GA-8N-SLI issues
  • stevo1210
    • Oct 2006
    • 4156
    GA-8N-SLI issues
    I purchased a second hand GA-8N-SLI motherboard today and it had been deemed with a POST issue. I had a client the other day with the same board with the same issue but they built a new PC so they took that board back as well so I have no reference board.
    Anyway, my issue is that the damn board will just beep at me with short and fast repetetive beeps that won't shut off until I switch the whole thing off. Sometimes it will POST and after a restart it screws up again. I changed the PSU and that hasn't changed anything. I tried resuffling my known good Kingston RAM into slot 3 and so far it hasn't exhibited any issues.
    When I plug the RAM into slot 4, it is still OK.
    Slots 1 and 2 will cause the board to not POST (I think). I want to use slots 1 and 2 so what else can I do?
    Thanks.
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: GA-8N-SLI issues
    This motherboard seems a cursed one: over 9000 results for GA-8N-SLI no boot
    First check obvious things: make sure you've installed the last bios revision and check the board revision: rev 1.0 supports only Pentium 4 5xx and 6xx, a few 8xx and none of the 9xx while rev 1.1 supports almost all old P4 generation. Check all cables and jumpers, you never know; clear the cmos and load default settings.
    Continuous beeping is related to ram: maybe your Kingston ram is too recent for the old nForce 4, there are rumors the GA-8N series works better with older modules like DDR2 533 and there isn't an official memory compatibility list [damn Gigabyte]. Try using only a module, in bios set all ram settings to their most tolerant values (e.g. highest latencies, low fsb); try all slots one by one, from first to fourth. If it doesn't work, try using old ram.
    Keep us updated
    Zandrax
    Have an happy life.
    • stevo1210
      • Oct 2006
      • 4156
      The RAM I am using is a Kingston 1GB DDRII 667MHz stick. This is the only 667MHz stick I own. The motherboard was apparently designed for 667MHz RAM. So far my system has booted without an issue for the last 4 days. I didn't use slot 1 or 2, but I used slot 3.
      If I use slots 1 or 2, the beeping issue comes back. If I use slots 3 and 4, the beeping issue goes away. I would like to use slots 1 and 2 for another stick of DDRII for dual channel but I don't know how to get around the beeping issues.
      Thanks.
      • zandrax
        Hit and miss
        • Dec 2007
        • 1157
        • Italy
        Hmmm, strange enough.
        Try cleaning both slot 1 and 2 with a dry spray deoxidiser, check ram caps and chipset heatsink (remove it, clean it and make sure there is enough thermal paste): nForces are so hot I'm not surprised high temps may be involved in board lock-ups and system dizzyness.
        Lastly there are a phisical damage, say a broken path or similar issues, or a bios issue: chances are quite low, though.
        Zandrax
        Have an happy life.
        • stevo1210
          • Oct 2006
          • 4156
          I used compressed air to clean slots 1 and 2. No success at all. Still beeps when I plug some RAM into slots 1 and 2. Sometimes I may get lucky and I can boot with RAM in slots 1 or 2. But after a reboot, it goes back to the beeping stage. Slots 3 and 4 on the other hand work like a charm.
          Thanks.
          • zandrax
            Hit and miss
            • Dec 2007
            • 1157
            • Italy
            This seems an hardware fault, maybe fake contacts or a short: if I were you I'd remove the board, check there isn't a screw, iron dust or something like that that is shorting ram contacts, then lie the board on a flat surface (a table) and try pressing slot 1 and 2 against the mainboard.
            OTOH the board works with ram in slot 3 & 4 so you could forget slot 1 & 2 and simply check stability with Prime95 and memtest86+.
            Zandrax
            Have an happy life.
            • stevo1210
              • Oct 2006
              • 4156
              Strangely enough when I took the board out of the case and tested the board on a cardboard box, RAM slot number 1 worked. Slot 2 didn't work whatsoever. When the board was put back into the case, only slots 3 & 4 worked. Sometimes slot 1 comes back to life but not for very long. Anyway, Stevo decided to ditch this board and buy an Intel DP965LTCK and he has been happy ever since he bought a new board. I even managed to have enough cash to fit in an Abit X600XT graphics card. The board was $40 and the graphics card was $15. My local computer store was having a closing down sale and saw these two on special.
              Thanks.
              • zandrax
                Hit and miss
                • Dec 2007
                • 1157
                • Italy
                So fake solderings, bad joints or maybe interrupted paths in pcb: you won't know since you changed board.
                The Intel board is a good deal (has PS/2, Pata and floppy connectors too: an unexpected surprise knowing Intel's desire of getting rid of all legacy connectors); the Abit is adequate except for recent games and HD films, but it costed less than an used one so there isn't anything to argue.
                Good purchase, Stevo.
                Zandax
                Have an happy life.
                • rounin
                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                  by rounin
                  I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                  🛠 Original Issue
                  The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                  04-19-2025, 01:18 AM
                • ugamazing
                  Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                  by ugamazing
                  I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                  We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                  12-17-2024, 07:05 PM
                • BigOof
                  Marantz SR5007 popping on volume change and mute in Direct Mode
                  by BigOof
                  I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                  12-12-2024, 06:15 AM
                • coasterghost
                  Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                  by coasterghost
                  For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                  Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                  Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                  System Hardware:
                  Processor: AMD Ryzen 7 PRO 5850U
                  Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                  09-08-2025, 10:46 PM
                • shahnld
                  Lenovo legion 5 pro startup issue
                  by shahnld
                  Good day Experts
                  I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                  A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                  And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                  08-24-2025, 12:31 PM
