What's enhanced DPI with Laser printers?
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    My wife and I are looking at purchasing a colour laser printer. I honestly have to say I don't know a lot about them. Haven't worked on one since 2005 or so and everything I learned in college about them went out of the window. We'd like to purchase one where the drum is built into the toner. I've been looking at some of the local places that carry coloured laser printers (ie, staples) and we found a few but I had a question.
    Almost all of the ones we looked at have a DPI of 600x600. However, some of the HP LaserJets say stuff like this:
    Black Print Quality
    600 x 600 dpi
    Up to 38,400 x 600 enhanced dpi
    Color Print Quality
    600 x 600 dpi
    This is for the HP M477fnw Color LaserJet Pro MFP. It's also the same for the HP Color LaserJet Pro M452dw. My question is what exactly is enhanced DPI? I've tried searching the net but couldn't really find much on it. I'm sure the HP manuals explain it but I'm a little weary on finding the answer through them. I'm afraid it might just be B.S., trying to get people to purchase them, when in reality, it's just still 600 x 600 dpi. Any help would be greatly appreciated. Thanks!
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • Spork Schivago
    • Mar 2012
    • 4734
    Re: What's enhanced DPI with Laser printers?
    Also, I found a site a while back (can't seem to find it now) that sold generic toner for laser printers. Has anyone actually tried using generic toner with a brand name laser printer? Is it safe to do or should we stick with the brand name stuff? Thanks!
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3264
      • Singapore
      u might also wanna do your research on how long the ink tanks actually last on a particular printer model. there are hp printers out there that are ink guzzlers. dont wanna be paying and paying and tearing through ink cartridges like a squid ink drunkard.
      • Spork Schivago
        • Mar 2012
        • 4734
        Thanks ChaosLegionnaire! 2,300 for normal toner, 5,000 pages for the colour high capacity ones and 6,500 pages for the black high capacity. We'll more than likely go for the high capacity ones because there's no shelf life with toner, right? Are these good numbers for a laser printer? Thanks for the help.
        • comptek
          • Aug 2013
          • 606
          DPI = dots per inch ..... enhanced i guess means more dots per inch !
          i used to have a laserjet 5 what brilliant bit of kit that was you could shrink down a letter for example to an inch square and you could still read it .. no bleeding either
          • comptek
            • Aug 2013
            • 606
            http://www.vsellis.com/understanding...vs-web-images/
            • diif
              • Feb 2014
              • 6978
              • England
              Best thing i did was buy a second hand colour laser printer. No more clean cycles and blocked nozzles.
              What do you intend to print Spork and how much. I'd want to see the output on paper not the numbers manufacturers publish. Drums and fusers should last far more than 6500 prints, if you're buying a drum with the toner each time that seems a waste/con to me.
              Have a look at Brother, can't fault the one i bought.
              • ChaosLegionnaire
                HC Overclocker
                • Jul 2012
                • 3264
                • Singapore
                do note that if those quotes are from the manufacturer, those paper specs are highly unreliable. just like how junk cap brands bullshit their way through the cap datasheets.
                they can quote hundreds or thousands of pages but those vary with how much ink a page requires to print whatever is on it. was quoted a few thousand sheets for a certain printer but after printing less than a hundred of *ahem* "colorful" sheets of paper, the ink ran out, leaving me "high" and "dry", pun fully intended...
                • rhomanski
                  nowhere man
                  • 5157
                  • U S of A
                  I just got my first, a xerox color laser printer, Phaser 6022, they said 500 pages with the original toner and 1000 with the rest. I ordered a set from LP products. The original told me to replace the toner at 68 pages. The next set is telling me to replace the toner at 48 pages. At 1000 pages for a set of toner it would have been almost as efficient as my Brother printer. At 68 pages per set of toner that's outrageous. Even Chinese toner is twenty dollars each. Sixty dollars to print 48pages.
                  sigpicThe Sky Is Falling
                  • Compgeke
                    • Feb 2014
                    • 524
                    I'd personally recommend a Brother over an HP anymore. HP's cheapened everything down to being crap, we're at a point now where a Brother is going to be the same build quality but cheaper. Toner is generally cheaper for 'em too.
                    When it comes to the DPI, I'd assume it's something similar to interpolation and mostly useless since 300 is normal print quality anyways for publication\photo use.
                    That's just a tad odd. I know someone with a Phaser 7300 and he gets around 4000 sheets a cart. The big problem with them is it doesn't give a drum full warning and as such if you don't replace it'll dump toner everywhere inside the printer. Easy for me to fix with enough paper towels but a headache for the owners.
                    I personally got a Phaser 8550DP wax printer and so far it's been fine, just uses a bit of wax at startup (aka don't turn it off).
                      • 31158
                      for black&white, HP5 forever!
                      for colour, not so easy.
                      i was looking into this a while back and all the reviews of cheap (<300€) colour lasers said the colour rendering was poor and no good for foto's
                      ended up getting a Brother inkjet in the end with 4 seperate tanks and A3 manual feeder.
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        Yeah, I know what dots per inch is but that's where I'm getting confused. 600 x 600 DPI, but 38,400 x 600 enhanced DPI. And 38,400 x 600, that's a lot of dots per inch!
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          Thanks for the article but it doesn't seem to clear up my confusion as to what enhanced DPI is and how it differs from normal DPI. I should of been a bit more clear with my question. Sorry about that.
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            Okay, so we would want one that has a seperate drum? I don't remember what the fuser was but I take it those wear out and need to be replaced as well or are they built into the drum? The drums without the built in toner seems to be a good amount cheaper than the ones that have the toner / drum together. I didn't realize the drums lasted for so long.
                            We intend to print on laser printable transparencies to make circuit boards. We print a lot of text based stuff. It's easier for me to read stuff on paper for some reason than in digital form, when it comes to me trying to learn something, like a new programming language or how to build circuits. So I usually print them but with an ink jet, that gets real expensive real quick. The wife likes to print pictures for her family as well.
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              No shit? Yeah, they were from the manufacturer and then the sites selling them also listed the same numbers (I'm sure they got from the manufacturer). I knew there was no way for them to tell exactly how many sheets I was going to be able to print because of the reasons you listed, but I didn't think it'd be off real bad. I was thinking maybe plus or minus 250 sheets. So how much can I reasonable expect to get from a high-yield toner cartridge or does it vary from manufacturer to manufacturer?
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                Thanks for the info on HP! When I used to have access to laser printers, HP was a great name but that was a long time ago. So is everyone suggesting a Brother laser printer for me? Can anyone suggest a good model? We would like wireless networking (at least up to N) (but I guess we could settle for wired networking), full automatic duplex printing, scanner would be nice but isn't required, and a resolution of at least 600 dpi x 600 dpi. I want to be able to print real fine traces with it and 600x600 dpi seems to do a real nice job. We didn't really want to go over 500$ or so for it. Someone is helping us pay for it as a Christmas gift. A fax is alright but we definitely don't need one. Just if there's a model that has one, it's okay.
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  Was that because it was generic toner or wasn't it generic? I'm not familiar with LP Products.
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    Yeah, I want to say the HP's I used where HP5's. I also remember an older model that wasn't too bad. The 4E I think it was or something. Only black and white but they held up pretty well. That was back in 99 or so though.
                                    • Spork Schivago
                                      • Mar 2012
                                      • 4734
                                      159.99$ for this one and it's an LED laser printer!!!
                                      http://www.brother-usa.com/Printer/M...w#.VlirovmrTIU
                                      It's normally 279.99$. Think that's a good one to buy?
                                      • Compgeke
                                        • Feb 2014
                                        • 524
                                        It varies. On something like my P3005 I get an insane amount of prints, over 10,000 per cartridge. On a cheap brother B&W (HL-5140) I've done over 1000 pages off a TN-570 cart - it's rated for 6700. It is a real Brother one however, not a 3rd party.
                                        For Colour, most of my experience is with a Phaser 7300 and the colour carts in those last around 4000 sheets, printing pages with graphics and such (rather than just colour text). This is of course a far bigger and higher end unit than anything you'll find at a store.
                                        Fuser is what "burns" the toner onto the page. Basically a heater, it's what makes sure the toner sticks to the page rather than being a messy powder. They tend to last nearly forever, usually well over 150,000 sheets. Odds are you'll replace the printer before replacing the fuser unless you print 10,000 pages a month - many older printers like the LJ4000 I have are on the original 1998 fuser. My Laserjet P3005 has done a bit over 51,000 pages and is still on the original fuser and such.
                                        Separate drum really doesn't matter. You'll find it on some like Brother, Xerox and Minolta however a lot like HP have moved to drum-in-cart setup. On ones that have separate drums I've found they'll last around 20,000 pages before needing replaced.
                                        Edit:
                                        Looks decent enough. Cheaper on Newegg though.
                                        http://www.newegg.com/Product/Produc...82E16828113832
                                        • SONY_E-WASTER
                                          KONICA MINLTA C250P (laser) all prints have unwanted vertical CMYK lines
                                          by SONY_E-WASTER
                                          Hello I'm a rookie tinkerer hopping to find some knowledge about these big color laser printers and copiers.
                                          The specific model I would like to fix.
                                          KONICA MINOLTA C250P this is the printer only version of the full office photo copier. I have a one of the full office copier version for part too (that one gives an error for the yellow laser).
                                          https://photos.app.goo.gl/cwVu2KYB6Yva5Ais6
                                          I'm adding a link above to a picture of print out form the C250P with visible vertical lines of CYAN YELLOW and MAGENTA mostly on the right side of the 11x17 print....
                                          02-03-2022, 08:02 PM
                                        • Dannyx
                                          Hilti PD30 Laser Range meter Error 276
                                          by Dannyx
                                          Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
                                          So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing...
                                          07-30-2023, 05:05 AM
                                        • dansity
                                          Power DeWalt 12V laser measure from power supply
                                          by dansity
                                          i got a Dewalt laser measure which uses the 12V batteries to operate. The laser measure is faulty and I want to attempt a repair, never fixed such thing before. You might see a different topic if I fail with the repair
                                          However I do not have dewalt batteries nor want to buy one for 140EUR as the laser tool might have some chance that it is very hard to repair or unrepairable.
                                          I want to power it from my PSU.
                                          The tool has 3 input pins, on the battery it is marked with B-, B+ and ID/TH.
                                          i want to know what is the third pin exactly and what do I need...
                                          10-29-2023, 03:04 AM
                                          I would like an explanation of how a laser can measure a product on a conveyor belt
                                          by sam_sam_sam
                                          I saw this on
                                          “How do they do it “
                                          The laser was measuring the diameter and the height of the product and the weight of the product and it was a straight line laser light across the the conveyor belt ( this is all that was shown in the video clip of the laser that was used )
                                          What type of product is this that can do this
                                          I want to thank anyone that knows what of laser this is
                                          04-24-2022, 07:55 AM
                                          Modifying a Engraving Laser Module with out a TTL Module
                                          by sam_sam_sam
                                          I bought this laser module a few years ago and did not do anything with because I did not have a TTL module so it sat in project box to do something with at a later date
                                          Well the later date has happened now
                                          What I did to this module is disconnected the cooling fan and going to use with a fan temperature speed controller ( out of a surplus computer switching power supply )
                                          Well now I have found a 15 watt TTL module that I just bought from AliExpress which I should have in a few weeks
                                          Some time later when I have learned to use a laser engraver...
                                          07-25-2020, 02:26 PM
