Hard drive issue
+ More Options
Posts
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Hard drive issue
    Firstly hello forum,need some help,have a old acer laptop totally knackered runs bad very laggy,the hard drive has files which I can access of another laptop via usb lead.
    Is there anyway you can view past net searches of another laptop,for example you logged in automatically to a site on the knackered laptop,can you view on another or is this not possible ?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Hard drive issue
    Which browser and version did you use ?
    It's easy to copy the entire profile which includes browsing history and passwords with Firefox and Chrome.
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      Hard drive is out of a acer on windows vista and the browser was google chrome.
      I just want to view ie on the search on that hard drive from another pc/laptop
      • diif
        • Feb 2014
        • 6978
        • England
        If the browser was Chrome on the Acer the profile can be copied over, I did it on a PC a couple of weeks ago. I think it was ...\AppData\Local\Google\Chrome\User Data that I copied over.
        • LEEDASH
          • Dec 2012
          • 481
          • Bedfordshire
          Where do you copy the file to ?
          • diif
            • Feb 2014
            • 6978
            • England
            I copied it to the same place on a new install.
            • LEEDASH
              • Dec 2012
              • 481
              • Bedfordshire
              The hard drive has around 30 file folders each with mixture of just numbers and letters,no app data in either one ?
              • diif
                • Feb 2014
                • 6978
                • England
                You will need your PC set to show hidden files and folders.
                • federalhouse
                  **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                  by federalhouse
                  I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                  **Background:**
                  I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                  **What I've Tried So Far:**
                  1. I accessed
                  08-01-2024, 07:03 PM
                • tmcw
                  PC case - Hard drive rails
                  by tmcw
                  A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                  So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                  I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                  Now, the case is a CiT Gaming Case, and...
                  05-22-2022, 12:04 PM
                • ash91
                  Hp pavilion 15 not detect hard drive
                  by ash91
                  Hello gentelmen .... this is my first post and sorry for my bad english,
                  so my proplem is my laptop keep losing hard drive even if i but the
                  hard disk in the cady (the box that can replace the dvd rom with hard disk)
                  when i turn the laptop on the massage that said no boot media found pop on
                  the hard disk is fine and to be sure i try another hard
                  i also update my bios to the last update
                  the 5 volt is present on the hard connector on the motherboard
                  the dvd rom work fine when i but a windows dvd in it
                  also when i boot from flash...
                  06-07-2023, 01:45 PM
                • perfm2
                  HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
                  by perfm2
                  So I've worked on dozens of HP and Dell laptops and have never encountered this before.
                  Steps taken in my usual process.
                  Reset security settings in the BIOS
                  Ensure existing HD comes up into the OS
                  Shut down the laptop and disconnected the main battery
                  Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
                  Replace battery connector and close up the laptop
                  Insert my USB drive with my Windows 10 image I've...
                  03-21-2023, 08:45 PM
                • reformatt
                  Intel iMacs, 3rd party SSD failures and Fusion setups
                  by reformatt
                  I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                  As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                  So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                  12-18-2024, 10:34 PM
