Looking for a better PSU
  • pentium
    • Mar 2006
    • 2778
    Well in order to upgrade my video card (or anything in my system to that matter) I need to replace my 430W Thermaltake PSU.
    On top of my planned new card, my system has other power hogging luxuries like:
    -18 USB 2.0 ports
    -4 Firewire ports
    -The Live! Drive
    -A dvd drive
    -Two floppy drives
    -Two hard drives (130 gig Seagate and a 40 gig Maxtor)
    -A panasonic Magneto-optical drive
    I need something with LOTS of power but still at a good price.
    Do you guys have any ideas?
    Find Nedry!
    Check the Vending machines!!
  • stevo1210
    • Oct 2006
    • 4156
    Re: Looking for a better PSU
    Have you looked at the FSP bluestorm series? The 550W edition costs about $100AUD.... I don't know how many canadian dollars that is.... but I'd guess it be simlar in Canada.
    Another PSU you could look at is the Antec Basiq 500W series. They cost about $80AUD here in Australia.
    I think both of them should sufficient for your new graphics card and the accesories you have on your PC now.
    If you want something more powerful, I'd suggest a Seasonic S12 600W series PSU. They are expensive, but they have good caps and also a nice finish on the outside.
    • pentium
      • Mar 2006
      • 2778
      I'll look for a bluestorm first and Antec last.
      Those power supplies seem potent enough to work in my system.
      Find Nedry!
      • stevo1210
        • Oct 2006
        • 4156
        Sorry Pentium, I got this part wrong. The FSP Bluestorm is a 500W PSU. Not 550W for $100AUD.
        • stevo1210
          • Oct 2006
          • 4156
          Another PSU that you could look at is the SilverStone ST50EFP 500w series PSU. It costs $110AUD here in Australia. After looking at some internal images of this Silverstone unit, I'd have to say that is is built very well.
          • pentium
            • Mar 2006
            • 2778
            Hmm.
            The PSU costs the same around here and it looks pretty good but is it able to support my whole system? The video card alone is recommended to be used with a 450W PSU at the minimum.
            Find Nedry!
            • gonzo0815
              • Feb 2006
              • 1600
              What kind of video card do you want to put in your system, that an 450w PSu would not be plentiful of whats?
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                When asking for power supply recommendations, you need to quote all of your system specs. If you're running that stuff on a Celeron 500mhz, your current supply is fine. If you're running it with current-gen hardware, it may be lacking.
                I run my entire system on a 350 watt sparkle PSU. Specs are:
                AthlonXP 2200+
                2x 512mb DDR400 RAM
                1x Seagate 250gb SATA main drive
                1x Maxtor 200gb IDE backup drive
                GeForce 6600GT (requires one 4 pin molex connector)
                Standard Lite-on IDE optical
                Adaptec SATA RAID PCI card
                Front and rear case fans
                Never had a lick of trouble, even with overclocking and gaming. Plenty of power to spare.
                Ludicrous gibs!
                • pentium
                  • Mar 2006
                  • 2778
                  This Card.
                  Athlon 3000+
                  1x 256mb DDR400 RAM
                  1x Seagate 130gb ATA main drive
                  1x Maxtor 40gb IDE backup drive
                  ATI Radeon 9600XT
                  Standard Creative IDE optical DVD
                  Adaptec SCSI PCI card
                  I didn't go with the normal specs as my peripherals (mostly the USB) suck up quite a bit of juice.
                  Find Nedry!
                  • dood
                    Deputy dood
                    • Mar 2004
                    • 2462
                    If you're worrying about performance, my recommendation would be to upgrade the memory before you worry about the video card.
                    Ludicrous gibs!
                    • shadow
                      • Feb 2007
                      • 732
                      Popping in a gig of memory will not cost much (nowadays) and performance will be much much better. 256mb is not considered much now with more modern games. Windows will also behave much better and it wont be swapping data to the hard disk all the time. I presume that you are planning to play games on this system considering you want a fairly powerful graphics card.
                      Ideally you would upgrade both the graphics card and memory at the same time.
                      • gdement
                        • Jan 2007
                        • 690
                        Newegg has a 700W Hipro for $100, and lots of FSP's including a 500W for $78. The bigger FSP's seem to get very expensive though.
                        I've been happy with both of those brands in the past, but haven't had any experience with the bigger units in question.
                        The comments on the Hipro say it's very large, so you need lots of room in the upper part of your case.
                        • pentium
                          • Mar 2006
                          • 2778
                          That's my temporary stick of ram.
                          I let a friend borrow my two gigs and a week later he returns them to me saying that they didn't work with his DDR2 ram (that's right, they were fried. )
                          I think I have room.
                          Find Nedry!
                          • shadow
                            • Feb 2007
                            • 732
                            What a bum!!
                            So he basically forced your RAM into his system even thou the notch is in a different location and it does not want to go in. He obviously did not realise that DDR2 memory has around 2x the amount of pins as normal DDR memory as well.
                            In short I would be very pissed off.
                            • pentium
                              • Mar 2006
                              • 2778
                              :rambo:
                              Oh I am pissed off and he knows it as he has been avoiding me ever since I phoned him. He knows that I want to kill, gut, quarter and sell him to pay back for the ram he killed.
                              Find Nedry!
                              • gonzo0815
                                • Feb 2006
                                • 1600
                                This card is really somehow power hungry
                                The GFX chip and rest of the card are using about 135w in 3D mode, the included TEC will use additional 75w (is this really needed or only a gimmick?).
                                The TEC is exclusively powered from the 12v rail, which would translate into 6.25A.
                                If we assume the 135v would feed exclusively from the 12v rail too, then this would translate into additional 11,35A.
                                Combined together it would be a healthy ~16.5A load at the 12v rail in worst case.
                                But may be, the card is using the AGP port at it`s limit, wich would be AFAIR ~70w to 80w.
                                Then the card would only draw 5.41A from the 12v rail.
                                To be on the safe side, i would use an 12v regulated PSU with about 26A at the 12v rail.
                                This would equal to 320w@12v with CPU, HDD`s and DVD.
                                A solid ~400w psu should fit your needs, but you need at least 17A per rail and two PCI-E plugs.
                                The be quiet Straight Power 450W would fit your needs, other PSu`s may have only one PCi-E plug or limited power per rail (if it is really limited..).
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  The drive connectors on he card are what help reduce the stress on the AGP port.
                                  Cards like these were desighed for PCI express but have a bridge installed so you can run them on AGP with a minimum performance loss however it means that the card will require another way to get power since the AGP port can't handle it so instead of pulling a 3DFX (what was he name of that four GPU card they made that had the external power supply?) they just made it so you can hook a regular drive power connector to the card.
                                  Find Nedry!
                                  • gonzo0815
                                    • Feb 2006
                                    • 1600
                                    Yep, that`s right, but you can`t know, if they use the AGP ports maximum power capability or if they are completely switched to the 12v feeding.
                                    You need two PCI-E 6pin plugs to feed this puppy. One is for the TEC supply, the other is for the card.
                                    At the time of 3dfx i was a good idea to use a external PSU, as the ATX ones from that time where in most cases not capable in deliver any clean voltage.
                                    • dood
                                      Deputy dood
                                      • Mar 2004
                                      • 2462
                                      Voodoo 5 6000 FTW!
                                      http://en.wikipedia.org/wiki/Voodoo_5_6000
                                      Ludicrous gibs!
                                      • pentium
                                        • Mar 2006
                                        • 2778
                                        Yeah, That was the card I was thinking about.
                                        By the way, I don't think they fully used the voltage output from the AGP port. I think they left a little room.
                                        Find Nedry!
                                        • eccerr0r
                                          It's 2025: do you know where your 5¼" floppy drives are?
                                          by eccerr0r
                                          Oh wow.
                                          As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                                          Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                                          Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                                          Weird. Seems the PC drive is having trouble clamping...
                                          07-07-2025, 12:49 AM
                                        • eccerr0r
                                          failing hard drives after sitting for years...
                                          by eccerr0r
                                          With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
                                          Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
                                          Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
                                          03-02-2023, 10:33 AM
                                        • abajor
                                          Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
                                          by abajor
                                          I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
                                          I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
                                          The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
                                          Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
                                          04-23-2024, 11:43 PM
                                        • ChaosLegionnaire
                                          what to do with faulty hard drives?
                                          by ChaosLegionnaire
                                          i have several dead/bricked (not detected, doesnt show up or making constant clicks of death) and faulty bad sector hard drives. im moving house soon and need to get rid of some dead weight.
                                          i thought of selling them for parts or not working but they are quite heavy and shipping each drive internationally via local post is US$23 each. im using some of the drives as gym strength training dumbells by putting 4 of them in a box to make a 3kg dumbell. but since im moving i cant carry the deadweight with me. any ideas what to do with them that is cost-effective for ppl like me...
                                          11-25-2021, 02:42 AM
                                        • goodpsusearch
                                          Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
                                          by goodpsusearch
                                          Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
                                          First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
                                          05-05-2024, 02:04 PM
