Re: Questions about Windows 7 Pre-Activation.
On the 7 discs, there's an install.wim file. You can use DISM to mount it and then set the product key. You can google for Windows 7 pre-activation product keys and find the one for your manufacturer and version of Windows that you want. For Dell, the keys are:
The SLIC data is already in the BIOS so you'd just need the certificate. You could find it on the recovery .WIM or download it. If you put it in the install.wim windows\system32\OEM directory, when you go to install, it'll automatically pre-activate. If you remove the ei.cfg file, you can just pick which ever version of 7 you want, and it'll always pre-activate.
It's just advice in case you ever want to play around. I know you don't need the advice because you was able to use the recovery wim to get what you needed and stuff.
Code:
Starter -- 36Q3Y-BBT84-MGJ3H-FT7VD-FG72J Home Basic -- 36T88-RT7C6-R38TQ-RV8M9-WWTCY Home Premium -- 6RBBT-F8VPQ-QCPVQ-KHRB8-RMV82 Professional -- 32KD2-K9CTF-M3DJT-4J3WC-733WD Ultimate -- 342DG-6YJR8-X92GV-V7DCV-P4K27
