Help with basic router config
  • binsonk
    • Apr 2014
    • 182
    I have a Linksys BESFR41 v.2 router that is apparently throttling my hardwire broadband. What is the fastest throughput I can expect from this router? I have read where it will throughput 6 Mps. I looked at the settings by putting the IP address in the browser. The settings look ancient, and I didn't see anything I could tweak. Okay, alternatively, I could use a Linksys WRT54GS or WRT54GS v2.1, or ubee DDW3610 dual stream n. I have a stupid question. I only use a wired connection, and the latter three routers are wireless. Will these routers broadcast a wired connection? How do I make sure they are not broadcasting a wired connection? As long as these wireless routers are powered, are they not broadcasting, and therefore do I need to encrypt the signal, even if I am using only the wired connection?
    • 30978
    Re: Help with basic router config
    you can turn wireless off in the settings - by default it's probably on but encrypted.
    i recomend taking the WRT54's and flashing them wih DD-WRT
    http://www.dd-wrt.com/site/
    • SteveNielsen
      Retired Tech
      • 2327
      It's confusing so I'll try to clarify some. Network speeds are usually measured in Mbps (mega-bits per second), file transfer rates are often given in MBps (mega-bytes per second). The big or little B makes all the difference; B = bytes, b = bits. 1 byte = 8 bits. On a fast ethernet circuit the maximum speed is 100 Mbps. Assuming you mean 6 mega-bytes per second, that would be 48 mega-bits per second, which on a fast ethernet (100Mbps) is about average performance. You will never get a full speed of 100 Mbps due to bandwidth used by the network protocols and timings (also called overhead). You'd be doing pretty good on a home network to get about 2/3 of the max rate, around 66 Mbps (8.25 MBps).
      On the Linksys routers you can turn off the radio if you're not using wifi. The Ubee router has 1000 Mbps ports so if your end nodes support that speed your troughput should increase by 10x using that one. I don't know if the Ubee radio can be disabled or not but I imagine so. If not you can probably just leave the wifi unconfigured and it won't talk to anything.
      You DO need to at least password protect your router though.
        • 30978
        mind if i ask what your doing?
        the BEFSR41 is just a hub,
        the WRT54's are ADSL and the Ubee is DOCSIS.
        your not using these for getting on the net are you?
        • SteveNielsen
          Retired Tech
          • 2327
          Lynksys says the BESFR41 is a Cable/DSL router with 4 port switch.
          • binsonk
            • Apr 2014
            • 182
            I've only set up the Linksys BEFSR41, as a router, for internet. I used it to allow more than one device to use the cable modem. This new modem, which is a downgrade from 15 Mbps to 6 Mbps, has 4 or 5 ports in back, so maybe it doubles as modem and router, which is the way I'm using it now without any problems.
              • 30978
              @Steve:
              read the manual - it has 5 10/100 ports and needs an external modem.
                • 30978
                @binsonk:
                the Ubee is DOCSIS3.0 compatable.
                so it can run over 150mbit on the cable side.
                flash the wrt54's with DD.
                what is your cable modem model/make?
                • binsonk
                  • Apr 2014
                  • 182
                  ubee DDW36C. I'm renting it, can't modify it.
                  • SteveNielsen
                    Retired Tech
                    • 2327
                    You said:
                    "the BEFSR41 is just a hub"
                    It is not a hub. It is a wired router and switch with a WAN port and 4 LAN ports.
                    @Steve:
                    You read it. It is not a modem and it has no wireless. That doesn't make a hub. It is still a router and switch.
                    http://support.linksys.com/en-us/sup...outers/BEFSR41
                      • 30978
                      it's a 5 port hub with a shitty firewall.
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        It's a mistaken opinion with a shitty attitude. A hub is not a switch and I think that you know that.
                          "the BEFSR41 is just a hub," Really? I must be using it all wrong then.
                          http://kb.linksys.com/Linksys/ukp.as...a1b_20875.xml&
                          I have one myself.
                          From Linksys:
                          " What is the BEFSR41?
                          The BEFSR41 is a Linksys EtherFast Cable/DSL Router with 4-Port Switch. The Router lets you access the Internet through its four switched ports. The device also contains security features including, a Stateful Packet Inspection (SPI) firewall and NAT technology."
                          This is reminding me of the Greek.
                            • 30978
                            sales hype aside,
                            if it does not have an ADSL/VDSL or DOCSIS port then it's just a relativly intelligent hub.
                            anyway, getting back to the topic, if binsonic knows his modem settings or has access to them in his modem, then he should just be using the Ubee DDW3610.
                            if he cant get the settings and must use the isp modem then the wrt54gs with DD installed will be a much better option than shitty linksys firmware.
                            • binsonk
                              • Apr 2014
                              • 182
                              I'm getting nominal download (6.43 Mbps) and upload (1.09 Mbps) speeds using the modem and its ports, so I don't see why I should bother with a router, except for security reasons perhaps. I am just embarrassed that I allowed that old Linksys router to throttle my internet for so long.
                                • 30978
                                the problem is some of the older routers have a weak cpu and combined with crappy factory firmware the routing and firewall stuff can reduce the speed between the ports a noticeable amount.
                                the reason i said to use the newer docsis router is because it's going to have a much faster cpu to handle the faster ports.
                                also you would only be running one box insead of 2.
                                the WRT54's are a bit old, but the replacement firmwares - DD being the most common make it a very good piece of kit.
                                there is also this one.
                                http://www.polarcloud.com/tomato
                                • double_DD
                                  Why does my ISP router hate my "homemade" power supply??
                                  by double_DD
                                  It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                  So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                  For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                  07-12-2025, 03:09 AM
                                • DynaxSC
                                  ASROCK Z270 GAMING-ITX/AC - IR35201 - NEED THE VRM CONFIG FILES
                                  by DynaxSC
                                  I have an ASROCK Z270 GAMING-ITX/AC motherboard with a fried VCORE controller IR35201 (International Rectifier, currently Infineon).
                                  This chip is unfortunately programmable, so after replacing the chip, it needs to be programmed with a config file, which I do not have, as the chips is not readable any more (total short on power supply pin).
                                  Some of you maybe know, it is possible to read out the config file from a board with a working chip using the USB005 I2C adapter and IR/Infineon software called PowIRCenter. The software is available freely at Infinion...
                                  02-10-2025, 04:52 PM
                                • EasyGoing1
                                  UPNP, "Standards" and hardware that implements it
                                  by EasyGoing1
                                  I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                                  One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                                  So I decided to implement UPNP...
                                  07-16-2022, 07:12 PM
                                • shadow666
                                  Router Xiaomi M4A Gigabit
                                  by shadow666
                                  hello
                                  i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                                  Mi Router 4A Gigabit Edition
                                  ROM CHIP is 16 MB
                                  i attached picture of motherboard​...
                                  11-30-2024, 03:49 PM
                                • Hornnumb2
                                  Home routers
                                  by Hornnumb2
                                  Is it just me or does it seem like the routers just dont last anymore. It seems like about 1 1/2 years mine starts dropping signal and losing connections. I am not buying the cheapest but middle of the road around $100. Any suggestions for one that will last? Thanks Michael
                                  07-01-2024, 07:36 AM
