COMMAND Prompt Win7
  • Gianni
    • Jul 2008
    • 681
    • Italy
    COMMAND Prompt Win7
    Today I was checking my son's PC and opening CMD window I saw that the backslash character is wrong, instead of
    C:\WINDOWS\system32>
    it is
    C:¥WINDOWS¥system32>
    As far as I saw it seems to work properly but I'd like to bring it back to classic backslash symbol.
    My son said he didn't changed anything... and I don't know where to look.
    Google didn't bring me any useful info but maybe I'm not able to serch the right word.
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • 31200
    Re: COMMAND Prompt Win7
    different font / characterset in use?
    • vinceroger69
      • Mar 2012
      • 6714
      http://www.8bitrobot.com/2013/10/04/...for-backslash/
      http://answers.microsoft.com/en-us/o...9b31bf5?auth=1
      • Gianni
        • Jul 2008
        • 681
        • Italy
        Thanks vinceroger69, probably is something like that, my son plays a lot with PC and probably has messed up with something in setting. Now he is sleeping and I can't switch on PC, next days I will check and let you know.
        I searched but using only backslash brought me only useless pages... I didn't thought to use also Yen ;-)
        Ciao
        Gianni
        H. J. Brown
        • Gianni
          • Jul 2008
          • 681
          • Italy
          vinceroger69 you were right, my son changed to play a japanese game, setting back to italian language the command prompt is ok now.
          Thanks again ;-)
          Gianni
          H. J. Brown
          • vinceroger69
            • Mar 2012
            • 6714
            Your welcome glad the links worked.
            • Hondaman
              Win7 Emulation in Linux
              by Hondaman
              If I install Win7 in VirtualBox or KVM, will Windows be tied to that exact hardware? Can I take the VM and move it to another machine at some point without having to re-activate Win7?
              I bought a replacement board identical to the one Win7 is licensed on. But of course it failed. I have two more identical boards in my basement. Running out of acceptable hardware will not happen for quite a few years, hopefully.
              But I am looking forward to that day when I cannot find any hardware, and I have to use emulation. Does anyone have experience with this?
              07-21-2025, 12:46 AM
            • eccerr0r
              win7 home iso? can I get 10?
              by eccerr0r
              Well I think that I have a GTX660Ti that's dead but I think I should give it one last try with its original OS and drivers: win7 home premium. While I can't stomach using win* of any type (I'm 100% Linux these days) I think I have to give benefit of the doubt to drivers, etc.
              So... I have the original CoA for Win7 home premium and it's an OEM license. And I have the whole computer that the GTX660Ti came in (it was reportedly working too), minus the original hard drive, what could I download and run the machine temporarily to verify the GTX660Ti works with Windows or not?
              09-14-2023, 07:35 AM
            • Hondaman
              USB problems?
              by Hondaman
              Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
              (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
              I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
              08-12-2024, 03:26 PM
            • Hondaman
              Japanese language -- Win7 or Linux Mint?
              by Hondaman
              I ordered a Japanese book, it will never be published in English. A Mr. Fujumoto was a Japanese sushi chef who became a cook for Kim Jong-Il. He was not perceived as a threat to the dictator's power, so he became very close to the dictator. Apparently, the dictator is QUITE hedonistic, with a lot of debauchery. Although he can spend as much as $700,000 per year on alcoholic beverages and this alcohol is NOT actually the highest quality. Also, the dictator has 24 palaces. One of them is as large as TEN YANKEE STADIUMS PUT TOGETHER. Are they all that large?
              Does anyone have experience...
              09-12-2025, 04:32 AM
            • 6BW6
              Win7 Performance test stops
              by 6BW6
              I had a dodgy Molex Sata lead go bad that cause crashes once in a while, after repairing all is well with no crashing BUT.... Windows performance test stops. I get-:
              Problem signature:
              Problem Event Name: APPCRASH
              Application Name: WinSAT.exe
              Application Version: 6.1.7601.17514
              Application Timestamp: 4ce798fc
              Fault Module Name: atiuxp64.dll
              Fault Module Version: 8.14.1.6463
              Fault Module Timestamp: 56254af6
              Exception Code: c0000005
              Exception Offset: 000000000000dc14
              OS Version: 6.1.7601.2.1.0.256.48...
              05-29-2023, 04:21 PM
