please help,what diode can i replace to a ah180 diode?what might be the compatible diode for ah180 omnipolar diode?
ah180
by iMuhtasebWow it's been a while since I posted!
This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
Tested another locked logic board on customer's top case and it posted with keyboard and... -
by NicRacHello everybody☺️ I am glad to be here and looking forward to a good discussion.
First of all, I am new here. Therefore I will shortly introduce myself.
I am Nico and currently I study Physics.
In my freetime I like to build and repair stuff. Especially big battery's.
A few years ago I got myself an electric unicycle, monowheel or however you call that.
The battery bms was broken so I replaced and resolder that. Nothing big.
I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...5 Photos -
by sam_sam_samI have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
I bought this from an eBay seller but unfortunately they only had one
I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
I bought three of from them to also make battery packs with this output power limit in mind
I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery... -
by SuperAmanI did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
by InsertCoinHello and happy new year ,
my Analog Combustion Machine Honeywell gone bad and I don't know what type of diode is utilized.
There is no mark around the body of the diode. The Schematics are general referred only, without any electronics components and values.
The two contacts (2),(5) of the Relay Coil need 48 Volts DC to begin operating. Between these two contacts in series is the bad diode and near of contact (5) is the bad pnp (bc856b) Transistor that can be easily replaced.
I have made a diagram of the PCB and some measurements along some... - Loading...
