Need some help - replacing SDRAM slot on...
  • liaisons
    • Mar 2005
    Hey guys! Great site, I'm glad you are all tearing away at the bad caps. I don't have bad caps... but I do have a problem and need some help.
    I just bought a Supermicro P3TDL3 (dual 370s)... I got it cheap... ~$20.
    The thing doesn't work. It has a bad SDRAM slot on it, the DIMM 1 slot. I don't know who fu*ked with it or why, but it looks like one of the pins was bent or broken off. They then proceeded to attempt to fix it, so it looks. They took out a small part of the plastic (on the SDRAM slot) and bent another pin in the process.
    The motherboard seems to work fine, though after hitting the power button I get one beep. Memory error.
    I want to replace this SDRAM slot, but I don't know where to buy the right one. I also need to get a good soldering iron and station, but not too expensive please. Also, what temps should I set the iron to when taking off the old SDRAM slot? I WOULD use a 'solder sucker' (thats what we called it back when I used to do stuff like this) to remove the old solder, correct?
    I do have experience in the past w/ soldering. Not too much, but I'm confident!
    Appreciate it guys,
    Stephen
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2658
    • oooo ess aaaaaaaaa
    Ouch. Well...first off, I would not recommend the solder sucker. I replaced a ZIF socket (yes...I know), and the solder sucker.....well.....sucked.
    I have access to a real nice PACE kit, but its pretty expensive. In the past, I've done a bit of surface mount work with one. The station has a good solder extractor and works great for the smaller stuff.
    For the SDRAM sockets I would recommend using a good desoldering station. Trust me....it will make life MUCH easier.
    As for the socket....you can probably get a replacement at Mouser or Digikey.
    Normally I would offer to help, but I'm heading to school in a couple weeks and won't have access to a good soldering/desoldering station.
    Unless of course you live close to VA and get it to me by the weekend.
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
    • sulbert
      • Dec 2004
      • 59
      So the board does not boot at all, even if you put memory in "good" slots?
      I personally would not buy it, just take another dead board from my junk pile and my heat gun and there it is. But that's me...
      • Preowner
        • Mar 2005
        • 13
        Ouch, thats 168 pins to desolder and resolder.
        Like asked before.. this prevents the board from posting? Are the pins touching or is that because you have a ram stick in it? If you can do without 1 of the 4 sockets Id say try to remove the offending pins and leave it at that. The more you mess with the board the more prone it is to fail, and thats an expensive board to lose. Still ~$300 new, I think, for pretty old tech.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          you must have reg ecc sdram.
          you must fill a bank with 2 dimms
          so put 2 matching reg ecc dimms into 3&4
          make sure nothing is touching in the mangled socket.
          iirc this is a tualatin only board
          you need p3s 512k chips.
          it may run a tulatin celeron in 1 socket to test.
          and i have replaced dimm slots here.you need good desoldering gear or forget it.
          heatgunning a junk board to pull a part is fine.
          i have the proper stuff to do this right if you just gotta have both banks working.
          i bet topcat does too.
          • liaisons
            • Mar 2005
            Hey, thanks for all of the information! I guess I won't turn unsoldering the current one. I'll try to use the 3 dimms that are good.
            kc8adu:
            You are saying that I MUST have 2 dimms in for it to boot? and they must be identical?
            I appreciate the help guys, thanks a bunch!
            Stephen
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              iirc all the serverworks based boards run interleaved so you 4 slots are 2 banks of 2
              so if slot 1 is damaged try using 3 and 4
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                If memory serves me correct, that board is based on the VIA Pro266 chipset, supporting Tualatin CPU's (I had one a while back). It does not require population of 2 DIMM's per bank, and interleaving can be disabled. It just doesn't perform as well running on one, but it should run. I don't remember if it required ECC RAM or not, but I do know it would run on one DIMM.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • totoagung2
                  by totoagung2
                  Totoagung2: Situs Slot Gacor Paling Gampang Jackpot di Indonesia 2024
                  Hadirnya situs slot gacor gampang jackpot Totoagung2 yang menyediakan banyak sekali permainan slot terpopuler terkini yang hadir setiap tahun nya. Tentunya di Indonesia sendiri yang menjadi salah satu negara yang favorit bagi provider game slot. Banyak sekali pengembang permainan melihat negara tanah air Indonesia untuk menjadikan dan mencoba berbagai kesempatan bisnis judi online yakni games judi slot Totoagung2 terbaik dan terpercaya no 1. Hal itu juga dibuktikan dengan sangat banyaknya provider mesin slot...
                  01-01-2024, 02:43 PM
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                • corrize
                  Best way to solder LVDS connector for beginner (and qfn) ?
                  by corrize
                  Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                  I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                  I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                  See the test :
                  https://youtu.be/bNAzC-EvqHs?t=1767
                  With hot air from bellow the board, that's...
                  03-09-2023, 02:57 AM
                • Lifeisfun
                  Trying to troubleshoot DDR4 SODIMM slot with slot tester
                  by Lifeisfun
                  Hi folks!
                  I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
                  Eventually I discovered that it was related to moving the laptop.
                  Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
                  If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
                  I removed the board got one of those memory slot testers...
                  06-04-2025, 02:26 PM
                • myth77
                  UV solder mask - high temp resistent, recomendation?
                  by myth77
                  Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                  Is there any solder mask...
                  03-28-2022, 04:04 AM
