Looking for a USB switcher for printer
  • diif
    • Feb 2014
    • 6978
    • England
    #61
    Re: Looking for a USB switcher for printer
    That's all good then Keeney
    Yes, I don't see a reason once it's configured that the IOgear would not work. It shouldn't matter how many computers are connected to it and it lists your printer in the compatibility list.
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      Thank you for your help Diif
      • diif
        • Feb 2014
        • 6978
        • England
        #63
        You're welcome Keeney
        • re-atari
          Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
          by re-atari
          Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
          Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
          02-03-2025, 06:49 PM
        • Curious808
          Brother HL-2140 laser printer: printer error (solved)
          by Curious808
          SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
          Windows 10
          Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
          Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...
          06-22-2023, 11:11 PM
        • Artefil
          HP officeJet 8012e ... A printer update will be installed to fix this problem
          by Artefil
          One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
          On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
          The screen displays the following message :
          "a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
          But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
          Have you ever...
          09-28-2023, 05:11 PM
        • прямо
          Need dump for 58mm Thermal Printer
          by прямо
          a friend gave me this printer because it's no longer working.
          It powers on, but won't do a self-test print and when connected via USB to Windows, Device Manager says No Printer Attached under USB Hubs tree.
          The red light doesn't blink either with no paper inside.
          I think the firmware maybe corrupted. If someone has a similar printer and can provide a firmware dump, I really appreciate it.
          Printer model: Panda PRJ-58U
          Flash memory: Boyamicro BY25D16ASSIG
          03-15-2024, 09:12 PM
        • bseinfo
          Brother MFC-J480DW printer stuck in maintenance mode
          by bseinfo
          I have a Brother MFC-J480DW printer stuck in maintenance mode (BHL2 USB Maintenance). The screen only shows white bars, and it’s completely unresponsive. The official Firmware Update Tool doesn’t detect it, and I’ve tried multiple versions.
          I’m looking for the raw firmware file LZ5313_L.blf (or .djf), compatible with FILEDG32.exe, so I can attempt a manual recovery.
          If anyone has a full dump of this model (or a compatible one like MFC-J485DW or J885DW), or knows a private Discord or Telegram group where this kind of firmware is shared,...
          07-05-2025, 10:53 AM
