Dell inspiron 531 4gb ram 64 bit OS running very slowly
    • 30928
    Re: Dell inspiron 531 4gb ram 64 bit OS running very slowly
    create a new user and try with that one.
    • Vivi
      Banned
      • Sep 2014
      • 101
      Just did, I have two users now, and for reason, its loading up fast now. Without freezing, I'm on the new user now. Again, is this weird?
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        #103
        It points to the hard drive being bad, please try to enable SMART in the BIOS
        And as has been adviced before it would be a good idea to try with another SATA cable to the harddrive.
        • Vivi
          Banned
          • Sep 2014
          • 101
          I can enable SMART in Bios, though that would require rebooting, so, I must prepare for the "snail like" loading time... I'm doing this now.
          That SATA cable is confusing me though. I have no idea what it is.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4913
            • New Zealand
            #105
            When you reboot, login to the new user account. We need to know if you get the slowdown problem on a new account after a reboot.
            Logging off and logging on after it's all up and running doesn't prove if it's the account or the computer.
            The SATA cable is the data cable for your hard drive, which uses the SATA interface as shown by your photos.
            -David VanHorn
            • Vivi
              Banned
              • Sep 2014
              • 101
              Okay I logged in on the new user, and... ehm, it loaded alot faster than it did the previous user. I'm on the new user now. I enable SMART in BIOS too. I now know the SATA cable.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                #107
                Good, now run this test again: https://www.badcaps.net/forum/showpo...0&postcount=26
                And post the details from the HEALTH page: https://www.badcaps.net/forum/showpo...8&postcount=49
                • domas
                  News Hater
                  • May 2013
                  • 323
                  • Denmark
                  #108
                  run as administrator:
                  chkdsk C: /f
                  y
                  reboot
                  then again as admin:
                  sfc /scannow
                  reboot
                  • Vivi
                    Banned
                    • Sep 2014
                    • 101
                    Nothing still not showing under Health tab:
                    • TVRepairNoobie
                      • Feb 2015
                      • 158
                      Vivi,
                      Click [Start] the type: cmd in the search box, right click on cmd.exe then select run as administrator
                      That will open up DOS screen then type the following commands to check disk for errors
                      chkdsk /r /f [press Enter]
                      you will be prompted with with something like below
                      C:\Users\BADCAPS>chkdsk /r /f
                      The type of the file system is NTFS.
                      Cannot lock current drive.
                      Chkdsk cannot run because the volume is in use by another
                      process. Would you like to schedule this volume to be
                      checked the next time the system restarts? (Y/N)
                      NExt, click [Yes] then reboot your computer....it'll take a while to scan and fix the disk.
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #111
                        Ok, it's probably because of your "NVIDIA nForce Serial ATA Controller", it's using a SCSI implementation and so SMART data can not be read.
                        What you enabled in the BIOS was probably for the "Standard Dual Channel PCI IDE Controller"
                        You can actually disable that whole IDE controller in the BIOS if possible, because I see from your photos there is no IDE connector, only an empty spot for one...
                        • Vivi
                          Banned
                          • Sep 2014
                          • 101
                          Originally posted by TVRepairNoobie
                          Vivi,
                          I ran chkdsk before, twice actually, and I saw no difference.
                          How do I disable "Standard Dual Channel PCI IDE Controller" in BIOS?
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            #113
                            It would be something along the lines of "IDE Channel 0" or similar
                            • Vivi
                              Banned
                              • Sep 2014
                              • 101
                              Okay I disabled the "Standard Dual Channel PCI IDE Controller". What's next?
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                #115
                                To run this test again that I asked in post #107
                                • Vivi
                                  Banned
                                  • Sep 2014
                                  • 101
                                  I did, and it still shows nothing (n/a), but actually, it seems like now that I enabled SMART, the computer runs fast like its supposed to, when I log onto all users.
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    #117
                                    That was not what I asked about, I asked you to run the benchmark again.
                                    • Vivi
                                      Banned
                                      • Sep 2014
                                      • 101
                                      how do I do that? You told me to show HEALTH details, and none
                                        • 30928
                                        he wants you to run the test that creates a graph for hd transfer rate.
                                        • Vivi
                                          Banned
                                          • Sep 2014
                                          • 101
                                          so is it this one?:
                                            DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:36 PM
                                            DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:30 PM
                                            DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
                                            09-12-2024, 03:28 PM
                                            DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
