Dell inspiron 531 fans constantly blowing hard
    • 31058
    Re: Dell inspiron 531 fans constantly blowing hard
    there is a bios setting for the cpu fan usually.
    btw,
    can you feel air coming out of the back of the power supply?
    that's another fan to check!
    • Vivi
      Banned
      • Sep 2014
      • 101
      can you tell me exactly, if possible? And I can feel calm air coming from the back.
      Also, I little off topic, but I must ask, is Windows 8 all what it seems to be? Is it recommended? Not that I could afford it anyways, I want to know.
        • 31058
        it's the plague on steroids.
        as for the fans, you have 2 on the back of the case - one is in the power supply - can you feel air blowing out near the power cable?
        and if you can - is it warm?
        a foto of the back showing that area would be good.
        • Vivi
          Banned
          • Sep 2014
          • 101
          Oh, yes, the air coming from the vent next to the power cable is warm, and the lower vent's air is cool. The photo will have to wait, for some reason, my camera is showing up so dark, even with all the light.
          Do you use Windows 8 yourself?
            • 31058
            i dont use any windows.
            i use http://www.mageia.org/en/
            btw, the reason the air feels cool on the other fan on your case is because unless it's been changed since your foto, it's sucking in.
            • Vivi
              Banned
              • Sep 2014
              • 101
              Oh my! I never heard of it.
              I didn't know I could feel air being sucked in.
                • 31058
                http://distrowatch.com
                the fan has to pull the air past your hand - so you feel it.
                • Vivi
                  Banned
                  • Sep 2014
                  • 101
                  Interesting tell me more...
                    • 31058
                    just try it.
                    that iso link i posted in the other thread - download it and burn it to a dvd or put it on a usb stick & boot from it.
                    you should read this: https://en.opensuse.org/SDB:Create_a..._using_Windows
                    pics - https://www.opensuse.org/screenshots.php
                    • TractorGear
                      • Mar 2015
                      • 40
                      Did we decide this was a desktop or a laptop?
                      Thermal compound at CPU/HSF interface?
                      GPU seems hot to me with that CPU load.
                      I'd wonder what else might be running in background.
                      OP, is there any chance you are infected? Sometimes malware runs your CPU up to 100%. Can you post a screen shot showing Task Manager showing your running processes?
                        • 31058
                        it's a desktop,
                        looks from the foto's to by running a seperate gfx card and standard ATX form-factor psu - luckily.
                        go look in the other thread.
                        https://www.badcaps.net/forum/showthread.php?t=44789
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          #32
                          look at that picture, plenty of dust clogging
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            #33
                            I missed the photos in the other thread, yes there's lots of dust under that cpu fan on top of the heatsink.
                            I'd carefully remove the fan off the heatsink then collect up the dust with tweezers. Careful to mind which way the fan is blowing and attach back the same way.
                            DO NOT VACUUM, i have fixed to many dead computers that people have vacuumed, the static will kill.
                            The improvements in speed an the OS tweaks are not enough for me to upgrade to Windows 8,and it's schizophrenic nature is just off putting.
                            • Vivi
                              Banned
                              • Sep 2014
                              • 101
                              There is one program that takes forever to load up at startup log in: AMD catalyt control center. Always takes the longest, but doesn't like freeze the computer anything, but still, it takes too long, look its still not up and loaded and its been 10 minutes!
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                #35
                                Have you got the latest CCC installed ?
                                • Vivi
                                  Banned
                                  • Sep 2014
                                  • 101
                                  I believe i do, how to check?
                                    • 31058
                                    go to amd.com and see what the latest version is.
                                    • Vivi
                                      Banned
                                      • Sep 2014
                                      • 101
                                      Yes, I have the lasest version, so thats why its taking so long to load up? like it is right now?
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        #39
                                        No, but checking the latest version of software/drivers is always the first thing to check.
                                        • Vivi
                                          Banned
                                          • Sep 2014
                                          • 101
                                          It certainly is the newest veriosion
                                            DELL Inspiron 3470 Inspiron 3000 i5-8400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3470 boardview and Inspiron 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:44 PM
                                            DELL Inspiron 3250 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3250 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3250 boardview and Inspiron 3250 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            DELL Inspiron 3650 Inspiron i5-6400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            DELL Inspiron 3650 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
                                            DELL Inspiron 3268 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3268 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3268 boardview and Inspiron 3268 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
