Re: Modem and wireless choices.
I recommend you just use the web interface to configure the devices. Having the modem and router have the same IP address is very very bad! When you specify the address, which one is it supposed to connect to? In short, this creates a mess (which you have now experienced).
Therefore I recommend you configure one device and change its IP to something like 192.168.1.2. Then configure the second and leave it as 192.168.1.1.
Hope this helps a bit.
By the way, WRT54g routers are awesome! Also I am pretty sure that the AG300 is also a router (although with a built in modem).
It is no problem, however I would recommend you use the AG300 purely as a modem and let the WRT54g handle the routing. However another idea is using the WRT54g as a wireless access point only and letting the AG300 handle the routing and modem parts. It does not really matter, I have the same sort of setup. I use my cheap wired router (with built in modem) purely as a modem and my WRT54g as a router and wireless access point.
