In need of a reliable PSU
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: In need of a reliable PSU
    Originally posted by gastorgrab
    This cant be good;
    Most new motherboards don't use -12v anyway, and software voltage monitoring is never accurate.
    I wouldn't worry about it.
    A man convinced against his will is of the same opinion still.
    • starfury1
      • May 2006
      • 1256
      I know the thread has moved on but thought Id add this anyway
      Corsair PSU's are made by Seasonic,
      Not all models are of Seasonic build from what I understand
      HX620W is and I think the HX520W too
      The VX TX is apparently CWT build
      ( using chemi-con KZE series by the looks of it from photos)
      Still, from what I understand a solid build
      anyway as was said before, check the reviews over at Jonny Guru's
      info above got from JG's reviews
      Cheers
      You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        The -12v supply must be loaded to get within spec
        Which still allows for +/- 20%
        Only serial ports AFAIK use the darn thing anyway... Guess it might be routed to the PCI ports aswell but I doubt it
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          If the PCI or PCI-X is a 5v version (32 or 64 bit) then -12v goes to it.
          If it's a 3.3v version it doesn't.
          Mann-Made Global Warming.
          - Dr Seuss
          • DXseekerMO
            Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
            by DXseekerMO
            Hello everyone!
            Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
            I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
            Yes
            0%
            1
            All backlight strips are the same quality
            0%
            1
            No
            0%
            0
            12-16-2021, 03:58 PM
          • iMic
            Vintage AT Power Supplies - Selecting Capacitors
            by iMic
            Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
            The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
            02-19-2023, 06:45 PM
            Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
            by sam_sam_sam
            So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
            The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
            You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
            09-07-2024, 07:26 PM
          • ckrtech
            Help Identify cap brand and quality, please
            by ckrtech
            This is a cap on a motherboard from 1994. “Ark” is the only brand I know of that has an A inside a rectangle, but I wanted to run it by you guys and get any thoughts on quality.
            Thanks in advance....
            06-09-2025, 12:28 PM
          • DrewPhillips
            SFX PSU - Need High Current on 3.3V & 5V Rails?
            by DrewPhillips
            I have an older system which was built in the Windows 7 era and which has developed, I suspect, a power supply problem. The system had the same problem, random crashes, a couple of years ago, which I subsequently remedied with a new power supply.
            The power supply which came with the machine is a no-name "Safe Power PE-300". It is SFX form factor and claims a high current capacity: +3.3V @ 22A and 5V @30A (the +12V rail claims a meager 16A). Problem is that SFX supplies (or even ATX supplies for that matter) having high current ratings on the 3.3V and 5V rails seem to be...
            02-18-2025, 01:03 PM
