Dell Precision T1500 8GB RAM, only 4GB usable
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    This desktop originally came in with a single 4GB stick. I replaced it with four 2GB sticks... Yet it doesn't seem to be recognizing all of it. in Windows, it shows 8.00GB (3.96GB usable) and I don't understand why. Crucial's website confirms this computer supports 16GB of RAM. I've tried two different sets of RAM sticks (four one sided and four two sided) with no difference. Latest BIOS version. Any input suggested - Thanks!
  • R_J
    • 9535
    Re: Dell Precision T1500 8GB RAM, only 4GB usable
    I take it you are using a 64 bit version of windows? is the onboard video using any of that memory? If you check Google there seems to be a lot of of this problem, but also many answers that may or may not work.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Originally posted by R_J
      Are you running 64 bit version of windows? is the onboard video using any of that memory?
      Yep, it's a 64bit Windows 7 Pro and I am not using the onboard video - I'm using a PCI-Express video card.
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3264
        • Singapore
        ok. there might be a bios setting called pci memory remap feature, memory over 4gb remapping or some such that enables or disables the remapping of overlapped pci memory above the 4gb boundary or total memory or some such. u must enable this feature when using a 64 bit os. do not mix this up with the memory hole setting which is a different thing altogether. hope that helps...
        if it still wont work or os wont boot after enabling that feature. reinstall the os. lol~ damn windoze...
        • rhomanski
          nowhere man
          • 5157
          • U S of A
          My last computer did that. Had to buy the most expensive version of windows to get it to recognize all my memory. Couldn't get any tricks to work. Seemed as if they did it on purpose to me.
          sigpicThe Sky Is Falling
            • 31015
            try a linux live disk - 64bit obviously.
            that will tell you if it's a hardware problem or a software one.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Seems like a good thing to try. I will do this and report back.
              Nope, it's a Dell - none of these options.
              7 Pro supports like 128GB or some number like that of RAM. I don't think 8GB will be pe a problem.
              • Compgeke
                • Feb 2014
                • 524
                I have a T1500 here (with Xeon X3440) and it supports 8 gigs fine. I second trying a Linux disk to see if that sees all the ram.
                • ChaosLegionnaire
                  HC Overclocker
                  • Jul 2012
                  • 3264
                  • Singapore
                  yes that is right.
                  64 bit win 7 home basic has a limit of 8gb.
                  64 bit win 7 home premium has a limit of 16gb.
                  64 bit win 7 pro, enterprise, ultimate has a limit of 192gb.
                  this is the source of this info from ms direct.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    http://en.community.dell.com/support...524/t/19492200
                    Follow the advice there (the RAM slots have to be populted in sequence if you're not using all of them among other thngs)...
                    sigpic
                    (Insert witty quote here)
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16956
                      The precision 470/670 was very fickle about this as well.
                      <--- Badcaps.net Founder
                      Badcaps.net Services:
                      Motherboard Repair Services
                      http://folding.stanford.edu/
                      Team : 49813
                      Join in!!
                      Team Stats
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Dell Precisions in general are like that. Tyan and Supermicro for the win.
                        sigpic
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16956
                          With the 470/670, it was more the chipset, the 7525 even in the SM variation was a little fickle, but nowhere near as pissy as the dell versions with their useless BIOS's, especially if using 2-rank DIMM's.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • Compgeke
                            • Feb 2014
                            • 524
                            T1500 isn't actually a real Precision. It's actually a Vostro 430 with a different model label in BIOS and different faceplate. If you can force the BIOS to error from a stuck key or whatnot it actually still says Vostro 430 there.
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              I tried just doing 2x 4GB in another T1500 and it worked fine.
                              Can I flash Vostro 430 BIOS?
                              • blasterboomer
                                • Dec 2013
                                • 135
                                • United Kingdom
                                try going on msconfig and making sure the memory isnt set to 4096mb it should be at 0 or the box should be unticked
                                • blasterboomer
                                  • Dec 2013
                                  • 135
                                  • United Kingdom
                                  msconfig.exe > boot > advanced options > maximum memory.
                                  make sure the box is unticked
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    Nope... it was just the wrong configuration of sticks. I hate OEMs :'(
                                    • teengoat
                                      • Oct 2015
                                      Compgeke, how did you get a x3440 to boot in a T1500? Latest BIOS? Or something else?
                                      Thanks.
                                      • Compgeke
                                        • Feb 2014
                                        • 524
                                        I actually didn't do anything special - I actually didn't realize until now it wasn't a factory option. Anyways, I never had to do anything BIOS wise, it just worked right away with (reported in) BIOS 2.4.0. I assume it's the latest BIOS, would never hurt to update. Factory chip on my board was an i7 940 and the X3440 came from a Z200 however that wouldn't make a difference.
                                        Here's an imgur album with a few "screenshots" of the BIOS, shows it working. For reference, the "Vostro 430" there is a Dell bug - T1500 and Vostro 430 share the same motherboard and I guess Dell forgot to change that instance. http://imgur.com/a/Jz1Uz
                                          DELL Precision 3630 Precision E-2274G Specification for Upgrade or Repair
                                          This specification for the DELL Precision 3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3630 boardview and Precision 3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          DELL Precision 3630 Precision 3000 i7-9700 Specification for Upgrade or Repair
                                          DELL Precision T5810 Precision E5-1620V3 Specification for Upgrade or Repair
                                          This specification for the DELL Precision T5810 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T5810 boardview and Precision T5810 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          DELL Precision T3620 Precision E3-1240V5 Specification for Upgrade or Repair
                                          This specification for the DELL Precision T3620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3620 boardview and Precision T3620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          DELL Precision T3630 Precision 3000 i5-8500 Specification for Upgrade or Repair
                                          This specification for the DELL Precision T3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3630 boardview and Precision T3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
