HELP!! Samsung Plasma just clicks
  • mjmonty
    • Feb 2015
    • 9
    Samsung 51 Inch Plasma
    Model# PN51D530A3F
    So last week, I get home and try to turn on the TV and nothing happens. When I unplugged and plugged back in, all it would do is click 5 - 7 times and then nothing.
    I took it to a local TV service repair shop and paid $50 for an estimate. The estimate came back at $390 for a bad power supply and bad X main. (as well as something else which was ineligible - regulation???)
    I thought to myself, "Matt, you worked on million dollar aircraft in the Navy. Surely you can fix a TV." So I turned to google and was met with a plethora of information (good and bad).
    I disassembled the TV and first isolated the Y and X boards coming off the power supply. And lo and behold, it "turned on" with jingle. The I isolated the X main, but plugged the Y main in and it turned on again. I assumed that the X main board was bad, so I ordered a replacement from SHOPJIMMY and had it the very next day.
    I was so excited that I saved myself hundreds of dollars, but when I replaced the X main board, the clicking continued.
    I was assuming that since it powered on without the X main plugged in, that the power supply was good. Am I wrong for assuming this?
    If anyone can take time to help me, I would be very grateful. I already was forced to watch the Superbowl on a 27 inch.
    09-07-2024, 05:50 AM
  • Asraf Atb
    Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
    by Asraf Atb
    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
    01-27-2025, 05:02 PM
  • bcstedt
    Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
    by bcstedt
    Just starting to crack into this one and wanted to get the ball rolling.
    At power on (plug in), power light on, relays click, repeat (sometimes)
    After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
    Removed Y-Main for inspection and testing
    This pic from:
    PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
    12-15-2023, 10:30 AM
  • JSin21
    Compatibility of main boards between different variations of samsung MU6100
    by JSin21
    Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
    I have Samsung Smart TV UA65MU6100WXXY version DA01
    Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
    11-27-2023, 04:54 AM
  • Biruslapio
    Samsung PL42C450 plasma X-Main IGBTs
    by Biruslapio
    Hello, the problem with this TV is it has all the Y and X voltages, but does not produce any image.
    It had a TON of cracked solder joints on these boards, fixed all that I could find, but in the last test I forgot to plug in the Y-SUS to control board flat cable, it was left dangling and possibly some pins shorted to the panel metal ground, the X-Main buzzed quietly then blew up in 3 seconds after powering up, annoying.
    Two RJH30E2 shorted, they are 360V 35A 1.7VCE IGBTs, the problem is I don't have any 360V IGBTs, only 300V or 600V, would two RJP3065 fit in? It's...
    04-08-2022, 01:16 PM
