iMac PIN code woes
  • stevo1210
    • Oct 2006
    • 4156
    iMac PIN code woes
    Hi Everyone,
    Been a very long time since I've done computer troubleshooting, so I've hit a problem.
    I've got a 27" 2011 model iMac here which was working all fine and well until; one night it decided to lock itself, displaying a 4 digit pin box. I didn't do anything and this has just decided to appear itself.
    After some googling, it appears the computer has been iCloud locked from a remote device such as an iPhone. I'm pretty sure I haven't touched iCloud since I got the computer.
    I purchased it six months ago from a second hand electronics store which refurbishes ex lease computers etc. I have all the proper documentation that came with the computer as well as a purchase receipt from this electronics store.
    So I figured the best way was to go to Apple themselves because I don't want to permanently lose my data on the computer. I turn up with the iMac for a meeting a technician/Genius and they tell me... sorry we can't help because you don't have a proper receipt from an AUTHORISED RESELLER. I asked about my data and I was told that they couldn't help me either... best option was to buy a new iMac.
    Not the happiest at the moment about this, but is there any fix to get the computer to even work again?
    Thanks.
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    Re: iMac PIN code woes
    Wow, just wow. Welcome to the 21st century I guess. I'm getting mighty disgusted with businesses these days. Tracking your every thought, selling garbage that locks itself up capriciously. I had a printer tell me it couldn't print anymore because it was worn out and to buy a new one. It printed a perfect page before it locked itself up.
    I sure hope one of the real genius's here can help Stevo.
    sigpicThe Sky Is Falling
      • 31199
      i suspect you will need to put Linux on it in future,
      the icloud lock is exactly that - the o.s. checks online for lock status.
      until then, take out the drive and put it in a usb caddy.
      then plug it into a machine runnng Linux,
      it will mount HFS & HFS+ partitions - no problem.
      i dont think the mac encrypts files or partitions by default - i'm not even sure it can if you wanted to.
        • 31199
        if that was an epson or brother, you can power it up while holding in a combination of buttons and it will reset the counters.
        if it's a brother, it can also kill your cartridges!!!
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          maybe speak to the electronics store they may of had this issue before and out of goodwill etc try to help you sort the issue out.
          • diif
            • Feb 2014
            • 6978
            • England
            There are a couple of solutions to try here .http://forums.macrumors.com/threads/...-code.1438822/
            • Spork Schivago
              • Mar 2012
              • 4734
              • United States of America
              Is there a chance the iMac was stolen? We had a local pawn shop that went out of business because they kept selling stolen merchandise. It wasn't on purpose though. People would bring them stolen merchandise. They'd try their best to make sure it wasn't stolen, but it was hard. They'd take your license and address, in case it was. But I guess the police officers gave them a lot of grief. Maybe it was stolen and the original owner locked it? Just a thought.
              So, where does the pin show up at? Is it when you power on the iMac or is it after X-Windows starts? I know the last Mac I redid, I had to reinstall Mac OS X 10.5.8. I burned Mac OS X 10.5.6 and installed that. During the installation, it gave me an option to keep the user files from the previous installation.
              If you have a desktop PC, you could pull the hard drive from the iMac as Stj suggested, but instead of a USB caddy, you can also plug it into a normal SATA port. Boot into Linux, copy your data off, reinstall (assuming the PIN shows up after X starts and not as soon as you turn on the iMac.)
              **EDIT: I just read the link Diif linked you to and I think that's probably your best chance. From reading it, it looks like the BIOS is locked as well and you won't be able to boot off a disc until you unlock the iMac.
              -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
              • ryogadan78
                iMac A1418 - No LED, no power after overvoltage on Ethernet port
                by ryogadan78
                Hi guys, I need your help again.
                I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                06-10-2025, 03:49 AM
              • Stephen
                iMac M1 DFU restore issue
                by Stephen
                iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                this is the message it gives me with the error
                Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                03-07-2025, 12:19 PM
              • Stephen
                iMac 27” 2020 Boot issue
                by Stephen
                Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                08-16-2024, 09:32 AM
              • tommy97
                iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                by tommy97
                we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                Any ideas what might've...
                04-20-2024, 04:48 AM
              • vzgherea
                iMac is not visible for iCloud unlocking
                by vzgherea
                Purchased an older iMac 27" 2011 with no HDD. Installed a new HDD and restored OS via web restore. Got a message saying that this mac has been locked with the 'Find my Mac' feature. The previous owner said he used to lock it sometimes in order to prevent his kids from playing too much, so he admits it could have been left locked. This mac is still listed under his iCloud devices, however the device is shown as grayed out and won't let him remove the lock even when I have the device turned on and connected to the internet.
                Is it because it is running from a new HDD? What could I do...
                03-03-2021, 01:47 PM
