Intel DP965LTCK shutdowns and bootloops.
  • stevo1210
    • Oct 2006
    • 4156
    I assembled a computer for my brother yesterday and by today it keeps bootlooping and shutting down at random times. Sometimes it can run for a few hours without shutting down but sometime it only takes a minute after bootup to suddenly shut down.
    This is what the PC currently has:
    * Intel Pentium 4 HT 530J 3.0Ghz CPU
    * Intel DP965LTCK motherboard
    * 1 GB (2x 512MB) G-Skill DDRII RAM
    * ATI X300SE 128MB graphics card
    * Seagate Barracuda 7200.10 160GB SATA HDD.
    * D-Link 54g PCI wireless card.
    * NEC DVD+/-RW drive.
    * Dell L350N-00 24 Pin 350W PSU
    After a while I cam to a conclusion that the PSU may be a bit weak because the intel hardware monitor came up with a message after a reboot saying that the 5V line was only 4.6V. I opened the PSU up to have a look for bad caps, but there aren't any bad caps. All the caps are OST though but before I powered this system, I had this PSU powering another Pentium 4 system and that one didn't do random reboots and shutdowns.
    I also reseated the PCI cards and RAM to no effect on the system.... it still bootloops and shuts down.
    All the fans are spinning and the CPU temperature is around 48-50c on idle and 58c under load.
    A CMOS reset didn't help it either.... I loaded the defaults and that didn't help at all.
    I also inspected the Intel motherboard for bad caps and there aren't any bad caps on it. The caps on the board are:
    * Nichicon HM(M) [still fine, no bulging or leaking]
    * Rubycon ZL
    * Samxon RS
    and a few polymers around the CPU.
    The PC was fine yesterday as I could reformat it, install games, play games and install drivers. It wasn't until this morning that it went haywire.
    The system had worked fine for over six months now because this used to be my old PC until I upgraded to an Asus P5K-E with a dual core CPU. The only thing that has been changed is the PSU. The old PSU which powered this system was a Thermaltake XP550NP 430W. I have heard that the Thermaltake XP550NP 430W is worse than the Dell PSU currently in the system from this thread: https://www.badcaps.net/forum/showthread.php?t=3096
    The Dell PSU also weighs much more than the Thermaltake XP550NP. The caps in the Dell PSU are also larger and have a higher capacitance.
    I've enclosed some pictures of the Internals of the Dell PSU as well.
    Does anyone know what could be wrong??
    Thanks.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • stevo1210
    • Oct 2006
    • 4156
    Re: Intel DP965LTCK shutdowns and bootloops.
    I just left the system in the BIOS hardware monitor and the 12V rail dropped to about 11.46V and after half a second, the system just shut off and bootlooped continuosly.
    My brother also said that yesterday when the PC was still OK, he could hear a very small clicking type of noise from the area where the PSU is. I'm trying to figure out what the faint clicking noise could have been.... any ideas??
    Thanks.
    • zandrax
      Hit and miss
      • Dec 2007
      • 1157
      • Italy
      Try swapping the psu: you should diagnose if it's a power supply or an other component fault.
      If it stills has problems after swapping, try booting the minimal system: board, cpu, a stick of ram and psu. If it boots, you should add other ram sticks, the hard disk, the cd player and pci cards unless you get instability. If it doesn't boot, it's more likely a board, cpu or ram fault: you can isolate the troblesome component by trial and error (e.g. swap the ram, try another cpu, ...).
      If you manage to get a stable system, update mobo's bios to the latest one, the 1718: it' recent (december 2007) and last updates are more cosmetic updates than real bug corrections, while the whole 16xx series is full of fixes.
      Zandrax
      Have an happy life.
      • stevo1210
        • Oct 2006
        • 4156
        I just booted the system with only the board, CPU, RAM and graphics card and the 12V rail got to about 10.75V and then it shut down. Is 10.75V a bit too low for the 12V rail??
        Thanks.
        • zandrax
          Hit and miss
          • Dec 2007
          • 1157
          • Italy
          Thanks.
          It's dangerously too low: it should never be lower than 11.4 v. Swap the psu.
          Zandrax
          Have an happy life.
          • starfury1
            • May 2006
            • 1256
            yes stevo if it was working fine with old psu, check the voltages on that and just use it if they are in spec.
            Sounds like the Dell is not cutting the muster there mate
            It may have something wrong with it the Dell so if you still got the box as it was that it was powering Id recheck the voltages in that one with it.
            It possible the Dell has unstable regulation due to possibly borderline caps
            (not talking DC output caps here) or something else affecting it.
            The Dell might be a better supply but it ain't worth jack if its faulty
            possible the Dell might be overloaded but from the previous post I think it was consider ok wattage wise to run your old system
            so refit the Thermaltake and check what it says to be sure on your now brothers machine
            err hope the above makes sense?
            You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              psu is bad.
              change out the hn/hm caps too.
              btw ost are crap too.
              • starfury1
                • May 2006
                • 1256
                well that puts it simply thanks KC8
                just noticed "liteon" on the pcb
                • stevo1210
                  • Oct 2006
                  • 4156
                  I changed the PSU today. The replacement PSU is also a Lite-on PSU with a 24 pin ATX connector.... but the new one is only 300W. The replacment PSU is second hand and looks to have come from an Acer system as there are Acer stickers on it.
                  So far the PC has been fine and hasn't bootlooped or shutdown.
                  Thanks.
                  • starfury1
                    • May 2006
                    • 1256
                    good one
                    so your other is a dud
                    • zandrax
                      Hit and miss
                      • Dec 2007
                      • 1157
                      • Italy
                      That's what matters!
                      Thanks.
                      Don't mention it.
                      Zandrax
                      Have an happy life.
                      • Sergejs A
                        Asus FA617NS bootloops
                        by Sergejs A
                        Picked up FA617NS laptop from bin 😀
                        Have situation were it fails to boot windows/linux for random set of times and then boots and works like nothing happened.
                        You can shutdown it and then if it powers on via fast start it works, but if you reboot it boot loops is here again.
                        Changed thermal paste with pads, changed ssd, changed memory
                        Battery are in bad shape, but disconnecting connection it changes nothing.
                        Noticed that when it lags, it does not react to power button correctly and sometimes lags in bios.
                        Decided to reflash bios, to...
                        04-23-2025, 09:20 AM
                      • h0m3w0rk
                        Random Shutdowns/Startup Failure with Corsair SFX 450
                        by h0m3w0rk
                        I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                        For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                        02-09-2025, 03:19 AM
                      • Kei.Kurono.931
                        Lenovo Thinkpad W541 Shutdowns after bios flash (removing BAP)
                        by Kei.Kurono.931
                        Hi. I have a Thinkpad W541 that i was trying to remove the Bios Supervisor Password using this guide. https://www.badcaps.net/forum/showthread.php?t=87588 LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
                        I have the old bios backup but when i restored the original bios the laptop shutdowns after a few seconds and can´t load Windows.
                        - Using a CH134a + SOIC 8 Clip + Colibri 1.0.1.61 i backed up the original bios 3 times and verified all of them were the same.
                        - Used the Lenovo Bios Auto Patcher applied the patched file to the chip and verified...
                        03-19-2021, 05:43 PM
                      • manubali
                        [Help] LG 49LH570T Random Shutdowns
                        by manubali
                        Hi, i was wondering if anyone can help me troubleshoot LG 49LH570T tv, initially it came for no power issue, but after leaving everything unplugged overnight, it started working in the morning when i was about to start diagnostics process.
                        It will turn on for 10 minutes and will die afterwards, and when i try to turn it on, a solid red LED will come up for few seconds, followed by two short blinks and then it completely shutdown, i have examined power supply and main board for visible damage or shorts, but its all fine.
                        The power supply PCB number is EAX66851401 REV 1.0.
                        One...
                        09-21-2023, 06:44 PM
                      • AresROC
                        Thermaltake TR2 Bronze 600w low 12v voltage
                        by AresROC
                        https://www.amazon.com/gp/product/B00NW6W2C8
                        I have a Thermaltake TR2 80+ Bronze that's been doing strange things. It would cause the computer to shot down randomly, and measures low voltage on the 12 volt rail. From 11.5 to 11volt.
                        I put it on the bench with a harddrive as load, and it outputs fine with low load:
                        5v - 5.17v
                        12v - 12.17v
                        It has all Japanese caps, but only 1 large cap for the Input supply. No obvious signs of overheating burns or bulge. Anyone know where I should start to troubleshoot? I guess I don't want to just start by replacing...
                        12-02-2021, 02:07 PM
