Pimp my drive
  • pentium
    • Mar 2006
    • 2778
    Pimp my drive
    I have always wanted to have a hard drive that not only worked bu also had a window in it.
    Well, two dremel grinding discs, a cd case, some hot glue and a hard drive later I had an old 3Gb WD Caviar drive that was exactly that: A hard drive with a window.
    It's not really pretty (it was a test job) but after all was said and done I popped the drive in a computer and threw every test I could at it to see if I had gotten dust on the platters. So far it has passed everything I have thrown at it. No errors. Nothing!
    Hmm, If this keeps up, I should buy a few SATA drives off ebay and to the same but also buy one of those plexiglass cases so that not only can you see the inside of your computer but also the inside of the hard drives! While I am at it, I should also do the same to the optical drives as well!
    Find Nedry!
    Check the Vending machines!!
  • pentium
    • Mar 2006
    • 2778
    Re: Pimp my drive
    Just realized something.
    The bastards left two whole platters unused and sold it as a 3Gb drive.
    Find Nedry!
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Re: Pimp my drive
      They do that all the time.
      The extra platters failed testing so they disabled them in the firmware and sold it as a smaller capacity drive.
      Mann-Made Global Warming.
      - Dr Seuss
        master hoarder
        • May 2008
        • 12170
        Re: Pimp my drive
        It looks great, especially for a quick job like this
        Now add in a few LEDs and it would be complete .
        • Roadkill203
          • Oct 2008
          • 68
          Re: Pimp my drive
          Maybe some ground-effects, too...
          • pentium
            • Mar 2006
            • 2778
            Re: Pimp my drive
            I was thinking of doing that (just barely have the room) but decided against it as I have this thing with adding leds to computers.
            Find Nedry!
            • federalhouse
              **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
              by federalhouse
              I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
              **Background:**
              I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
              **What I've Tried So Far:**
              1. I accessed
              08-01-2024, 07:03 PM
            • tmcw
              PC case - Hard drive rails
              by tmcw
              A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
              So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
              I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
              Now, the case is a CiT Gaming Case, and...
              05-22-2022, 12:04 PM
            • madura2010
              DAY11AM6E0 hard disk drive and optical disk drive not detected
              by madura2010
              Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
              i checked the connectivity of ribbon=good communication with hard and motherboard
              changed hard disk and checked=3f0 error persist
              sata power=+5v available
              Then checked data capacitors=all good
              Then checked data lines path connectivity to pch=all good
              reflashed...
              03-12-2023, 09:09 AM
            • ash91
              Hp pavilion 15 not detect hard drive
              by ash91
              Hello gentelmen .... this is my first post and sorry for my bad english,
              so my proplem is my laptop keep losing hard drive even if i but the
              hard disk in the cady (the box that can replace the dvd rom with hard disk)
              when i turn the laptop on the massage that said no boot media found pop on
              the hard disk is fine and to be sure i try another hard
              i also update my bios to the last update
              the 5 volt is present on the hard connector on the motherboard
              the dvd rom work fine when i but a windows dvd in it
              also when i boot from flash...
              06-07-2023, 01:45 PM
            • karto95
              Repairing a Seagate hard drive with damaged logic board
              by karto95
              I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
              I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
              If anyone has any suggestions or experience with this...
              03-21-2023, 04:05 AM
