Computer Power Supply Antec EA-500
  • Mint Waxed
    • Aug 2016
    • 35
    The more I learn about electrolytic capacitors, the more they sound like little devils just waiting to wreak havoc. As important as computers are in our daily lives, you'd think by now there would be an affordable alternative.
    Using my power supply as an example, the Antec EA-500 is jam packed with electrolytics. Referring to the extensive capacitor listings found at Mouser Electronics, I see caps rated at as little as 1,000 hours and as high as 6,000 hours. I suppose these figures represent running them at the maximum rated temp.
    In all your infinite wisdom, how often should a business computer running at around 8 hours per day be checked for bulging caps in the PSU?
    Even more perplexing, these PSU's are built in dense layers making access to the caps extremely difficult. It would take so many man-hours to repair that the majority of the time, tech's simply replace the entire unit.
  • northpoint
    • Dec 2012
    • 41
    Re: Computer Power Supply Antec EA-500
    Dont forget the amount of glue they use to cover all the important "easy blow" components.
    I say check em when it dies.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Yes, and also maximum ripple current which the PSU may or may not be exerting on it.
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        that depends on many various factors like ambient temperature (air-con or not), dustiness of the working environment, whether or not japcaps are used, how close the psu is running relative to its maximum output wattage, how powerful the psu fan is, where the caps are positioned and whether they receive adequate airflow from the fan.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          All these variables can be condensed into one: power supply internal "ambient" temperature, which can be measured with a temperature probe stuck in between the caps.
          A working TV? How boring!
          • Mint Waxed
            • Aug 2016
            • 35
            One nice thing about the EA-500 PSU, the internal fan speed is controlled by a thermistor which maintains a relatively constant temperature. As for "ambient", it's rather doubtful since the air is in constant motion. It powers an older Abit motherboard currently out of production. I attribute it's longevity to the fact that there are no electrolytic capacitors employed on the board. As for power supply load, the MB is not overclocked so the AC input is only around 2 amps.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              HWI seems to like it
              http://www.hardwaresecrets.com/antec...supply-review/
                by sam_sam_sam
                03-31-2024, 02:12 PM
                by sam_sam_sam
                07-01-2024, 06:34 AM
              • shamsudeen
                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                by shamsudeen
                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                07-19-2025, 07:14 AM
              • JimBanville
                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                by JimBanville
                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                09-13-2023, 07:21 AM
