Building an auto shop computer
  • dragos2009
    • Mar 2013
    • 110
    • Romania
    Re: Building an auto shop computer
    why not buy an intel NUC computer it tiny powerful enough
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      Hmm. Dual m.2 slots (wifi and ssd). Wifi wires included. Vesa mount. Not bad. I will need an hdmi to dvi connector though
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        Oh I found one with built in wifi (many of them only come with the wifi antenna cables and you have to install a mini m.2 wifi card).
        What do you guys think? Its a mobile i5
        http://m.newegg.com/Product/index?it...9SIA6ZP3R88391
          • 31051
          i think your not thinking clearly.
          you cant use wifi in a workshop, ignition systems and welders etc will jam it.
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            they currently have a usb extension cable, running up a pole with a duct taped up USB wifi adapter. No problems
            I don't think they use arc welders
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              #26
              Got it. Mobile i5 broadwell. 24" samsung monitor with a back mount. But had issues installing on the 950 pro. Turns out it has its own driver for it's pci-express chip. Had to find someone who extracted the files so I could load them into windows 7 install
              • dragos2009
                • Mar 2013
                • 110
                • Romania
                #27
                try this to see if it works http://nucblog.net/2015/07/installin...h-or-nuc5ppyh/
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  #28
                  I didn't have any usb issues. The usb was set to auto, which detects the current implimentation and switches. For instance it allows ehci on the windows install. The issue was never with broadwell, it was with skylake, which only allows xhci (yeah unless you impliment drivers on install boot). I found this out during a skylake i3-6100 build for a customer of mine. Luckily, the motherboard had a ps/2 keyboard/mouse combo, and I was able to go through the windows setup easily with just a keyboard. Unfortunately the usb install method did not work from my flash drive even with usb legacy mode on. Had to actually use sata otherwise it could not find source files. No problem with usb keyboard/mouse or usb install of the NUC
                  • dragos2009
                    • Mar 2013
                    • 110
                    • Romania
                    #29
                    i see a big problem you said that the nuc will be used in a workshop and there is a lot of dust and computers and dust don't go very well as in this case the nuc is not fanless and it has a small fan and heatsink that will be cloged with dust
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      #30
                      Yeah I know it has a little fan assembly. But it's waay of the ground. Even the old computer didn't have mch dust and it was right near the floor
                      • shouri
                        Dell latitude e5490 auto restart
                        by shouri
                        Hi guys, can someone help me?
                        I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                        Board model is dm70 la-f401p rev:1.0 2017-09-20.
                        At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                        After a few days test, is seems ok.
                        Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                        12-10-2024, 09:27 PM
                        Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                        The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                        Securing a good thermal interface between...
                        10-07-2024, 04:35 AM
                      • classicandy
                        Lenovo G50-80 Auto Power On when AC is detected
                        by classicandy
                        Hi Everyone,
                        I have a Lenovo G50-80 that auto powers On when AC (Charger) is connected. I have checked the BIOS settings and there is no option to turn On or Off that feature as it is in some HP EliteBooks. I did update the BIOS and still same.
                        I then flashed the BIOS with a different bin file I downloaded here, It worked (didn't auto power on) for some time (after testing up to 5 times) but has now started again to auto power on when AC is connected.
                        The CMOS battery voltage is 3v. I have also tested with two main batteries as well. I would be glad if anyone...
                        03-21-2024, 05:48 AM
                      • harp
                        detecting heat with IR LED receiver
                        by harp
                        I have some dark IR led, and want to know if it is be situable to detect pure heat (not visable glow ir radiation) in well lighted desk?
                        So, if I put hand over it in near distance like few centimeters, that detect rising heat, not covering it from light.
                        Something like termal camera, but in one spot, any simple circuit?...
                        09-06-2023, 06:03 PM
                      • ludovik
                        Moto G84 short after heat
                        by ludovik
                        i was reballing the power manger of a moto g84, after applying heat i tried to power on and it wouldn’t.
                        i injected 1.5v to some capacitor that seem in short because both side beep if tested.
                        when i inject i feel the cpu burning;
                        since the cpu is exactly on the other side of the board, is that possible that the heat from the reballing damaged the cpu? do you know where i can find schematics or what can i do?
                        i know this is not enough to explain the situation so if you need any other info ask me please!
                        Thank you very much in advance
                        11-08-2024, 02:13 PM
