Why is it doing this??
  • stevo1210
    • Oct 2006
    • 4156
    Re: Why is it doing this??
    Oh, and the hinge movement doesn't feel stiff either.... it feels quite normal and smooth as per usual.
    I once had a Texas Instruments TM6030 laptop and the hinges on it became stiffer and stiffer until it locked up and then cracked the plastics. Before it locked up though, it made very very loud creaking noises on opening and closing the screen.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
    • Wizard
      • Mar 2008
      • 2296
      drop few weight 30 oil on the hinge joints, on mechanical to wick oil into there since can't use grease as it had to be there during assembly process.
      In any rate, don't let it presist!! Get oil on there asap!
      Cheers, Wizard
      • stevo1210
        • Oct 2006
        • 4156
        Cheers, Wizard
        Done that and the noise is still there. I put as much oil as I could onto the joints and then twisted the hinge to rub it in. Re-Installed the hinges and that noise is still there.
        • stevo1210
          • Oct 2006
          • 4156
          I've just noticed that this creaking noise is intermittent and only exists when I put the screen more than half way (say more than 90 degrees to the chassis), if it's less then 90 degrees.... meaning a bit tilted forwards towards the keyboard, the noise doesn't exist. Only happens when screen is tilted more than 90 degrees backwards from keyboard, say 120 degrees to the chassis.... strangely enough even oil won't solve the problem. But as I said, the creaking noise is very small and only happens in the first few mm of closing, after that it's silent.
          Thanks.
          • stevo1210
            • Oct 2006
            • 4156
            I finally figured out what made the noise today. The plastics from the hinge cover and the screen surrounding were scraping against each other as they were going up and down, which is what produced the noise. There was also like a piece of minute plastic poking out of the screen cover scraping against the hinge cover so I got a small flat head screw driver and poked it so that's solved now.
            Unscrewed the rear section of the hinge cover and lifted it up just a tad and the problem went away.
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
            • Chrissygizmo
              by Chrissygizmo
              02-10-2025, 12:33 AM
            • spice_disc
              Vizio TV M50-C1 reboot cycle and static on screen
              by spice_disc
              I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
              The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
              09-08-2024, 02:37 PM
