ATA cables
  • keyboardcowboy
    • Apr 2006
    • 73
    ATA cables
    is this cable still good its an 80 conductor ATA cable,i have plenty of these with a broken wire in all at exactly the same place,by the way this is a new cable
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: ATA cables
    I'm not sure 100% but I think it is for "cable select" device.
    Usually you can set by a jumper HDD and CD-DVD units as master-Slave-Cable select.
    I have seen a lot of 40wire ATA cable with a open wire, but I have never seen a 80 cable.
    Look here
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • Wizard
      • Mar 2008
      • 2296
      Re: ATA cables
      Correct,
      Set all your drives (including disc drives) as cable select (CS). The blue goes on board itself, end is primary, middle connector is slave with this (CS) system.
      Cheers, Wizard
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • araxnido
        Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
        by araxnido
        Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
        When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
        06-10-2025, 09:26 PM
      • Patch2
        Cable Repair
        by Patch2
        I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
        01-02-2025, 06:04 PM
      • conghuyms
        I need datasheet cable eDP LCD 30 pin slim pls help me!
        by conghuyms
        My 30-pin eDP cable from the mainboard to the LCD screen got cut and damaged at the screen connector side. I found another cable and took the screen-side connector from it, but the wire colors are different. So I really need the wiring diagram for both ends of the eDP cable to solder it back properly. If anyone has the diagram, please kindly help me out. Thanks a lot...
        08-22-2025, 11:16 AM
