Dell SX270 Poly mod
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Dell SX270 Poly mod
    I bought a large lot of Dell SX270 systems for cheap. These are little toaster boxes, they get very hot. These will be some great candidates for some poly testing. When they arrive, I'll try this out on a couple of them...
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Dell SX270 Poly mod
    i have done a few already.
    so far they are more stable than new according to my customers.
    these are about the only boxes i regularly find blown rubycon mcz in.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      I also see them all the time with blown rubies and panasonics in them. I'm curious to see how they do.
      Team : 49813
      Join in!!
      Team Stats
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i have been tempted to cut a slot in the face of one and stencil "insert pizza here" on it.if its going to run hot put that wasted heat to use!
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
        • F R 2568
          Dell Latitude 5420 does not start (no post) need help to find the reason why
          by F R 2568
          Hello all,
          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
          If the laptop is only connected to the AC adapter (battery removed):
          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
          The power/battery...
          01-08-2025, 05:45 AM
        • diamon
          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
          by diamon
          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
          Pictures of these boards:
          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
          Dell...
          02-28-2024, 12:51 PM
