XP restore via command line
  • pentium
    • Mar 2006
    • 2778
    I keep a Thinkpad T30 docked these days at my desk running RDP and an IRC client and this afternoon I came home to it stuck at the "windows did not properly start last time" screen. It didn't matter what I selected the machine would do a brief drive access and then freeze.
    I brought the machine up on the SP2 install CD's recovery console and chkdsk did it's magic as best it could. On reboot I could start windows normally and I saw the boot splash screen, then the screen went blank as it does before the video reinitializes and the machine hung again.
    Started with the last known good configuration and it did it again. Tried safe mode and after agp440.sys (I doubt it was on that file but that was the last thing it had on the screen) all hard drive activity stopped and the machine hung. Finally tried booting to safe mode with a command prompt and again, no dice.
    Suspecting either bad ram or the machine was failing to enable a VGA mode from the video card because like the last T30 the GPU had flaked out I fed it a Ubuntu 8.05 live CD and to my surprise it booted that no problem so the video was fine and running memtest found not issues with the ram either.
    The only thing I can think of now is that for some random reason the machine crashed and something got corrupt. Before I take it as a loss I want to see if falling back to an older restore point might fix it somehow. I seem to recall that if you boot from the windows CD into the recovery console and run C:\windows\system32\restore\rstrui.exe you can restore from a previous point via command line but it says it can't find the application even when I can clearly see it in C:\windows\system32\restore. What gives?
    Find Nedry!
    Check the Vending machines!!
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: XP restore via command line
    Did you check the date and time in the Bios ? .. XP is very sensitive to a failed cmos battery . Being very old , i suspect you'll find a rotten one .
    In case it wasn't the battery , it's better to repair the XP from the Original CD , start as if you're formatting from zero and if the system can be restored you will see the option repair system at some point..
    • pentium
      • Mar 2006
      • 2778
      The battery is fine and the time as not slipped. I replaced the cell when I rebuilt the laptop in 2014.
      I've never really researched into that but I've been warned to only leave this until the end as if you have anything custom in your windows folder it's gonna wipe that out and while it might bring the OS back other applications may stop working. Plus the machine currently has SP3 while my install media is SP2. I'm not entirely sure if reloading part of it with an older version of XP will do much good.
      Find Nedry!
      • diif
        • Feb 2014
        • 6978
        • England
        You'll need to slipstream SP3 into an ISO made with your SP2 if you want to do a repair install.
        More likely to be a flakey hard drive than bad ram, have you checked it ?
        • pentium
          • Mar 2006
          • 2778
          Right. Should of expected that.
          The slipstream install disc took my existing install.....and ignored it. It installed a brand new install of XP alongside my install that needed to be repaired so now I got one install that has my stuff but doesn't boot and a fresh isntall that has several fun hours of reloading software and drivers to get it back to where it was. Thanks. At this point it's better if I nuke the disk and start over.
          Find Nedry!
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            pop in a bootable win98 DOS CD (yes, there is such a thing- I made them back in the day) and type:
            FDISK
            and kill the partition(s)- then start over
            "pokemon go... to hell!"
            EOL it...
            All style and no substance.
            guilty,guilty,guilty,guilty!
            guilty of being cheap-made!
              ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
              This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-12-2024, 03:28 PM
            • Fam787
              HELP! A1398 Dead,
              by Fam787
              I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
              Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
              12-27-2024, 05:19 PM
            • lucaszmn
              by lucaszmn
              Problem:
              Initial Findings:
              • I concluded that the
              08-12-2025, 03:01 PM
            • Soulzink
              Samsug washing machine. Power supply DC41-00189a board issue
              by Soulzink
              I am trying to fix a samsung washinmachine power supply main board.
              I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
              Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
              The power supply board reference is the following: DC41-00189a
              I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
              04-19-2025, 06:26 AM
            • cubytus
              Samsung UN50TU8000FXZC shows thin horizontal green line when warm
              by cubytus
              Hi to all,
              I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
              I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
              Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
              01-10-2024, 01:26 AM
