dec 2007
              • 1157
              • Italy
              #26
              Matter of priorities: which do you feel more urgent between a working USB connection or slightly faster ram?
              [/QUOTE]I wouldn't open the notebook if still under warranty and I couldn't help you in any way in smoothing the signal. IMHO putting ferrites on already shielded cables is a better experiment to carry: try savaging them from old VGA cables.
              Zandrax
              Have an happy life.
              • arneson
                • Sep 2005
                • 1267
                #27
                I have to deal with multiple grounds when installing shipboard systems.
                The DC neg grounds can be 12v 24v and 32v all on one panel.
                Then next to this will be a panel with 120vac neutral and 120vac ground, not to be confused with rf ground or sea water ground or bonding system.
                There are times when cables must be connected to ground only at one end and other times when extra grounds from chassis to device have to be added.
                I've put in radar antenna cables that have three large ferrites and an 8awg strap from the array case to the arch.
                I read one manual that calls for the grounded cable shield to be connected in Canada and not connected in the US.
                Grounding and ground loops can be tricky stuff, even more in a lightning environment.
                Jim
                • i4004
                  • Oct 2006
                  • 2029
                  #28
                  If you connect the ground on a circuit with a floating to the ground to a circuit with an earth ground (or to a floating ground at a different potential), or if you connect circuit with ground at one potential to a circuit with ground on another potential then you create a current path. - That current path is called a ground loop.
                  there , i corrected it for ya.
                  if you're suggesting ground with potential that differs from some other ground(ground at 0v...but what ground is perfectly 0? gold that goes straight to center of the earth?) can be called "floating ground", that's where you're wrong.
                  floating ground HAS NO CONNECTION to ground.
                  grounded points do, no matter what's the resistance between circuit vs. "good ground" and circuit vs. "bad ground".
                  got it? when something is grounded (even badly grounded) it's not floating anymore.
                  floating ground essentially means "no ground".
                  you're wrong in thinking only floating ground can produce g.loop condition.
                  two grounds at different potentials can do too.
                  • kikkoman
                    • Jul 2007
                    • 691
                    #29
                    where's your fucking problem, guys?
                    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Thanks for the mis-correction i4004.
                      You made it redundant by saying the same thing twice.
                      kikkoman
                      i4004 and I are playing.
                      If you don't wanna play too then don't jump in.
                      - Dr Seuss
                      • i4004
                        • Oct 2006
                        • 2029
                        #31
                        yes, if we don't mind, i don't think anybody should...hehe...
                        anyway
                        "A system where the system ground is not actually connected to another circuit or to earth (though there may still be AC coupling) is often referred to as a floating ground."
                        http://en.wikipedia.org/wiki/Ground_...d_versus_earth
                        bonez, it's not good if you have definitions only you know about...
                        hehe...
                        • tony359
                          by tony359
                          11-28-2023, 05:18 AM
                        • MegaZAC
                          Onkyo TX-SR805 noise in one channel
                          by MegaZAC
                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                          There's some logic behind it. As soon as I select an input I get only left...
                          04-23-2025, 10:09 PM
                        • courtcircuit
                          Philips HTS8000 home cinema noise problem
                          by courtcircuit
                          Hello
                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                          Removed each of tyhe boards
                          02-08-2025, 08:22 AM
                        • guyandpit
                          Asus tuf fa507r BSOD
                          by guyandpit
                          Hi there! Need help! its been 2 months finding the cause of BSOD ntoskrnl and other error, this has water damaged before no power, i replaced sio and pwm control for gpu and cpu. It will boot 3 times in BSOD before succesfully boot in windows. I done stress on cpu, gpu and ram no errors found. Any opinion guys with same exprience? Thank you see attached bsod error
                          05-09-2025, 11:46 PM
                        • alambrose
                          LG GRAM random bsod SOLVED
                          by alambrose
                          LG Gram 15Z980 picked up on Ebay for $200 (was sold as parts because no M2 drive and bios pw locked), but otherwise intact and working.
                          Threw a 500gb M2 in, and was able to install Windows. On Gram, Win activation is stored in the bios, so Windows was automatically activated. I still kept getting random bsod's. Also bought a pw and unlocked the bios.
                          Upgraded Windows to 11, still didn't solve the random & frequent bsod's. Cleaned & reseated all cables, RAM, etc... still getting frequent bsod's. Bought & installed a new stick of RAM, still getting frequent...
                          02-12-2023, 06:12 PM
