5.25 floppy
  • fzabkar
    • Mar 2009
    • 772
    Re: 5.25 floppy
    The floppy controller has a data separator whose clock rate has to match the drive.
    A 1.2MB floppy has 15 sectors per track and spins at 360RPM, so its data rate is 5400 sectors per minute.
    A 1.44MB floppy has 18 sectors per track and spins at 300RPM, so its data rate is also 5400 sectors per minute.
    Therefore you should configure your BIOS for a 3.5" 1.44MB drive. In fact in the past I have configured my 1.44MB drive as a 1.2MB FD, and my 1.2MB as a 1.44MB FD, and was still able to read 1.44MB and 1.2MB diskettes in their respective drives.
    You could Format your diskette via a Windows DOS box by specifying the "F:size" parameter as "F:1200". Alternatively, you could try specifying the "T:tracks" and "N:sectors" parameters (80 and 15, respectively).
    Code:
    C:\>format /?
    Formats a disk for use with MS-DOS.
    FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B | /S] [/C]
    FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B | /S] [/C]
    FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B | /S] [/C]
    FORMAT drive: [/Q] [/1] [/4] [/8] [/B | /S] [/C]
     /V[:label] Specifies the volume label.
     /Q     Performs a quick format.
     /F:size   Specifies the size of the floppy disk to format (such
           as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88).
     /B     Allocates space on the formatted disk for system files.
     /S     Copies system files to the formatted disk.
     /T:tracks  Specifies the number of tracks per disk side.
     /N:sectors Specifies the number of sectors per track.
     /1     Formats a single side of a floppy disk.
     /4     Formats a 5.25-inch 360K floppy disk in a high-density drive.
     /8     Formats eight sectors per track.
     /C     Tests clusters that are currently marked "bad."
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      Re: 5.25 floppy
      Originally posted by ozzy214
      Windows 7 sees it as 3.5. I think its a bios limitation, because I installed xp and it cant pull data or format. I then tried zubuntu live and it said somethign about cant mount and bad blocks. So guess this box cant read it
      So going to have to fire up the dinosaur and try that!
      I agree on that . If the bios sees it as 3.5inch , then yes , windows won't be able to read it , and Zbuntu already affirmed that as giving logical responses to such situation (cannot mount and bad blocks ) ..
      A different approach is trying to remove the 1.44 floppy temporarily from the PC , and leave the 5.25 inch alone , hoping The PC then will be forced to see it as floppy A and deal with it in proper way..
      In between , did you try other kinds or even different labels of Floppy cables connectors ?.. Why not assuming the inner cable connector's are copper corroded ? ..
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        Re: 5.25 floppy
        By the way , I threw 6 working units 5.25 inch last year , assuming no one will ever mention them , or even remember , lol .. And yes , i was thinking to leave them for Antics purposes , like i've kept a 10 mb Hard disk ..
        This is the first time i regret it , because i'm trying to help virtually !! ..
        • ozzy214
          • Nov 2013
          • 319
          • usa
          Re: 5.25 floppy
          I would have bought them and flipped them as they are still selling. Their is a lot of industrial machines still running them to thius day.]
          I pretty much put this project on hold. The mitsu floppy just keeps spinning the disk no matter if requested data or not. So me thinks the logic board is dead. There is jumpers on it, but I cant find a diagram.
          I did find another floppy on the shelf that seemed to act normal, but never could read a disk. Bad head or bad floppies I guess? And sadly the last time I was monkeying with it, I broke the gold finger off off the board unplugging it!!
          Never got around to firing up the socket 7 board i acquired from my competitor scrap man.
          So guess this project dead till I find another floppy.
          Sucks, as I have a whole ton of floppies from commodore I acquired from a estate sale. I wanted to see if still good and could access the data. Curiosity on my part and they may have been worth something on ebay.
          I dont think its ment to be. I even was going to buy a zoom floppy controller to run old commodore floppies off of usb. But fired up the one from the estate sale and lets say it started smoking. Crash and burn baby....surprisingly never lost power. But has a rank burnt crispy smell!!
          So me thinks Im just not ment to play with the floppies~!
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            Re: 5.25 floppy
            Just keep it on hold .. As a repair shop , many customers and friends drop all kinds of items each day for free , guess that's why i don't write in the free scores thread , lol .. Last month i was given 3 VCR's , 3 HP printers plus one huge Xerox .. Of course i threw the 6 units due to lack in space , but who knows ? maybe we'll see anothers . If so I promise you one or two for free ..
            About the floppies , yes , those you know , look like thin paper and can be bent easily , so i think they are the most difficult part in your quest .
            • fzabkar
              • Mar 2009
              • 772
              Re: 5.25 floppy
              Jumper settings ...
              Mitsubishi MF501C/MF504C Flexible Disk Drives Installation Guide:
              https://cdn.badcaps-static.com/pdfs/...73a05ba75c.pdf
                • 31046
                Re: 5.25 floppy
                nice find!
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  • United States of America
                  #28
                  Re: 5.25 floppy
                  I didn't read the whole thread and this information is more than likely outdated now, but just in case you ever need to plug in an old school floppy, like a 1.2MB 5.25" floppy, I do believe they make add-on floppy controller cards that you can plug into a PC. I saw one, but it was crazy expensive, 16-bit. I believe ISA. I didn't look too hard.
                  **EDIT: I found the Catweasle.
                  http://www.vesalia.de/?V02b0f1152514...871776e6429267
                  It allows you to hook up 8", 5 1/4" and 3 1/2" inch media and it's a PCI card.
                  -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
                    • 31046
                    Re: 5.25 floppy
                    i dont see drivers for that!
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      #30
                      Re: 5.25 floppy
                      Are there supposed to be? I just figured it was plug-and-play.
                        • 31046
                        Re: 5.25 floppy
                        you figured wrong, it's for amiga emulators.
                        nothing is plug&play unless it has a bootrom.
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          #32
                          Re: 5.25 floppy
                          I didn't look too hard, but I thought that's what those little chips that have two sockets on that board where, bootroms. I take it I was wrong in that assumption as well...
                          • ozzy214
                            • Nov 2013
                            • 319
                            • usa
                            #33
                            Re: 5.25 floppy
                            I thank you much sir fr the info, but floppy still wont boot. Discs is just on a continous spin so I think the logic board is dead.
                            The other one I have attempts to red, but doesnt. So maybe bios limitation?
                            I put it on hold as I got many projects to do for my ebay store. And very busy!
                              • 31046
                              Re: 5.25 floppy
                              the 2 28pin chips are commodore SID chips (Sound Interface Device)
                              Vesalia is a retro shop - that's a giveaway anyway - good source of oldschool joysticks etc.
                              • eccerr0r
                                It's 2025: do you know where your 5¼" floppy drives are?
                                by eccerr0r
                                Oh wow.
                                As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                                Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                                Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                                Weird. Seems the PC drive is having trouble clamping...
                                07-07-2025, 12:49 AM
                              • Stefan Steff
                                HP Elitebook 840 G5 strange behaviour, need ideas...
                                by Stefan Steff
                                I finished my work for this year, so I'm free until January 6th.
                                My last task it's unresolved and I'm looking for ideas for the return in January.
                                So what's about...
                                This laptop is booting in 3-4 seconds has no password and every voltage is present. So far so good.
                                My problem is that it doesn't boot from anything. !...just stays with a blank screen(backlight only)
                                No USB boot (in fact partially no boot...), no PXE boot nor boot from M2.SATA or NVME...crazy...
                                The Ventoy USB (EFI) boots in the menu system but after selecting one of the ISO (like a simple...
                                12-24-2024, 05:50 AM
                              • CDNBrewer
                                Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                by CDNBrewer
                                Hello Everyone,
                                I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                Symptoms:
                                • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                • I swapped the Left and Right surround
                                08-05-2025, 09:29 PM
                              • ZoneMind6006
                                Ideas on what's going on with this T480s
                                by ZoneMind6006
                                It's already computrace disabled and all that good stuff, W25Q80V and W25Q128V seem fine. The issue is powering the thing on, the fan will spin for about a half second and if power is kept in, it continues to do so in intervals. If I place the battery in, it will show orange for just a sec, now interestingly, if I place a charger in both the TB port and charging port at the same time it will turn white or charge until completion, how odd, but it won't boot. Any ideas?
                                12-13-2023, 07:44 PM
                              • Topcat
                                Need to find a 34-Pin Motherboard Floppy Header
                                by Topcat
                                Looking for some floppy headers.....searching the usual sources (digikey/mouser/etc) until my eyes bled, I couldn't seem to find such a beast. Yes, the silly 34 pin floppy header for a PC motherboard....
                                Why? Well, I was given a bunch of Optiplex 330's, which are useless systems these days....and despite what some have said, they do not respond well to the E5450 c0 stepping LGA771 Xeon mod, tried several, it never worked. They're in a standard BTX case, so I tossed some $5 Optiplex 380 boards in them I picked up on ebay, which will run ANY 5400-series Xeon with hard mods + firmware........
                                06-25-2020, 10:50 AM
