ECS Atom 945GCT-D
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    ECS Atom 945GCT-D
    ECS Atom 945GCT-D
    Now there is something for the quiet hope PC builders for net/video/downloading. ECS company show now on the Taiwan Cumputex Intel Atom powered 945GCT-D mainboard in DTX size (170 x 203 mm - well, there are even smaller mainboard, like Mini-ITX witch is 170 x 170 mm big) and it is based on the Intel Atom processor. Logicvally it is not a very fast one, so Intel is claiming and boasting that this is the smallest CPU. Well, I think that Motorola DragonBall was smaller few years ago already, but that is just me...
    ECS 945GCT-D mainboard has 100MBi ethernet, HD audio a integrated GMA950 graphic with DX9 support. Mainboard is based on the 945GC/ ICH7 chipsets and using a 1.6Ghz Atom 45nm processor, diorectly soldered into mainboard. In the CPU is used a little over 47 millions transistors. Bried history on the number of transistors:
    8086 - 0.029 millions transistors
    80286 - 0.134 millions transistors
    80386 - 0.275 millions transistors
    80486 - 1.2 millions transistors
    Pentium - 3.3 millions transistors
    AMD K5 - 4.3 millions transistors
    Pentium II - 7.5 millions transistors
    AMD K6 - 8.8 millions transistors
    AMD K7 - 22 millions transistors
    Pentium III - 9.5 až 28.1 millions transistors (more recent revision)
    Pentium IV - 42 až 125 millions transistors (Prescott)
    AMD Barton - 54.3 millions transistors
    AMD K8 - 105.9 millions transistors
    Core 2 Duo - 291 millions transistors
    Core 2 Quad - 582 millions transistors
    ...and also...
    Dual core Itanium 2 - 1 700 millions transistors
    So it has a little less caps that has a AMD Barton CPU's.
    It should be fully compatible with existing x86 CPUs, witch is a requirment todays. As for the CPU itself, it has an Intel HT technology inside as well, as allegedly every instruction of the Core line. Hmmm. Witch is great is, that the TDP of the Atom CPU's range between 0.6 and 2.5W only, depending on the type. 2.5W is for ATM fastest 1 800MHz one. VIA C3 1200MHz mas a 14W TDP and can be cooler with passive heatsink - if you don't mind around 70°C temperatures on load.
    Atom is going to be one hell of a cool CPU.
    DTC mobo is compatible with current ATX and Micro-ATX cases, so no own holes drilling for this mobo.
    Mainboard specification is - 512k L2 cache, 100MBi ethernet, HD audio, 2x SATA 3.0Gb/s, 1x PATA, 4x USB 2.0, 2x DDR2 533 and one PCI slot and one added PCIe x1 expansion slot.
    Source: http://my.ocworkbench.com/bbs/showthread.php?t=75131
    Here is a small video-preview of how the box and mobo looks in my friend hands - watch in high quality!
    http://www.youtube.com/watch?v=gdtD7JN_st8
    Review and tests of ESC 945GCT-D board with Intel Atom CPU's are there:
    http://my.ocworkbench.com/2008/ecs/ECS_945...om_board/g1.htm
    Overclock go, thanks to no voltage adjustments of Vcore, to not more that 145MHz FSB from 133MHz. So a 1.6GHz CPU to 1.75GHz Super PI 1M test is can make in 1min and 33 sec, witch is against the VIA C3 I using as fanless machine very very good, because 1 200MHz C3 Nehemiah need for 1M Super PI test 8min 28sec...
    Great solution for a small, fanless (and hence quiet!) home computer/server!
    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: ECS Atom 945GCT-D
    bigger hs on nb than cpu!
    ost caps on vrm out .
    those wont last!
    • linuxguru
      • Apr 2005
      • 1564
      Go for the Intel-original D945GCLF instead at ~$65 or less - it comes with an Atom 1.6 GHz EM64T HT CPU pre-installed. It has good caps and generally better build quality than ECS/PCChips.
      • Mirenia
        Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
        by Mirenia
        I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
        I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
        In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
        The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
        03-30-2025, 06:47 AM
      • orcic
        MASTER TL240 and new mainboard LW36BKC01
        by orcic
        I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
        The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
        After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
        Now I have some doubts about how to connect the new mainboard to the old power supply.
        First of...
        05-12-2023, 08:10 AM
      • Devonavar
        Vizio M43-C1 - How closely do I need to match the mainboard number?
        by Devonavar
        I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
        I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
        Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
        So, I've ruled out the PSU for now.
        The reboot loop...
        08-14-2022, 08:46 PM
      • l0lhaxz1
        QN65QN90A - Mainboard MLCC failed - now bootloop
        by l0lhaxz1
        Hi
        I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
        Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
        Came to learn after a bit more research...
        02-06-2023, 08:59 AM
      • Jembang
        coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
        by Jembang
        good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
        11-01-2024, 09:55 AM
