files on CD will not open
  • arthurmason
    • Feb 2016
    Every week I do a backup of data on a CD. Today also decided to do it because of the lost data from the hard drive, but could not open the files on the drive, an external drive without any damage.
    Is there a way to recover the data?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: files on CD will not open
    Have you been checking the CDs after burning ?
    Does the data copy from the CD to your hard drive ?
      • 30964
      yes, your very unclear.
      • thomasfraser
        • Feb 2016
        Attempt to repair the damaged CDs, another methods represented on next strings
        https://discuss.howtogeek.com/t/how-...-cd-disk/26571
        http://www.quora.com/How-do-I-recove...rupted-CD-disk
        https://www.repairtoolbox.com/cdfreerepair.html CD Repair Toolbox Free
        CD/DVD get scratched due to regular use. You can use following methods to recover data. I assure you that after using these methods, you will have all your data.
        1. Clean the CD/DVD properly as dust can be a reason.
        2. Use a CD/DVD writer instead a CD/DVD reader device for such corrupted disks, because DVD writer are more powerful than DVD reader.
        3. If nothing happens, then you should opt for a third party data recovery software. This is the best way to recover data from CD/DVD/Blue-Ray disks.
        • federalhouse
          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
          by federalhouse
          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
          **Background:**
          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
          **What I've Tried So Far:**
          1. I accessed
          08-01-2024, 07:03 PM
        • tmcw
          PC case - Hard drive rails
          by tmcw
          A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
          So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
          I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
          Now, the case is a CiT Gaming Case, and...
          05-22-2022, 12:04 PM
        • madura2010
          DAY11AM6E0 hard disk drive and optical disk drive not detected
          by madura2010
          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
          i checked the connectivity of ribbon=good communication with hard and motherboard
          changed hard disk and checked=3f0 error persist
          sata power=+5v available
          Then checked data capacitors=all good
          Then checked data lines path connectivity to pch=all good
          reflashed...
          03-12-2023, 09:09 AM
        • ash91
          Hp pavilion 15 not detect hard drive
          by ash91
          Hello gentelmen .... this is my first post and sorry for my bad english,
          so my proplem is my laptop keep losing hard drive even if i but the
          hard disk in the cady (the box that can replace the dvd rom with hard disk)
          when i turn the laptop on the massage that said no boot media found pop on
          the hard disk is fine and to be sure i try another hard
          i also update my bios to the last update
          the 5 volt is present on the hard connector on the motherboard
          the dvd rom work fine when i but a windows dvd in it
          also when i boot from flash...
          06-07-2023, 01:45 PM
        • ChaosLegionnaire
          bug of the month: write caching setting for the hard drive in device manager
          by ChaosLegionnaire
          i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
          so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
          10-06-2019, 01:39 PM
