Resistor
  • redlght
    • Jan 2014
    • 13
    • US
    Resistor
    What value is 42E2? 42.2 o k m
    • 30978
    Re: Resistor
    42E = 2m67
    maybe
    because the last digit is not listed on my data - maybe the tolerance.
    lookup E96 coding
    • redlght
      • Jan 2014
      • 13
      • US
      Re: Resistor
      I know the letter position marks decimal point EG 42.2 just not sure of ohm kohm or mohm
        • 30978
        Re: Resistor
        where did you get that info?
        • redlght
          • Jan 2014
          • 13
          • US
          Re: Resistor
          From one i did before i think they used that type of markings in italy and such
          • redlght
            • Jan 2014
            • 13
            • US
            Re: Resistor
            Resistors are identified on a circuit with numbers and letters to show the exact value of resistance - such as 1k 2k2 4M7
            The letter W (omega - a Greek symbol) is used to identify the word "Ohm."
            but this symbol is not available on some word-processors, so the letter "R" is used. The letter "E" is also sometimes used and both mean "Ohms."
            A one-ohm resistor is written "1R" or "1E." It can also be written "1R0" or "1E0."
            A resistor of one-tenth of an ohm is written "0R1" or "0E1." The letter takes the place of the decimal point.
            10 ohms = 10R
            100 ohms = 100R
            1,000 ohms = 1k (k= kilo = one thousand)
            10,000 ohms = 10k
            100,000 ohms = 100k
            1,000,000 ohms = 1M (M = MEG = one million)
            • redlght
              • Jan 2014
              • 13
              • US
              Re: Resistor
              SO i guess it is a 42.2 ohm
                • 30978
                Re: Resistor
                your playing a dangerous game making those assumptions.
                i hope your right!
                are there other resistors on your circuit with a letter code you could meter?
                • redlght
                  • Jan 2014
                  • 13
                  • US
                  Re: Resistor
                  Yeah the ch2 i can measure when i open it back up
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Re: Resistor
                    The last number is the power of 10. That would make it a 4.2 X 10^2 or 420 ohm resistor.
                    sigpic
                    (Insert witty quote here)
                      • 30978
                      Re: Resistor
                      and the letter "E" ?
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Re: Resistor
                        E for Exponential notation. Like the "E" key on a TI calculator.
                        sigpic
                        • redlght
                          • Jan 2014
                          • 13
                          • US
                          Re: Resistor
                          they claim the E marks the decimal point
                            Re: Resistor
                            Can we see the pictures of this resistor?
                            • redlght
                              • Jan 2014
                              • 13
                              • US
                              Re: Resistor
                              There is one on each channel ill get a pic and measure the good one when i take it back apart
                              • redlght
                                • Jan 2014
                                • 13
                                • US
                                Re: Resistor
                                Good one reads 43 so 42.2 ohm it is
                                  Re: Resistor
                                  All these time I thought we are talking about SMD resistor with '42E2' marking on the top, it is through hole resistor with color band code.
                                  So where did you get the '42E2' from?
                                  Pictures are always important.
                                  • redlght
                                    • Jan 2014
                                    • 13
                                    • US
                                    Re: Resistor
                                    That is the value marked in the service manual schematic 42E2 rest are marked regular 10K and such.
                                    42.2Ω 1%
                                    Yellow, red, red, gold, brown.
                                    Standard
                                    1% (E96) value.
                                    • jinu_j
                                      by jinu_j
                                      Hi
                                      05-03-2025, 10:51 PM
                                    • mikey5791
                                      by mikey5791
                                      Hi to all forum members,
                                      12-26-2024, 04:55 AM
                                    • MidnightRoller
                                      Can a resistor lose resistance after hot air?
                                      by MidnightRoller
                                      I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                      I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                      02-02-2022, 11:46 PM
                                    • artvandalai
                                      What resistor ohm will work better to repair this waterpik?
                                      by artvandalai
                                      The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                      01-05-2025, 04:10 PM
                                    • chth96
                                      Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                      by chth96
                                      I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                      Since then, This AC/DC adaptor have been out of order.
                                      But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                      After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                      And Is there any possibility that it will suddenly explode as well as to be out...
                                      12-03-2023, 04:40 AM
