What are these called?
  • gastorgrab
    • May 2007
    • 320
    What are these called, exactly? The other thread seems to have disappeared so i'll try to be brief.
    Is it a two-row, 20 pin, IDC cable recepticle?
    Is it a 40-pin, 2-row insulated header?
    I'm trying to order a replacement for a board and i cant figure out the correct terminology to use.
    It seems that the second IDE connector was never soldered at all. None of the surface mount components have moved and there is no discoloration of the board but the pins are all still brass colored.
    The solder on the individual pins looks like this;
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: What are these called?
    40 pin ide header?
    • gastorgrab
      • May 2007
      • 320
      I guess my last post didn't make it.
      Can i assume that i'm looking for a 40-pin, two row, header with 2.54mm pin spacing and row width?
      I see a bunch that have exatly that but either don't have the index slot or that have a different type indexing holes.
      Anyone have a part number? (digikey)
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Idc40-m
        Mann-Made Global Warming.
        - Dr Seuss
        • gastorgrab
          • May 2007
          • 320
          Originally posted by PCBONEZ
          Idc40-m
          That looks correct to me, but Digikey wants $93.66 for only one of those.
          http://search.digikey.com/scripts/Dk...me=288-1353-ND
          Digi-Key Part Number: 288-1353-ND
          Manufacturer Part Number: IDC-40-M
          • zandrax
            Hit and miss
            • Dec 2007
            • 1157
            • Italy
            Wrong pick: this is a DIN Rail Mounted Interface Module. Always look for its datasheets before buying.
            Let me search.
            Zandrax
            Have an happy life.
            • gastorgrab
              • May 2007
              • 320
              Another search at Digikey or 'IDC' left too many options. I don't know the trade names for any of the listed 'locking/latching mechanisms'.
              A search at Mouser was a lot easier to narrow down.
              The top illustration in this document looks very close:
              http://www.mouser.com/Search/Product...mwim2A6w%3d%3d
              Mouser Part #: 649-66506-053LF
              Manufacturer Part #: 66506-053LF
              $2.45 is cheap enough to experiment with
              Thanks!
              • zandrax
                Hit and miss
                • Dec 2007
                • 1157
                • Italy
                Digikey doesn't sell them: I've found some Ide & Sata cables and Sata connectors, but not Ide/Ata ones.
                Zandrax
                Have an happy life.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  I don't understand why you don't just put the one you have back together and solder it in.
                  - Dr Seuss
                  • gastorgrab
                    • May 2007
                    • 320
                    Initially i thought it might be nice to replace it with a 90 degree connector. It turns out that the index slot is on the wrong side to do something like that (the connector would face the wrong way). After looking at the pins under a hand held microscope i stated to wonder if there was a good reason that the original solder bonded to the IDE1 pins but almost not at all to IDE2 connector pins.
                    Could it be possible that somehow the factory didn't plate the solder ends of these pins with tin (or whatever preparation they might use)?
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      That's possible.
                      There are always mistakes in anything mass manufactured.
                      - Dr Seuss
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        You should be able to press the pins back into the plastic and reassemble it.
                        Then solder it in properly by hand.
                        - Dr Seuss
                        • gastorgrab
                          • May 2007
                          • 320
                          Hey, i needed some new caps anyway.
                          It's an extra board so there's no real loss if i toast it.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            For the 90 degree.
                            There should be connectors somewhere that face the other way.
                            Also it's not that hard to modify one to get what you want.
                            Pull the pins out of the plastic.
                            Flip the plastic piece.
                            Put the pins back.
                            You will only have to be creative for one pin.
                            - If it's too long clip it.
                            - If it's too short then solder a left over lead scrap from a cap to it (not while it's in the plastic) and make it long enough.
                            - Dr Seuss
                            • gastorgrab
                              • May 2007
                              • 320
                              Put the pins back
                              True. I've already proved to myself that the pins slide right out.
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Just remember to keep it true to the pin-out on the motherboard. !!!
                                Easy to get confused when flipping pins in connectors around.
                                You can usually get maybe 15 degrees tilt out of a straight pin version by simply soldering it in at an angle. You know. Pins on one side longer than the other.
                                - Dr Seuss
                                • gastorgrab
                                  • May 2007
                                  • 320
                                  I'm re-thinking the need for a replacement after the previous board, that was in good physical shape, didn't work.
