hi guys; i have my Hp dv-6 1259DX and it has Intel card Hd 4500 with max resolution 1366x720 and my LCD Tv has the same resolution through HDMI,how come whem i use 1366x720 my TV displays a very small screen,in order to fill tv screen i have to change resolution to 1280x720 and then has screen edges cut,i realy don't understand,can you shad some light, is there any drivers that can adjust the 1366x720 to fit the screen, in Win 10 or win 7?
1366x720 resolution?
Re: 1366x720 resolution?
Thanks rievax; i do that too, but when i change resolution in the PC to 1366x768 the screen on tv is very small,as i said in order to fill screen on the tv i have to use 1280x720 and still it cuts edges.Comment
The most likely reason why there are 1366x768 (and 1280x768) displays is to maintain backwards compatibility of the 4:3 1024x768 resolution.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
1366x720 isn't a proper aspect ratio for anything - 683:360 ratio.
1280x720 is the proper resolution for 16:9 720p, hence it'll work normally. The next best thing that might work is 1366x768 but odds are since it doesn't work the TV is just made for 1280x720 max and tries to scale everything else.Comment
1366x768 is a surrogate for 16:9 since 1365.333 x 768 can't be used (768 * (16/9) = 1365 1/3). Not that 16:10 would be usable either, that would be ~1229x768. 768p needs to die in a fire, why anyone would want a 768p monitor in the first place is beyond me, we're not in 1998.Comment
My HP DV-6 1259DX has HD4500 but i only see 1366x668 max, i have to use 1280x720 so it fits the screen and has best resolution on the TV,it always detects resolution auto,if the Tv was 1920x1080 then it would have that resolution,
i tried it with my HD 15'' Led tv that has 1080i and it detects 1920x1080,
i guess the problem is the tv.
What i don't understand why is shown the same resolution of the tv and i get small pic!with 1280x720 i get the best pic and a close fit of the screen,although the edges are cut off.Comment
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... -
by ChrissygizmoHello everyone, I’ve just been given a Samsung UE55JU6800K smart tv as it had white spots on the screen due to the led lenses falling off. After refitting them & putting the tv back together I thought it was a nice easy fix for a free bedroom tv , then I tried it before screwing the back into place. I realised that the right side of the screen was darker than the other side, I removed the screen again as I thought the backlights had failed but they are fine.
I put the screen back in place & turned it back on . The screen seemed to be ok again but different screens on the same... -
by spice_discI'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...1 Photo -
by ipatchi have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
- Loading...
